HELP Hcigar 250VTS Check Battery error
Agregory23
On 10/26/2017 at 6:22 PM, Agregory23 said:
I recently got the Hcigar VT250S and every time I change to two batteries it gives me the check battery error. I went to Escribe and changed the settings to Two Cell at 160 watts and it did nothing. Please Help!
Did you upload you settings to the device after your changes? It appears that the board is still trying to find 3 cells, but only seeing 2 cells, hence the 'Check Battery' message...The soft cell cutoff setting is not going to cause this error
hello i am using hcigar vt250s. When using 2pcs, the device sometimes turns itself off, I press the fire button and it opens and closes the screen. I am wearing 3pil lid, I select 3 cell from PC connection but the battery is empty and I get a batery chek error on the screen of the device. help please
