sudo apt-get install libfont-freetype-perl libxml-libxml-perl xapian-tools dwww deborphan apt-xapian-index software-properties-gtk
cd Downloads/escribe/
bash SetupEScribe2_SP50_INT.run
and after doing that, I have 57 int, i get the following output trying to run the .sh file after installing
./launch-escribe-suite
13:42:23.1049: System.IO.FileNotFoundException: Could not load file or assembly 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies.
File name: 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f'
  at A.GLL.PO () [0x00027] in <e86c68b7d5a148c3bcf9f4cb27453eae>:0
  at A.GAI.CE () [0x00034] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.GAI+<>c.SE () [0x00000] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.GAI.TE (System.Boolean , System.String ) [0x0017b] in <7f503517b0c24202b94c6c77ff97f7ca>:0
HRESULT: 0x80070002
Unhandled Exception:
System.PlatformNotSupportedException: Operation is not supported on this platform.
  at A.GAI.TE (System.Boolean , System.String ) [0x001b0] in <7f503517b0c24202b94c6c77ff97f7ca>:0
  at A.BE.BE (System.String[] ) [0x00011] in <8e2979cefe5e41efada4eb30def4adb6>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.PlatformNotSupportedException: Operation is not supported on this platform.
Sounds like you need to install gdk-sharp
I'll write a shell script for your version if you want. Might take a day. What distro are you on? Linux Mint. Ubuntu based or Debian? (LMDE)
On 6/10/2025 at 4:22 PM, James Bellinger said:
I've posted SP67 for Linux, which adds support for Oxva Pro 2 DNA.
Do we have any idea if this will work on Linux Mint 22 which uses Ubuntu 24.04? gtk sharp is near impossible to get now-a-days. Could really use a bit of help getting it to run as i can't as of yet.
thanks.
