47 minutes ago, ronnie.redd said:
sudo apt-get install libfont-freetype-perl libxml-libxml-perl xapian-tools dwww deborphan apt-xapian-index software-properties-gtk
cd Downloads/escribe/
bash SetupEScribe2_SP50_INT.run
and after doing that, I have 57 int, i get the following output trying to run the .sh file after installing
./launch-escribe-suite
13:42:23.1049: System.IO.FileNotFoundException: Could not load file or assembly 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies.
File name: 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f'
  at A.GLL.PO () [0x00027] in <e86c68b7d5a148c3bcf9f4cb27453eae>:0
  at A.GAI.CE () [0x00034] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.GAI+<>c.SE () [0x00000] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.GAI.TE (System.Boolean , System.String ) [0x0017b] in <7f503517b0c24202b94c6c77ff97f7ca>:0
HRESULT: 0x80070002
Unhandled Exception:
System.PlatformNotSupportedException: Operation is not supported on this platform.
  at A.GAI.TE (System.Boolean , System.String ) [0x001b0] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.BE.BE (System.String[] ) [0x00011] in <8e2979cefe5e41efada4eb30def4adb6>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.PlatformNotSupportedException: Operation is not supported on this platform.
On 6/10/2025 at 4:22 PM, James Bellinger said:
I've posted SP67 for Linux, which adds support for Oxva Pro 2 DNA.
Do we have any idea if this will work on Linux Mint 22 which uses Ubuntu 24.04? gtk sharp is near impossible to get now-a-days. Could really use a bit of help getting it to run as i can't as of yet.
thanks.
  • 1 month later...
thanks.
In LM 22 load Software Manager
In Software Manager, search for Synaptic
If it's not installed, install it.
Search Synaptic for your dependencies, check the box, click apply, confirm with another click on apply and it should load.
  • 3 weeks later...
I've ported Linux EScribe SP68 from GTK 2 to GTK 3. Some newer systems didn't have gtk-sharp2 easily available, so this should make those systems usable.
*This is still a test version*, but if you'd like to try it,  let me know what bugs you run into!
https://downloads.evolvapor.com/SetupEScribe2_SP68_INT_GTK_Test1.run
The bugs I've found so far are:
(1) Multiline labels such as in Atomizer Analyzer don't lay out correctly.
(2) Text fields with escape codes (such as Format and Label on Small Screen Pod devices) don't save properly.
(3) Occasionally, dialog boxes are misaligned relative to the window that is showing them.
Enjoy :)
God bless.
James
  • Thanks 3
Currently attempting to run the new test version. GTK3 is present and up to date on Arch (Wayland KDE).
Last version ran great! This one, not so much.
When launching from shortcut, I get nothing.
When launching from terminal, here's what I get.
[alexander@archwinmax ~]$ bash /home/alexander/.local/opt/evolv/escribe-suite/launch-escribe-suite
11:42:20.2213: System.MissingMethodException: Method not found: void Gdk.Screen.add_MonitorsChanged(System.EventHandler)
  at A.ZYY.EX () [0x00027] in <02b00bdd2b4f4d34a20952e967aab6dc>:0
  at A.WXU.BN () [0x00034] in <d1b359a9d8c44ee289d7b8b5f23cb7c1>:0
  at A.WXU+<>c.QN () [0x00000] in <d1b359a9d8c44ee289d7b8b5f23cb7c1>:0
  at A.WXU.HN (System.Boolean , System.String ) [0x0017b] in <d1b359a9d8c44ee289d7b8b5f23cb7c1>:0
HRESULT: 0x80131513
  at A.WXU.HN (System.Boolean , System.String ) [0x001b0] in <d1b359a9d8c44ee289d7b8b5f23cb7c1>:0
  at A.SN.SN (System.String[] ) [0x00011] in <5ef53635d6784895aa259437f6ef683f>:0
From what I understand (and I could be very wrong), monitors-changed is an X11 function, not sure if this might be some Xwayland issue?
Please let me know if there's any further information I can provide
I'm no programmer, but happy to do what I can do to diagnose and bug-hunt
This was my concern about porting to GTK 3. The C# bindings have been in beta forever (effectively abandonware), so each distribution is likely to have a different version with  different functions.
Give this a try:
https://downloads.evolvapor.com/SetupEScribe2_SP69_INT.run
I changed how I register for the monitors changed event. I'll bet you'll have some other error, but it should take care of that one.
My version of GTK Sharp 3, on Mint, is 2.99.3-4. What does it list as your version? Also, what's the specific OS version, etc.? I've not used Arch Linux before, but certainly could give it a try in a virtual machine.
Thanks!
God bless.
James
  • Thanks 1
I shall give it a test when I return home in 2 days and also give a better report on what relevant packages/versions I'm running.
Honestly, thankyou so much for the work on the Linux port.
Our vape store computers are all Linux based and so are a few customers.
Just know that your work is seriously appreciated 😁
Okay, so I'm finally back home.
Just installed SP69, and yes the monitors-changed issue seems resolved. As predicted though, new error 😅
07:35:39.1585: System.MissingMethodException: Method not found: Gtk.Settings Gtk.Widget.get_Settings()
  at DimensionEngineering.Common.Platform.UnixGtk.UnixGtkPlatformHelper.HH () [0x00000] in <54a546c5898c453b833f3015c4c1e070>:0
  at DimensionEngineering.Common.Platform.UnixGtk.UnixGtkPlatformHelper.TY () [0x0013d] in <54a546c5898c453b833f3015c4c1e070>:0
  at A.UQK.VG () [0x00027] in <cbddc29820b84d138af4b92cac521704>:0
  at A.AUQ.LC () [0x00034] in <593b78e79b3f40f48766e2d2a9265ec6>:0
  at A.AUQ+<>c.XC () [0x00000] in <593b78e79b3f40f48766e2d2a9265ec6>:0
  at A.AUQ.KC (System.Boolean , System.String ) [0x0017b] in <593b78e79b3f40f48766e2d2a9265ec6>:0
HRESULT: 0x80131513
  at A.AUQ.KC (System.Boolean , System.String ) [0x001b0] in <593b78e79b3f40f48766e2d2a9265ec6>:0
  at A.EC.EC (System.String[] ) [0x00011] in <5ef53635d6784895aa259437f6ef683f>:0
I'm using gtk-sharp-3 3.22.2-2 from the standard Arch repos
Arch doesn't really have an OS version as it's rolling release, so packages are updated on the go, rather than as a batched OS version. Kernel wise though, I'm using 6.16.5-arch1-1 if that helps at all 😁
Got another Arch user here :joy:
I'm getting the same error as RapideWilson and have the same version of gtk-sharp 3, my kernel is slightly newer at 6.16.6-3.
Thanks for all your doing for getting us Linux users running!
All right. Let's try this again. I found that the Debian and Arch versions of GTK Sharp 3 were seemingly not compatible in some ways.
So, this version gets rid of the dependency on distribution versions of GTK Sharp, and instead includes the GTK Sharp fork on GitHub, which doesn't depend on distribution-specific files.
It's got its own set of bugs, but it *may* be consistent across Linux distributions. I tested it on Mint Linux and Manjaro Linux, and it worked on both of those. Here's the download:
https://downloads.evolvapor.com/SetupEScribe2_SP69_INT_GTK_Test2.run
Known bugs:
ECigStats seems to not even run in this version.
Let me know what bugs you run into. Thanks!
God bless.
James
  • Thanks 1
Escribe software running for me 😁 Cheers James!
Ecigstats doesn't launch for me on my systems either. Terminal doesn't seem to be reporting anything, just a dead stop.
Cheers for the update! Time to sort new service packs on customers kits 😄
Running into a few stability issues when uploading theme changes on Xlim Pro 2 DNA, not sure if kit or software.
Very occasionally Escribe will close mid-upload and render the device inaccessible through Escribe until the device has been rebooted. Nothing bad has happened, but felt it might be worth mentioning it.
By the way, have you been encountering "Fill Pod" errors on the Pro 2 DNA, outside of when the pod really needed filling / was an old pod?
(I made a separate test version to address that. I am wondering if it'd be worth making a Linux version of it.)
I was, but ever since changing 'Dry Limit Resistance' setting from 118% to 122% it's been a LOT more consistent for me personally
A brief run with Cinnamon Desktopped CatchyOS and SP69 INT GTK Test2.run looks pretty sweet although I didn't go into great depth.
Edited by Podunk Steam
All about the info ya know
Hello,
I Upgraded to Debian 13 "Trixie" and installed the "SetupEScribe2_SP69_INT_GTK_Test2.run", it crashes when connecting and downloading settings, here is the log:
ariel@graske:~/.local/opt/evolv/escribe-suite$ ./launch-escribe-suite
Control=(0.207843137254902, 0.207843137254902, 0.207843137254902)
LabelText=(0.933333333333333, 0.933333333333333, 0.925490196078431)
DisabledText=(0.568627450980392, 0.568627450980392, 0.564705882352941)
ActiveCaption=(0.105882352941176, 0.105882352941176, 0.105882352941176)
ActiveCaptionText=(0.933333333333333, 0.933333333333333, 0.925490196078431)
InactiveCaption=(0.105882352941176, 0.105882352941176, 0.105882352941176)
InactiveCaptionText=(0.933333333333333, 0.933333333333333, 0.925490196078431)
List=(0.176470588235294, 0.176470588235294, 0.176470588235294)
ListText=(1, 1, 1)
ListFocused=(0.0823529411764706, 0.325490196078431, 0.619607843137255)
ListFocusedText=(1, 1, 1)
ListSelected=(0.176470588235294, 0.176470588235294, 0.176470588235294)
ListSelectedText=(1, 1, 1)
ListDisabledText=(0.568627450980392, 0.568627450980392, 0.564705882352941)
Got link color.. FG=(0.207843137254902, 0.517647058823529, 0.894117647058824)
Got tooltip color... FG=(0.933333333333333, 0.933333333333333, 0.925490196078431) BG=(0.207843137254902, 0.207843137254902, 0.207843137254902)
Current edition: INT
Found edition: US
Found edition: INT
Edition matched!
Found edition: OXVA
System.DllNotFoundException: libwebpdemux assembly:<unknown assembly> type:<unknown type> member:(null)
  at (wrapper managed-to-native) A.LSJ+GSJ.RI()
  at A.LSJ+GSJ..cctor () [0x00000] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
keys-changed
state-changed
state-changed
Killed
ariel@graske:~/.local/opt/evolv/escribe-suite$ Control=(0.207843137254902, 0.207843137254902, 0.207843137254902)
ListText=(1, 1, 1)
Found edition: US
Found edition: INT
Edition matched!
Found edition: OXVA
17:58:14.4594:   Benchmark: Tab Configuration: Welcome took 29.9959 ms.
17:58:14.4733:   Benchmark: File->New took 5.3215 ms.
17:58:14.4743: Benchmark: Startup took 618.024 ms.
keys-changed
state-changed
17:58:14.5182: Benchmark: AutoConnect took 7.2571 ms.
state-changed
state-changed
state-changed
state-changed
17:58:26.9836: Benchmark: AutoConnect took 11.5315 ms.
17:58:27.0729: Benchmark: AutoConnect took 88.4787 ms.
state-changed
state-changed
state-changed
state-changed
state-changed
state-changed
Closed.
state-changed
state-changed
17:58:37.0502:   Benchmark: Reading EEPROM at offset 0x0 and size 84 took 43.941 ms.
17:58:37.1611:   Benchmark: Reading EEPROM at offset 0x0 and size 3840 took 91.2567 ms.
17:58:37.1694: Benchmark: Downloading settings took 184.3547 ms.
Closed.
Exception in Gtk# callback delegate
  Note: Applications can use GLib.ExceptionManager.UnhandledException to handle the exception.
System.ArgumentException: Value does not fall within the expected range.
  at A.UNQ.GI (System.Object ) [0x000a9] in <a66080483acc4537937a56ffe717ea52>:0
  at A.PMU.HKI (A.QNQ , System.Int32 , System.Object ) [0x00006] in <a66080483acc4537937a56ffe717ea52>:0
  at A.PMU.DNI (A.QNQ , System.Int32 , System.Object ) [0x00006] in <a66080483acc4537937a56ffe717ea52>:0
  at A.PMU+JMU.GK (System.Object ) [0x00022] in <a66080483acc4537937a56ffe717ea52>:0
  at A.WAL.KN () [0x00043] in <3aaa3e70696344c6914a0436d3c67fc6>:0
  at A.WAL.AK () [0x00031] in <3aaa3e70696344c6914a0436d3c67fc6>:0
  at A.PMU.ER (A.QNQ , System.Object , System.Nullable`1[T] ) [0x0000a] in <a66080483acc4537937a56ffe717ea52>:0
  at A.UBQ`1[A].PD (A.HDQ , System.Byte[] ) [0x00041] in <a66080483acc4537937a56ffe717ea52>:0
  at A.ABQ`1[A].IJI (A.HDQ ) [0x00082] in <a66080483acc4537937a56ffe717ea52>:0
  at A.ABQ`1[A].SD (A.HDQ ) [0x0001d] in <a66080483acc4537937a56ffe717ea52>:0
  at A.WZQ`1[A].YE (A.HDQ ) [0x00024] in <a66080483acc4537937a56ffe717ea52>:0
  at A.ARQ.TK () [0x0014b] in <a66080483acc4537937a56ffe717ea52>:0
  at A.BAV.YGO (A.QAV , A.PMU ) [0x00016] in <a66080483acc4537937a56ffe717ea52>:0
  at A.BAV.JGO (A.OLF , A.YMX , A.PMU , System.Nullable`1[T] ) [0x00027] in <a66080483acc4537937a56ffe717ea52>:0
  at A.TJX.CI (A.OLF , A.BAV , System.Byte[] , A.YMX , System.Boolean , System.Nullable`1[A.TJX+NFX]& , System.Nullable`1[T] ) [0x00031] in <df3d5f13b65843d59654128c266f1e2e>:0
  at A.TJX.QI (System.Boolean , System.Boolean , System.Nullable`1[T] , System.Object , System.Boolean , System.Boolean ) [0x00098] in <df3d5f13b65843d59654128c266f1e2e>:0
  at A.TJX.VI (System.Boolean , System.Boolean , System.Nullable`1[T] , System.Object , System.Boolean , System.Boolean , System.Boolean ) [0x00026] in <df3d5f13b65843d59654128c266f1e2e>:0
  at A.DNX.II () [0x00046] in <df3d5f13b65843d59654128c266f1e2e>:0
  at A.DNX+<>c.OI (A.QUJ ) [0x00000] in <df3d5f13b65843d59654128c266f1e2e>:0
  at A.AUJ+TUJ.AI () [0x0002c] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
  at A.PQJ+BQJ.KI (System.Object , System.EventArgs ) [0x0006d] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
  at A.RYG.VLK () [0x00026] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.NCG.KI (System.Action ) [0x00015] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.RYG.UGI () [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.RYG.RDI () [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.NCG.LI (A.SGG ) [0x00046] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.RYG.WQI () [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.OLG.GN () [0x00013] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.OLG.OnButtonPressEvent (Gdk.EventButton evnt) [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at Gtk.Widget.ButtonPressEvent_cb (System.IntPtr inst, System.IntPtr evnt) [0x00012] in <d0dc9f3a91c34db496df00dd6d19bb1e>:0
  at GLib.ExceptionManager.RaiseUnhandledException (System.Exception e, System.Boolean is_terminal) [0x00000] in <a7d917b1864c44f1a0d710c8d30f7cb8>:0
  at Gtk.Widget.ButtonPressEvent_cb (System.IntPtr inst, System.IntPtr evnt) [0x00000] in <d0dc9f3a91c34db496df00dd6d19bb1e>:0
  at System.Object.wrapper_native_0x7f17cd806fe0 () [0x00000] in <8611ac11d22247aabb4fd94490032492>:0
  at Gtk.Application.Run () [0x00000] in <d0dc9f3a91c34db496df00dd6d19bb1e>:0
  at DimensionEngineering.Common.Platform.UnixGtk.UnixGtkPlatformHelper+JRG.KI () [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.NCG.KI (System.Action ) [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at DimensionEngineering.Common.Platform.UnixGtk.UnixGtkPlatformHelper.XN (System.Action ) [0x00000] in <771b61c096e549d881d6ce5756ba66c2>:0
  at A.ZGJ.EX (System.String , System.Func`1[TResult] , System.Func`2[T,TResult] , System.Action ) [0x00000] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
  at A.TN+NK.ZO (A.TN+IK ) [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.TN.TK (A.CKQ ) [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.WI+<>c.OI (A.CKQ ) [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.OLV. (System.Object , A.CKQ ) [0x00000] in <a66080483acc4537937a56ffe717ea52>:0
  at A.OLV.II (System.Object , A.CKQ ) [0x00000] in <a66080483acc4537937a56ffe717ea52>:0
  at A.HKQ.YI (System.String , A.CKQ ) [0x00000] in <a66080483acc4537937a56ffe717ea52>:0
  at A.ON.VI (System.String[] ) [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.ON+NN.II () [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.ZGJ.DX (System.Action ) [0x00000] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
  at A.ZGJ.YX (System.Action ) [0x00000] in <0594b7d4112d4d3b851e1b0839fb19cd>:0
  at A.ON.SI (System.String[] ) [0x00000] in <29520a13b21f4f188dcc6c19bbf5d0fb>:0
  at A.TI.TI (System.String[] ) [0x00000] in <2479da9410484492b8f1f133fc468660>:0
I've posted up a version that fixes the bug with DNA Go and Reflex. If that's the problem you were having, it should be fixed now. Let me know :)
God bless.
James
  • Thanks 1
