Serilthas Posted December 24, 2018 Report Posted December 24, 2018 (edited) Coil: Dual SS904L Coil 0.2 Ω Material: SS904L Replay Compatible: Yes Coil: Dual SS904L Coil 0.4 Ω Material: SS904L Replay Compatible: Yes Edited December 24, 2018 by Serilthas 1
Buellbloke Posted December 30, 2019 Report Posted December 30, 2019 On 12/24/2018 at 2:57 PM, Serilthas said: Coil: Dual SS904L Coil 0.2 Ω Material: SS904L Replay Compatible: Yes Coil: Dual SS904L Coil 0.4 Ω Material: SS904L Replay Compatible: Yes Did you have to load anything in to make it compatible or just use an exisitng wire setup please?
Wayneo Posted December 30, 2019 Report Posted December 30, 2019 12 hours ago, Buellbloke said: Did you have to load anything in to make it compatible or just use an exisitng wire setup please? For REPLAY the only things you need are a TC capable coil, a straight 'watt' coil material type, a theme that supports Replay and the 'use Replay on this profile' option enabled. No wire setup needed at all. 1
Buellbloke Posted December 30, 2019 Report Posted December 30, 2019 1 hour ago, Wayneo said: For REPLAY the only things you need are a TC capable coil, a straight 'watt' coil material type, a theme that supports Replay and the 'use Replay on this profile' option enabled. No wire setup needed at all. I never really considered Crown 4 0.40 ohm coils as temp sensing although I suppose being stainless they are. They do fluctuate some so be a bit of trial and error maybe. Defo considered trying them with Replay though. Didnt for one min think that the Theme could antagonise the option 😮 Thanks for the info dude 😎
Wayneo Posted December 30, 2019 Report Posted December 30, 2019 Uwell (crown) used Nickel legs in their round wire coils, making them difficult to use with the standard TCR for Stainless steel. Replay, with no material profile (aka watts) takes away all that level of confusion. Themes are a wild west. There are some published before Replay was ever mentioned/available. IMHO the top downloads have earned those spots. 1
Buellbloke Posted December 30, 2019 Report Posted December 30, 2019 (edited) 4 hours ago, Wayneo said: IMHO the top downloads have earned those spots. I grabbed this one before your informed and grateful support, am thinking its up to the task. Evolv DNA 75C and 250C Enhanced Default Theme with Replay 3.0 (8 reviews) By Jasonvillamil Edited December 30, 2019 by Buellbloke
retird Posted December 30, 2019 Report Posted December 30, 2019 Yep, there are many, many themes to choose from....... pitch till ya' win...... 1
