Lowbytes Posted July 9, 2017 Report Share Posted July 9, 2017 Hi James Service Pack download worked without any Problem (El Capitan) Thanks for adding DNA60 - beside i do not own one Will be back with reports when 75 non C or 200 is added ;-) Great work - absolutely happy with MAC Version and sure that soon MAC version will work as great as windows Version! Regards Mikel Link to comment Share on other sites More sharing options...
ndb Posted July 9, 2017 Report Share Posted July 9, 2017 I have to report something weird that _might_ be related to the latest SP22 firmware, but I'm not sure, so I'll try to describe what I'm seeing. First of all, it has happened sometime with the previous FW too, but it was occasional, while it has now become systematic. Using my two 75C mods (vapedroid x1c2 and therion 75C), with two different atomizers/builds (serpent smm on the droid with a 1.3ohm SS316L, squape Xdream on the therion with a 0.62ohm SS316L) both with the SS316L profile from steam-engine. After the mod has been idle for a while (probably for the time it takes to auto-lock, but I'm not sure), it won't fire going immediately into "temp protect". In a couple of instances I was able to get it firing again just re-trying for 3 or 4 times, but most of the times it won't just fire, _never_. The workaround I found to be working is: 1) switch to a watt (i.e. no TC) profile 2) fire it a couple of times (no temp protect error here obviously) 3) switch back to the TC profile 4) fire it and when asked refuse to update the cold ohm value (which is of course higher and wrong because of the heat-up during firing in watt mode) And then it'll work again. As soon as I let it sit idle for a while, it will get back into not firing and I'll have to repeat the process again. I tried to re-flash the FW, hard-reset, remove batteries, switch atomizers between the mods. Nothing seems to work. Anybody else experiencing this? Link to comment Share on other sites More sharing options...
James Posted July 9, 2017 Author Report Share Posted July 9, 2017 Hmm. Thanks for reporting this. I had noticed an occasional Temp Protect myself, and have noticed Peak Temperature occasionally reading wrong. I think it might be misreading when it's down at 1W or less before firing. Will investigate on Monday. In the meantime, FWIW, the Mac version should run on SP21 just as well. 1 Link to comment Share on other sites More sharing options...
Lowbytes Posted July 9, 2017 Report Share Posted July 9, 2017 (edited) Yes - sometimes (after felling to sleep) the 75C not working in Temp Mode Workaround 2 or 3 Times pressing firebutton short - TC coming back I can see it in my Theme because i´ve set the Temp reading to live view - If my dest Temp is set to 210°C - firing - Temp digits are going blank (because there´s no temp reading) - after 2 or 3 Times short firing live temp is coming back! Edited July 9, 2017 by Lowbytes Link to comment Share on other sites More sharing options...
ndb Posted July 9, 2017 Report Share Posted July 9, 2017 On 7/9/2017 at 1:33 PM, James said: Hmm. Thanks for reporting this. I had noticed an occasional Temp Protect myself, and have noticed Peak Temperature occasionally reading wrong. I think it might be misreading when it's down at 1W or less before firing. Will investigate on Monday. In the meantime, FWIW, the Mac version should run on SP21 just as well. Expand 1 Thanks @James , I also noticed the following: if I re-read cold ohms right after failing to fire in TC with the temp protect error, most of the times it reads a lower resistance (e.g. right now, the 1.3 became 1.278 and the 0.62 went down to 0.605) and in some cases with this lower reading I'm able to start firing again, but then it feels like it actually read too low and I'm in weak-vape land. As I just noticed this, I haven't observations for what happens if it re-reads a cold ohm value which is _not_ lower than the pre-existing one. To summarize, 3 different scenarios: Refuse to fire, but retrying 3 or 4 times starts firing again. Only happens rarely, I'd ballpark it as less than 10% of the cases Refuse to fire forever, the fire-in-watts-then-back-to-TC dance "unlocks" it 100% of the times Refuse to fire forever, re-reading a lower resistance "unlocks" it about 50% of the times. No observations for what happens if it re-reads the same cold ohm value. On 7/9/2017 at 7:49 PM, Lowbytes said: I can see it in my Theme because i´ve set the Temp reading to live view - If my dest Temp is set to 210°C - firing - Temp digits are going blank (because there´s no temp reading) - after 2 or 3 Times short firing live temp is coming back! Expand 2 Exactly, but in my case it self-recovered in less than 10% of the cases, see my point 1 above. 1 Link to comment Share on other sites More sharing options...
peraspera Posted July 10, 2017 Report Share Posted July 10, 2017 On 7/7/2017 at 11:15 AM, James said: If the DNA 75c is supposed to fire immediatealy after coming out of a long overnight sleep, my Therion DNA 75c does not do that. I have the default them installed which show the Evolv screen instead of firing. If I push the fire button the row of little round circles at the bottom of the screen light up red? one by one. Pressing the fire button quickly in indeterminate amount of times brings up the normal screen and the Therion then fires returning to normal functioning. I assumed, mistakenly it seems, that there was some sort of unlocking sequence of button pressing I should use to wake the Therion up but couldn't figure out what that might be for a certainty although three or four quick presses seems to do it. This behavior has been the same using SP22 and SP21. This is a very small nitpick but after launching Escribe and before clicking on anything in the EScribe Suite window the Escribe menu is blank and there is no way to quit the program if it was accidentally launched. Expand Link to comment Share on other sites More sharing options...
embe71 Posted July 10, 2017 Report Share Posted July 10, 2017 (edited) You quoted James for your own post, please correct this because that's rather confusing. You can set the unlock-sequenze, the lock time and to lock when idle or not in Escribe. You can set the idle time in the theme in theme-designer. @James: I know this is mainly a mac-beta-version-thread but since SP22 is included: Cold ohms still read a good amount too low compared to the DNA 166 (Therion 166) if reading the coil for the first time. As a result temperature goes up through the roof and TC kicks in far too early. Adjusting it up a bit manually (without locking the resistance) works then fine all the time. It makes no difference if I run case analyzer, use the default-settings or other settings for thermals some people posted as result for my therion 75C. Same behaviour on all my 4 Therion 75Cs (mod resistance is fine). I also noticed that the "wrong" offset seems to have something to do with the coilsize: Using thicker wire (SS316L) or thicker Clapton wire (SS316L) results in a smaller offset from the real resistance when reading cold ohms. Also there seems to be no refinement going on as on the DNA250/166. Is this really the case and the 75C is not able to refine over time? Edited July 10, 2017 by embe71 Link to comment Share on other sites More sharing options...
Lowbytes Posted July 10, 2017 Report Share Posted July 10, 2017 On 7/10/2017 at 6:11 AM, embe71 said: @James: I know this is mainly a mac-beta-version-thread but since SP22 is included: Cold ohms still read a good amount too low compared to the DNA 166 (Therion 166) if reading the coil for the first time. As a result temperature goes up through the roof and TC kicks in far too early. Adjusting it up a bit manually (without locking the resistance) works then fine all the time. It makes no difference if I run case analyzer, use the default-settings or other settings for thermals some people posted as result for my therion 75C. Same behaviour on all my 4 Therion 75Cs (mod resistance is fine). I also noticed that the "wrong" offset seems to have something to do with the coilsize: Using thicker wire (SS316L) or thicker Clapton wire (SS316L) results in a smaller offset from the real resistance when reading cold ohms. Also there seems to be no refinement going on as on the DNA250/166. Is this really the case and the 75C is not able to refine over time? Expand I´m using a Clapton Coil V2A - 0,37 Ohm - on all other DNA´s reading 0,37 cold - working fine on TC on all my DNA´s - to have the same vape experience i´ve to set it to 0.335 Ohm on the DNA75C A bit far from accurate......... Just to show some Numbers! But with manually set to this data TC working like a charm Link to comment Share on other sites More sharing options...
embe71 Posted July 10, 2017 Report Share Posted July 10, 2017 That matches exactly my experience: I know what the temperature is roughly when firing on my DNA250. So I up the cold ohms manually until I get about the same temp which is in the range you describe and the end result also matches roughly what my coilmaster build deck measures. After manually having upped the ohms TC works fine. 1 Link to comment Share on other sites More sharing options...
blueridgedog Posted July 10, 2017 Report Share Posted July 10, 2017 Update process went smooth for my hack and MacPro. Link to comment Share on other sites More sharing options...
GamulinAO Posted July 11, 2017 Report Share Posted July 11, 2017 (edited) Try to run Escribe suite on latest MacOs High Sierra and have this error. Цитата Process: mono-sgen32 [1042] Path: /Applications/EScribe Suite.app/Contents/MacOS/RunProgram Identifier: com.evolvapor.EScribe.Suite Version: ??? Code Type: X86 (Native) Parent Process: ??? [1] Responsible: mono-sgen32 [1042] User ID: 501 Date/Time: 2017-07-11 10:12:01.867 +0300 OS Version: Mac OS X 10.13 (17A306f) Report Version: 12 Anonymous UUID: 1F7B027A-5683-21DD-6484-973C3967EBD1 Time Awake Since Boot: 1600 seconds System Integrity Protection: enabled Crashed Thread: 0 tid_303 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGABRT) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY VM Regions Near 0: --> __TEXT 00000000000a8000-0000000000432000 [ 3624K] r-x/rwx SM=COW /Applications/EScribe Suite.app/Contents/Frameworks/Mono.framework/Versions/5.3.0/bin/mono-sgen32 Application Specific Information: abort() called Thread 0 Crashed:: tid_303 Dispatch queue: com.apple.main-thread 0 libsystem_kernel.dylib 0xa76fcef6 __pthread_kill + 10 1 libsystem_pthread.dylib 0xa782d6dd pthread_kill + 307 2 libsystem_c.dylib 0xa764c4ba abort + 133 3 mono-sgen32 0x00175c1b mono_handle_native_crash + 811 4 mono-sgen32 0x001d8af9 mono_arch_handle_altstack_exception + 169 5 mono-sgen32 0x000b89c2 mono_sigsegv_signal_handler + 482 6 libsystem_platform.dylib 0xa782202b _sigtramp + 43 7 ??? 0xffffffff 0 + 4294967295 8 mono-sgen32 0x000b87e0 mono_sigill_signal_handler + 128 9 com.apple.GeoServices 0xa3911a8c _GLOBAL__sub_I_GEOAddressObject.mm + 54 10 dyld 0x00577502 invocation function for block in ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 34 11 dyld 0x005611ed dyld3::kdebug_trace_dyld_duration(unsigned int, unsigned long long, unsigned long long, void () block_pointer) + 210 12 dyld 0x00577450 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 422 13 dyld 0x00577659 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 59 14 dyld 0x005724e8 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 350 15 dyld 0x00572472 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 232 16 dyld 0x005714b8 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 104 17 dyld 0x0057153b ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 65 18 dyld 0x005654a2 dyld::runInitializers(ImageLoader*) + 71 19 dyld 0x0056e22c dlopen + 557 20 libdyld.dylib 0xa75a5a85 dlopen + 81 21 ??? 0x02b97614 0 + 45708820 22 ??? 0x02b97098 0 + 45707416 23 ??? 0x02b960c5 0 + 45703365 24 mono-sgen32 0x000bc7f8 mono_jit_runtime_invoke + 1592 25 mono-sgen32 0x002dd33e do_runtime_invoke + 94 26 mono-sgen32 0x002d9184 mono_runtime_class_init_full + 1156 27 mono-sgen32 0x0022fe9d ves_icall_System_Runtime_CompilerServices_RuntimeHelpers_RunClassConstructor + 93 28 ??? 0x02b96f18 0 + 45707032 29 ??? 0x02b96e88 0 + 45706888 30 ??? 0x02b96038 0 + 45703224 31 ??? 0x02b960c5 0 + 45703365 32 mono-sgen32 0x000bc7f8 mono_jit_runtime_invoke + 1592 33 mono-sgen32 0x002dd33e do_runtime_invoke + 94 34 mono-sgen32 0x002d9184 mono_runtime_class_init_full + 1156 35 mono-sgen32 0x000b49b3 mono_jit_compile_method_inner + 2803 36 mono-sgen32 0x000b7a72 mono_jit_compile_method_with_opt + 1490 37 mono-sgen32 0x000b7492 mono_jit_compile_method + 50 38 mono-sgen32 0x001780bb common_call_trampoline + 1083 39 mono-sgen32 0x00177c4a mono_magic_trampoline + 74 40 ??? 0x005ec188 0 + 6209928 41 ??? 0x7ba0ac28 0 + 2074127400 42 ??? 0x006e07d7 0 + 7210967 43 ??? 0x006dc2a0 0 + 7193248 44 ??? 0x006dbd60 0 + 7191904 45 ??? 0x006db2a8 0 + 7189160 46 ??? 0x006dbabf 0 + 7191231 47 mono-sgen32 0x000bc7f8 mono_jit_runtime_invoke + 1592 48 mono-sgen32 0x002dd33e do_runtime_invoke + 94 49 mono-sgen32 0x002e0d23 do_exec_main_checked + 147 50 mono-sgen32 0x002df8e5 mono_runtime_run_main_checked + 69 51 mono-sgen32 0x001345d7 mono_jit_exec + 311 52 mono-sgen32 0x00137202 mono_main + 10114 53 mono-sgen32 0x000ab22b main + 2011 54 mono-sgen32 0x000aaa45 start + 53 Thread 1:: SGen worker 0 libsystem_kernel.dylib 0xa76fcd6e __psynch_cvwait + 10 1 libsystem_pthread.dylib 0xa782b6a3 _pthread_cond_wait + 658 2 libsystem_pthread.dylib 0xa782d298 pthread_cond_wait$UNIX2003 + 51 3 mono-sgen32 0x003580e9 thread_func + 249 4 libsystem_pthread.dylib 0xa782a74d _pthread_body + 292 5 libsystem_pthread.dylib 0xa782a629 _pthread_start + 376 6 libsystem_pthread.dylib 0xa7829d02 thread_start + 34 Thread 2:: SGen worker 0 libsystem_kernel.dylib 0xa76fcd6e __psynch_cvwait + 10 1 libsystem_pthread.dylib 0xa782b6a3 _pthread_cond_wait + 658 2 libsystem_pthread.dylib 0xa782d298 pthread_cond_wait$UNIX2003 + 51 3 mono-sgen32 0x00358062 thread_func + 114 4 libsystem_pthread.dylib 0xa782a74d _pthread_body + 292 5 libsystem_pthread.dylib 0xa782a629 _pthread_start + 376 6 libsystem_pthread.dylib 0xa7829d02 thread_start + 34 Thread 3:: Finalizer 0 libsystem_kernel.dylib 0xa76f3d92 semaphore_wait_trap + 10 1 mono-sgen32 0x002d4df6 finalizer_thread + 278 2 mono-sgen32 0x002a4aab start_wrapper + 795 3 libsystem_pthread.dylib 0xa782a74d _pthread_body + 292 4 libsystem_pthread.dylib 0xa782a629 _pthread_start + 376 5 libsystem_pthread.dylib 0xa7829d02 thread_start + 34 Thread 4:: HID System Events Job Manager 0 libsystem_kernel.dylib 0xa76fcd6e __psynch_cvwait + 10 1 libsystem_pthread.dylib 0xa782b6a3 _pthread_cond_wait + 658 2 libsystem_pthread.dylib 0xa782d298 pthread_cond_wait$UNIX2003 + 51 3 mono-sgen32 0x002c98a8 mono_os_cond_timedwait + 168 4 mono-sgen32 0x002c847b mono_w32handle_timedwait_signal_handle + 219 5 mono-sgen32 0x002c8318 mono_w32handle_wait_one + 952 6 mono-sgen32 0x002d636f ves_icall_System_Threading_Monitor_Monitor_wait + 447 7 ??? 0x006e6158 0 + 7233880 8 ??? 0x006e5ff0 0 + 7233520 9 ??? 0x006e5f60 0 + 7233376 10 ??? 0x006e5f24 0 + 7233316 11 ??? 0x006e5a1c 0 + 7232028 12 ??? 0x006e5931 0 + 7231793 13 ??? 0x006e56eb 0 + 7231211 14 ??? 0x006e53e8 0 + 7230440 15 ??? 0x006e5288 0 + 7230088 16 ??? 0x006e513c 0 + 7229756 17 ??? 0x006e5013 0 + 7229459 18 mono-sgen32 0x000bc7f8 mono_jit_runtime_invoke + 1592 19 mono-sgen32 0x002dd33e do_runtime_invoke + 94 20 mono-sgen32 0x002def67 mono_runtime_delegate_try_invoke + 311 21 mono-sgen32 0x002def9d mono_runtime_delegate_invoke_checked + 45 22 mono-sgen32 0x002a4acf start_wrapper + 831 23 libsystem_pthread.dylib 0xa782a74d _pthread_body + 292 24 libsystem_pthread.dylib 0xa782a629 _pthread_start + 376 25 libsystem_pthread.dylib 0xa7829d02 thread_start + 34 Thread 5: 0 libsystem_pthread.dylib 0xa7829cbc start_wqthread + 0 1 ??? 0x7b76fa20 0 + 2071394848 Thread 6: 0 libsystem_kernel.dylib 0xa76fd71a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0xa782a103 _pthread_wqthread + 1023 2 libsystem_pthread.dylib 0xa7829cde start_wqthread + 34 Thread 7: 0 libsystem_kernel.dylib 0xa76fd71a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0xa782a103 _pthread_wqthread + 1023 2 libsystem_pthread.dylib 0xa7829cde start_wqthread + 34 Thread 0 crashed with X86 Thread State (32-bit): eax: 0x00000000 ebx: 0xa782d5b8 ecx: 0x0077367c edx: 0x00000000 edi: 0xa9ae81c0 esi: 0x00000303 ebp: 0x00773698 esp: 0x0077367c ss: 0x00000023 efl: 0x00000206 eip: 0xa76fcef6 cs: 0x0000000b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0xa9ace330 Logical CPU: 0 Error Code: 0x00080148 Trap Number: 132 Binary Images: 0xa8000 - 0x431ff3 +mono-sgen32 (???) <B8AE6E04-21F7-3840-B09F-F508228A4111> /Applications/EScribe Suite.app/Contents/Frameworks/Mono.framework/Versions/5.3.0/bin/mono-sgen32 0x560000 - 0x5a454b dyld (514) <A2E89CF8-C6FE-3198-B70D-48427CA8AD45> /usr/lib/dyld 0x2d00000 - 0x3aafff3 com.apple.AppKit (6.9 - 1543) <02F3A595-20B0-3AEB-AC16-035305FBB22D> /System/Library/Frameworks/AppKit.framework/AppKit 0x4201000 - 0x43edff3 com.apple.AddressBook.framework (11.0 - 1794) <E5736765-4EEE-3050-95D1-C01E158C472F> /System/Library/Frameworks/AddressBook.framework/AddressBook 0x457b000 - 0x48b3fff com.apple.WebKit (13604 - 13604.1.28.2) <887EBF4A-CB13-3762-9194-2BC35F5FC06E> /System/Library/Frameworks/WebKit.framework/WebKit 0x4bfe000 - 0x4c6efff com.apple.corelocation (2212) <E8990545-A4A4-3FA6-97B8-009DDE4FB344> /System/Library/Frameworks/CoreLocation.framework/CoreLocation 0x9001d000 - 0x9022aff3 com.apple.avfoundation (2.0 - 1311.4.2) <51D0CCEA-FF9E-31B8-8E80-9DFAC2975EFF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation 0x9022b000 - 0x902deff3 com.apple.audio.AVFAudio (1.0 - ???) <016CD8FC-48F7-35F1-B017-24998CC2B649> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio 0x902e0000 - 0x902e0fff com.apple.Accelerate (1.11 - Accelerate 1.11) <333E2B43-4A3F-323E-B563-E2379B733F9F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x902f8000 - 0x90a35fdf com.apple.vImage (8.1 - ???) <B24C7770-55EA-357F-BF8E-431995635749> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x90a36000 - 0x90b71ff7 libBLAS.dylib (1211) <BF99A2CB-4B48-357F-B7BC-FEA08C6B51E5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x90b72000 - 0x90b9fff7 libBNNS.dylib (31) <65195CA9-D651-3962-8B9A-CF7B83CB2345> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x90ba0000 - 0x90f13fff libLAPACK.dylib (1211) <8B0949D5-035C-3216-9D15-17BA099DBF58> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x90f14000 - 0x90f2affb libLinearAlgebra.dylib (1211) <6ADA0BFE-3AAF-3430-8BD8-8C604EBEA81A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x90f2b000 - 0x90f44ff7 libSparseBLAS.dylib (1211) <0C7848B1-0F3B-3EB7-8784-57D15012D2B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x90f45000 - 0x91097fef libvDSP.dylib (621) <65A3B4DE-E243-31A4-97F8-385510334150> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x91098000 - 0x91176ff7 libvMisc.dylib (621) <B7A09E1D-A7C8-33E3-92EF-6AE06C26BD55> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x91177000 - 0x91177fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A9FF566F-F1F5-3161-B436-F5CD2A127FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x92166000 - 0x92166fff com.apple.ApplicationServices (48 - 50) <B334CB27-9A84-3876-A806-096AE5D9FD1D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x92167000 - 0x921cdff3 com.apple.ApplicationServices.ATS (377 - 441) <67F34727-6629-3F7E-9CB2-B05A2543DD81> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x921d0000 - 0x922f7ffb libFontParser.dylib (218) <7C65CE26-7F58-3F86-8040-7484F5B65B9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x922f8000 - 0x92344fff libFontRegistry.dylib (216) <7B33CD0A-0C66-3CA5-822D-C67B5BC60A64> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x92432000 - 0x92437fff com.apple.ColorSyncLegacy (4.13.0 - 1) <3450BE6D-0AA6-32CF-BFB6-A95CA9ED05A9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy 0x924e1000 - 0x92538ff7 com.apple.HIServices (1.22 - 619) <AED25160-2EEB-38DE-B7E6-AD23669C6D22> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x92539000 - 0x92548ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <A372FFDC-1622-3DAE-9567-FDC781BFC63D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x92549000 - 0x925a1ffb com.apple.print.framework.PrintCore (13 - 501) <7E81C78F-3540-39E3-A93F-00F5A4236E33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x925a2000 - 0x92638ffb com.apple.QD (3.12 - 403) <DA16A03D-A469-3CFA-861C-2E6DAD6FD30C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x92639000 - 0x92645ff7 com.apple.speech.synthesis.framework (7.0.13 - 7.0.13) <B63583E4-9C20-3753-ADEC-ED89D12AFC7A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x92646000 - 0x9288ffff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <C00F83DF-8329-3440-848A-4F22BEFEDD2A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x92891000 - 0x92891fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <CB58011E-CDE7-354A-85C4-B52BBA967688> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x929c8000 - 0x92d02fff com.apple.CFNetwork (866.2 - 866.2) <1599FEE7-9815-3A99-9DA7-41129901C163> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x92d17000 - 0x92d17fff com.apple.Carbon (158 - 158) <0EA582A4-1C80-31C2-AD69-9C8A1B3D1C49> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x92d18000 - 0x92d21ff3 com.apple.audio.SoundManager (4.2 - 4.2) <AF67D750-8E63-3D63-8DE0-A0983652CB43> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x92d22000 - 0x92d26fff com.apple.CommonPanels (1.2.6 - 98) <D345A57A-18A0-33C1-8715-AE5F99A3B061> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x92d27000 - 0x930bbff3 com.apple.HIToolbox (2.1.1 - 902.1) <4337EEB7-471E-3304-B4B4-5FAD4331D51E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x930bc000 - 0x93110ffb com.apple.htmlrendering (77 - 1.1.4) <039F5A8F-F3CF-3625-85DE-5F3C05F62096> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x93111000 - 0x93114fff com.apple.help (1.3.8 - 64) <3C12F8F1-7DDE-36DF-8E6F-C52B30F84037> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x93115000 - 0x9311affb com.apple.ImageCapture (9.0 - 9.0) <728D4034-63C1-3F36-A937-37CA08244873> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x9311b000 - 0x931b5ffb com.apple.ink.framework (10.9 - 220) <81B0C4AF-D0DD-3B03-A681-E970576BFF63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x931b6000 - 0x931f0fff com.apple.NavigationServices (3.8 - 227) <C709B074-4C1C-30B2-8DD4-50844A239CA7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x931f1000 - 0x9320cffb com.apple.openscripting (1.7 - 172) <4E52D20B-4D68-3644-9E18-B707B10F01C1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x9320d000 - 0x93212fff com.apple.print.framework.Print (12 - 267) <3B77909C-E520-3DB6-B042-AACAADA1BF49> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x93213000 - 0x93215fff com.apple.securityhi (9.0 - 55006) <8A5123DD-80EE-31DF-92ED-00B096A62FA8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x93216000 - 0x9321cfff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <960673C3-9213-3C52-B6C6-7582E5498561> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x9321d000 - 0x9321dfff com.apple.Cocoa (6.11 - 22) <B2D444E1-D80E-32FD-A855-AA23E7FFCE31> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x9322a000 - 0x932e8ffb com.apple.ColorSync (4.13.0 - 533) <5B52F0DB-8473-336A-B85C-3E25AFCD9E0E> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x932e9000 - 0x93384fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F1D891DB-006A-31CE-A7FE-39FF9F0E0EFC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x933e1000 - 0x933e6fff com.apple.CoreBluetooth (1.0 - 1) <EB931589-15BA-3729-AA50-23DBED97EE1B> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x933e7000 - 0x936c1ff7 com.apple.CoreData (120 - 836) <FB056531-7F63-35D9-9A2F-CCE42F6EB3EF> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x936c2000 - 0x936c8ff3 com.apple.CoreDisplay (1.0 - 68) <CDE9194C-20BF-3B1A-BAE5-56ED9BFCD0EF> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x936c9000 - 0x93b4bfff com.apple.CoreFoundation (6.9 - 1436.1) <8D3E8DB2-2980-3A82-9502-78E3757923B8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x93b4d000 - 0x9417affb com.apple.CoreGraphics (2.0 - 1113) <7DFF4A35-6251-3C64-ACE6-F9F9B6C79846> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x9417c000 - 0x943e5ff3 com.apple.CoreImage (13.0.0 - 555) <ED840C14-9817-3241-915F-B8E855AA3945> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x944a0000 - 0x9460bff3 com.apple.CoreMedia (1.0 - 2042.4.4) <11CF87A6-C901-3D82-84B7-E5EB30D3DE3C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x9460c000 - 0x9465eff7 com.apple.CoreMediaIO (803.0 - 4970) <74FD1D35-521F-3BD1-9D3A-871C42F9ADC5> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO 0x9465f000 - 0x9465ffff com.apple.CoreServices (817.2 - 817.2) <9BC73B79-1241-3D7E-94E7-4A83CCB55E20> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x94660000 - 0x946d2fff com.apple.AE (733 - 733) <23642F65-57FD-3067-BB23-1CBEA3156214> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x946d3000 - 0x949b0ff7 com.apple.CoreServices.CarbonCore (1178 - 1178) <2D3685AE-A6A9-31D7-9447-24AA6509BCFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x949b1000 - 0x949e5ff3 com.apple.DictionaryServices (1.2 - 282) <05A09DA1-C25A-3D10-ACC7-578C9FBBA0AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x949e6000 - 0x949eefff com.apple.CoreServices.FSEvents (1237 - 1237) <91A1DB35-F252-33DD-B1B4-6B4F2ADDE1B6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x949ef000 - 0x94b4cff7 com.apple.LaunchServices (817.2 - 817.2) <630B1905-1A8F-3146-B2FF-30604C024885> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x94b4d000 - 0x94bf9fff com.apple.Metadata (10.7.0 - 1168.1) <2560EC03-079B-3758-AAB8-6572677C53F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x94bfa000 - 0x94c58ffb com.apple.CoreServices.OSServices (817.2 - 817.2) <DD7164A4-9AB2-350A-8534-02785203641D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x94c59000 - 0x94ccaff3 com.apple.SearchKit (1.4.0 - 1.4.0) <2F4A3649-7F38-3D08-B7D0-1AB1662F98E7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x94ccb000 - 0x94cedfff com.apple.coreservices.SharedFileList (66 - 66) <FBB033FF-0485-3DEE-98B4-BF591D462049> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x94cee000 - 0x94e36ff3 com.apple.CoreText (352.0 - 571) <F1D90873-5882-34D6-A1A8-F7F3660F5108> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x94e37000 - 0x94e71ffb com.apple.CoreVideo (1.8 - 276.0) <F1EF6F73-FEB6-3170-90B3-EC788FF29DF5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x94e72000 - 0x94ef8ff3 com.apple.framework.CoreWLAN (13.0 - 1331) <F4111FED-84EB-314E-8A92-A7636921C14B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x9505c000 - 0x95066fff com.apple.DirectoryService.Framework (10.13 - 205) <7983B913-B769-31C7-9BD2-0380344F403F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService 0x9514c000 - 0x95155ff7 com.apple.DiskArbitration (2.7 - 2.7) <BD6B9525-AA50-3FD5-8FE1-F21E887116A9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x95166000 - 0x954d8ff3 com.apple.Foundation (6.9 - 1436) <FC8D457D-F181-3D5E-AF5B-45F4E13B9C59> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x95519000 - 0x95548fff com.apple.GSS (4.0 - 2.0) <42644DEE-8889-3481-8A05-10CC8CFF29E6> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x95574000 - 0x95689ffb com.apple.Bluetooth (6.0.0 - 6.0.0d51) <6102DADD-4765-3A2D-A601-E0C21238065D> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x956ef000 - 0x9578fffb com.apple.framework.IOKit (2.0.2 - 1437) <A445AD62-454F-399E-AD9E-EE5EF95E0669> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x95791000 - 0x95797fff com.apple.IOSurface (204 - 204) <5800E65F-D0FC-3D78-AF5D-EDAF533D97B6> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x95798000 - 0x957e9ffb com.apple.ImageCaptureCore (7.0 - 7.0) <1953C0BD-6623-3605-B1BA-9CB39FB8D842> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore 0x957ea000 - 0x95964ff3 com.apple.ImageIO.framework (3.3.0 - 1679) <C2765CF8-3D9B-3FF6-9EFD-67549A62B6FB> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x95965000 - 0x95969ffb libGIF.dylib (1679) <FB6BD82A-FA9D-375B-BCA9-F9F3B21AA974> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x9596a000 - 0x95a5bfff libJP2.dylib (1679) <BBB17A3D-49E5-397E-9B12-E762DE53E189> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x95a5c000 - 0x95a7eff7 libJPEG.dylib (1679) <15BE7257-EEB1-397D-8142-2D34D52BE22E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x95a7f000 - 0x95aa5ff3 libPng.dylib (1679) <42A5337B-1996-3D19-B2DA-99AB2B596D6F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x95aa6000 - 0x95aa8ffb libRadiance.dylib (1679) <F675DA4F-420B-34DB-AF16-3B6F47551DB9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x95aa9000 - 0x95af3fff libTIFF.dylib (1679) <B535B668-61EB-3869-8DFC-36AF5D21297D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x95ba0000 - 0x963d5ffb com.apple.JavaScriptCore (13604 - 13604.1.28.2) <B047A301-F603-390B-8B4C-9892D3A2D498> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x963ed000 - 0x96405fff com.apple.Kerberos (3.0 - 1) <2398EBCA-4A21-30BC-A275-5D2239C627DF> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x96406000 - 0x96439ffb com.apple.LDAPFramework (2.4.28 - 194.5) <D968D3B6-F5B2-31A1-923A-978F0A94025D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP 0x9645d000 - 0x96465ff3 com.apple.MediaAccessibility (1.0 - 113) <50ABB21F-174C-3755-B98A-1E76B86A5C1A> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility 0x96466000 - 0x96de2ff3 com.apple.MediaToolbox (1.0 - 2042.4.4) <4D10BACA-4330-3EE8-845C-EB4F0DEA5496> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x96de4000 - 0x96e5afff com.apple.Metal (120.11 - 120.11) <90A24B95-4334-3525-A44B-F2F2155802A0> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x96e5c000 - 0x96e68fff com.apple.NetFS (6.0 - 4.0) <CCB708DC-4C27-347E-A1AA-EC5FB9763749> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x99ba7000 - 0x99bf2fff com.apple.opencl (2.8.10 - 2.8.10) <496381CE-6B48-3DDA-BCCE-0400DB409279> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x99bf3000 - 0x99c0ffff com.apple.CFOpenDirectory (10.13 - 205) <C4113A8F-4686-3E7F-B748-C19016D29663> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x99c10000 - 0x99c1bfff com.apple.OpenDirectory (10.13 - 205) <FC3CB0F0-DD51-311F-9D8B-32C7BBA50BA2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x9ae25000 - 0x9ae26fff libCVMSPluginSupport.dylib (15.0.42) <CCEDBF4D-95F0-3A94-8AFD-8A57E3119342> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x9ae27000 - 0x9ae2afff libCoreFSCache.dylib (160.7) <FD012990-278A-3AC5-BAAB-2CD37CD3C098> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x9ae2b000 - 0x9ae2ffff libCoreVMClient.dylib (160.7) <DCCBB2D4-0BE3-3317-A2C4-4B35EE91933C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x9ae30000 - 0x9ae39ff7 libGFXShared.dylib (15.0.42) <77514202-6094-3852-BC1F-8A66B34B2EA9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x9ae3a000 - 0x9ae46fff libGL.dylib (15.0.42) <6E55F628-733F-3809-87EF-1D2DF5E1734F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x9ae47000 - 0x9ae82ffb libGLImage.dylib (15.0.42) <C4BB1600-91A9-3222-AE0A-671FEB1AA349> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x9affc000 - 0x9b03eff7 libGLU.dylib (15.0.42) <AF558A21-7845-32FE-937C-CF8BA8C6FCB9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x9b9e5000 - 0x9b9f3fff com.apple.opengl (15.0.42 - 15.0.42) <ADA66F59-7896-377F-9CBB-F06C0714D77E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x9bcc9000 - 0x9be1affb com.apple.QTKit (7.7.3 - 3013) <4B9C3CC9-348A-34C7-BE3E-51BEB5DF2676> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x9be1b000 - 0x9c065ff7 com.apple.imageKit (3.0 - 1036) <5AF58EAA-046C-387E-805A-78678B75D6AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit 0x9c066000 - 0x9c13efff com.apple.PDFKit (1.0 - 649) <874BB3AD-6E45-3767-8F61-B069A4D9C249> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit 0x9c13f000 - 0x9c651ff3 com.apple.QuartzComposer (5.1 - 362) <1911CED4-20A5-38EE-8277-0B06EB249259> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer 0x9c652000 - 0x9c673ff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <2CB99459-CDD0-3DFC-962F-32E12979AD49> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters 0x9c674000 - 0x9c757ff7 com.apple.QuickLookUIFramework (5.0 - 737) <DC69FACB-8C8D-346B-B466-0F96D3FE7F23> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI 0x9c758000 - 0x9c758fff com.apple.quartzframework (1.5 - 21) <AFDC52CF-3DDF-3100-9D60-9DEFAE551CD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz 0x9c759000 - 0x9c968ffb com.apple.QuartzCore (1.11 - 555) <E6D5192A-0360-38AC-864A-56F46BA391F3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x9c969000 - 0x9c9bdff7 com.apple.QuickLookFramework (5.0 - 737) <1C66BD46-2961-3954-8AAA-7E1CC57AE7DE> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook 0x9c9be000 - 0x9cc16fff com.apple.QuickTime (7.7.3 - 3013) <DE59CD56-1782-3F0A-B2EA-52100FDE6506> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x9cdc4000 - 0x9cdc5fff com.apple.SafariServices.framework (13604 - 13604.1.28.2) <6BE10B0F-2A31-3F8D-8A01-CEEBD7A97942> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices 0x9cdfe000 - 0x9d122ff3 com.apple.security (7.0 - 58267.0.0.0.1) <F32DAEC1-9831-3604-AC69-D40D337A4EB4> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x9d123000 - 0x9d1a9ff3 com.apple.securityfoundation (6.0 - 55185) <421496B2-7410-377C-982C-C627AA290F1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x9d1aa000 - 0x9d1d1ff7 com.apple.securityinterface (10.0 - 55109) <7CA06334-AE9B-395F-AD7B-A84D74894C18> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface 0x9d1d2000 - 0x9d1d6fff com.apple.xpc.ServiceManagement (1.0 - 1) <36260315-C702-3C71-A33C-362AED807EFA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x9d2ff000 - 0x9d36fffb com.apple.SystemConfiguration (1.17 - 1.17) <5CFC4503-A4E3-357F-82DF-30A461C25C2E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x9d519000 - 0x9d8ecffb com.apple.VideoToolbox (1.0 - 2042.4.4) <2392386F-AA24-370F-B739-C6F85FD0966C> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x9d8ed000 - 0x9eca0ff3 com.apple.WebCore (13604 - 13604.1.28.2) <A6B331BE-C5F7-358F-A623-13527D5E1B78> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x9eca1000 - 0x9ee36ffb com.apple.WebKitLegacy (13604 - 13604.1.28.2) <86D1D4AA-3A9E-3F2D-BC1E-73C3CE9E2D95> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy 0x9f181000 - 0x9f207ffb com.apple.APFS (1.0 - 1) <A9CF769A-81E6-322A-945A-93B9D0C1100E> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS 0x9f7f4000 - 0x9f81fff3 com.apple.framework.Apple80211 (13.0 - 1331) <755E0399-6BC1-369E-914C-A2508917755B> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x9f821000 - 0x9f82bfff com.apple.AppleFSCompression (96 - 1.0) <0A180311-CE9E-31D3-9EF4-A955E0F888E1> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x9f922000 - 0x9f95ffff com.apple.AppleJPEG (1.0 - 1) <1B864248-E14A-34CC-9876-8FE7084AD2E4> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x9f960000 - 0x9f97dff7 com.apple.aps.framework (4.0 - 4.0) <8C5D6FAC-AE3E-32E3-A90B-EF4FCCA7B062> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService 0x9f97e000 - 0x9f986fff com.apple.AppleSRP (5.0 - 1) <A257887E-7A02-39FF-8D6F-2E924C8C164C> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP 0x9fa55000 - 0x9fa58fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <B441BEB1-BBB4-3A0B-8742-90A2E24676F0> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x9fa59000 - 0x9faa8ffb com.apple.AppleVAFramework (5.0.37 - 5.0.37) <B114581B-E252-3A6A-B13C-A5AE3191CC17> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x9fab2000 - 0x9fab9fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <A22829FC-2C32-3A43-87FF-983927743A7A> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement 0x9faba000 - 0x9fb5cff7 com.apple.backup.framework (1.9 - 1.9) <4CA74009-5ACB-34B5-A54E-C78DC50A6ADB> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x9fbca000 - 0x9fbf7fff com.apple.CalendarAgentLink (8.0 - 250) <83C157EE-25A0-31F8-9D95-0178AA87B720> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink 0x9fc9e000 - 0x9fca7fff com.apple.CommonAuth (4.0 - 2.0) <428B5B8E-C6CF-39D3-A499-D9090814B770> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x9fcbb000 - 0x9fccefff com.apple.commonutilities (8.0 - 900) <E90496AF-10F4-3D7D-A6DF-1D5CB5FAB915> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities 0x9fcd4000 - 0x9fd2bffb com.apple.AddressBook.ContactsFoundation (8.0 - ???) <6E94E5BB-3D03-3FC7-9E98-A7296DB34CCB> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation 0x9fd2c000 - 0x9fd4cfff com.apple.contacts.ContactsPersistence (1.0 - 2318) <F8502E0F-5001-3EAF-9508-08FC636A3155> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence 0x9fd4d000 - 0xa0065fef com.apple.CoreAUC (249.0.0 - 249.0.0) <D73413FC-5546-348D-A966-E0DE6F301176> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC 0xa0066000 - 0xa0097fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <BE416D22-0CF3-33C5-A6BB-1D57ED6CF010> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD 0xa010c000 - 0xa0114fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8A39292C-6FB3-31F3-A064-CEA4F4B33B61> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon 0xa0115000 - 0xa0125ffb com.apple.CoreEmoji (1.0 - 66) <EBF27F98-512A-313F-A795-1ADE8F6788F0> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0xa02e3000 - 0xa02f9ff7 com.apple.CoreMediaAuthoring (2.2 - 956) <DF73D380-07BC-3815-B396-6223C24D03AF> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring 0xa03ac000 - 0xa043cff3 com.apple.CorePDF (4.0 - 414) <49F1ABE0-0DEB-3466-9D83-C3D08981BB61> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF 0xa043d000 - 0xa0444ff3 com.apple.CorePhoneNumbers (1.0 - 1) <A25F21CC-8CBC-3E47-BD7F-44DB848020DB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers 0xa0493000 - 0xa0529ff7 com.apple.CoreSymbolication (63072) <9AAAC50E-0540-3792-9961-2D1C326695A7> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0xa052a000 - 0xa064effb com.apple.coreui (2.1 - 482) <A43077E2-C347-37C0-9FF0-25B7E86A7622> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0xa064f000 - 0xa06e9ff7 com.apple.CoreUtils (5.2 - 520.52) <91345018-125F-3C0F-AB35-6E83D57D3E01> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0xa073a000 - 0xa0797ff3 com.apple.framework.CoreWiFi (13.0 - 1331) <723D279B-55D4-34D1-AC1C-806329FC6663> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi 0xa0798000 - 0xa07a8fff com.apple.CrashReporterSupport (10.13 - 1) <8EC7E20C-218C-3B92-BF04-ABC087BEFC30> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0xa0816000 - 0xa0823ff7 com.apple.framework.DFRFoundation (1.0 - 176) <EF3B1F68-3AF1-3137-BA08-51B0671A0A31> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation 0xa086f000 - 0xa08dfff3 com.apple.datadetectorscore (7.0 - 585) <2FF41A14-65FF-3610-8E55-E44A28BD14F8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0xa08e0000 - 0xa0920ff7 com.apple.DebugSymbols (141 - 141) <8E7861AC-E4A0-3CB9-96F1-E5972BB40341> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0xa0921000 - 0xa0a60fff com.apple.desktopservices (1.12 - 1.12) <9D13D4F5-2CCC-3EAC-A44B-892E49BF4709> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0xa0bea000 - 0xa0bf4fff com.apple.DisplayServicesFW (3.1 - 380) <1C549EFE-B724-3CAC-9FD7-804B32AC5675> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices 0xa0d27000 - 0xa1157ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <12A48D58-4D60-32C3-BCDA-9BA8DD3F8E54> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0xa3191000 - 0xa31b7ffb com.apple.GenerationalStorage (2.0 - 280) <0B3FA2AD-0ACA-3DB5-866A-5387B0758DF2> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0xa31cf000 - 0xa3a64ff7 com.apple.GeoServices (1.0 - 1332.20.6.28.2) <519E58E0-1528-3B41-82F6-7FB03C5076F5> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices 0xa3abf000 - 0xa3b32ff3 com.apple.Heimdal (4.0 - 2.0) <DA452632-DB70-3F4F-AEB5-609CBD773187> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0xa3ddf000 - 0xa3de5fff com.apple.IOAccelerator (367 - 367) <4BEBA488-F9F8-3554-ACEC-3FD568D58DC7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0xa3de6000 - 0xa3dfefff com.apple.IOPresentment (1.0 - 32.1) <72127F94-8698-3132-A963-374CA6ABE290> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0xa3e5b000 - 0xa3e7aff3 com.apple.IconServices (93 - 93) <95217786-8538-32E7-97F3-A82A7316A661> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0xa3e83000 - 0xa3e92fff com.apple.IntlPreferences (2.0 - 225) <56E1E8F4-2D0E-3C24-987B-DF00FB2CB575> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences 0xa3eb2000 - 0xa3fa3ff7 com.apple.LanguageModeling (1.0 - 155) <BCE7971D-36D7-3721-9778-F346052B55B7> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0xa3fa4000 - 0xa3fe8ff3 com.apple.Lexicon-framework (1.0 - 29) <1B028151-7FF4-3DE0-812F-8F6E455285B1> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon 0xa439e000 - 0xa43c6ffb com.apple.MultitouchSupport.framework (436 - 436) <10DC8594-0150-36D0-8B23-DC4C1B3A6774> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0xa44e5000 - 0xa44effff com.apple.NetAuth (6.2 - 6.2) <F2438793-08C3-3456-95EA-3FD073EE784A> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0xa4597000 - 0xa45d3fff com.apple.PerformanceAnalysis (1.178 - 178) <FD58CB75-6FE4-34D9-814E-6C4B13A58E10> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0xa45fe000 - 0xa45fefff com.apple.PhoneNumbers (1.0 - 1) <AC5EEC55-4DED-367F-8C40-7B616F5A2174> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers 0xa4670000 - 0xa468cff7 com.apple.ProtocolBuffer (1 - 259) <28247103-F21B-3684-B495-E326C5F0A1D7> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0xa4763000 - 0xa4776fff com.apple.QuickLookThumbnailing (1.0 - 1) <CE2AA2B8-5F82-31C0-A47C-390484A2C4EE> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing 0xa4777000 - 0xa4799fff com.apple.RemoteViewServices (2.0 - 125) <F0D8695C-9701-3D8D-9B2D-EB69FD580349> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0xa484f000 - 0xa487bfff com.apple.Sharing (886 - 886) <7CB7F309-27A3-3F99-BE90-0597A59D784E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0xa489a000 - 0xa489bfff com.apple.performance.SignpostNotification (1.0 - 1) <7DA065F9-1D86-383E-BB95-946BCC686215> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification 0xa489c000 - 0xa4921ff3 com.apple.SkyLight (1.600.0 - 293) <AC5CEFDB-5CD3-3D22-8490-AFEA16101B0D> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0xa4950000 - 0xa495dffb com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <1444E572-4A81-3DB4-A365-41FA3C00AA6F> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0xa4c21000 - 0xa4ca1ffb com.apple.Symbolication (63071.1) <DA252CAA-46CF-321E-9FAE-CCB827EFE6BA> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0xa4cf2000 - 0xa4cf9fff com.apple.TCC (1.0 - 1) <A722E262-7FB4-31E0-8534-6AFBA91B5ABD> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0xa4cfa000 - 0xa4d11ff3 com.apple.TextureIO (3.4 - 3.4) <9051EC58-9D06-3A79-A2FD-07FE3ECB5E7D> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0xa4d33000 - 0xa4d34fff com.apple.TrustEvaluationAgent (2.0 - 31) <185BD5A9-5A2D-3317-B7FE-9B67F14C4D2C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0xa4d35000 - 0xa4ebefff com.apple.UIFoundation (1.0 - 534) <0968B043-55FD-3191-B89B-1727F3C731AE> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0xa5254000 - 0xa5317ff7 com.apple.ViewBridge (332 - 332) <0DBC5ED9-8EE2-3987-B58B-94349A0BC7F5> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0xa548a000 - 0xa548cfff com.apple.loginsupport (1.0 - 1) <BBD4EB7D-8FE6-3078-A925-29337C07EE3B> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0xa54b0000 - 0xa54ddffb com.apple.contacts.vCard (1.0 - 2318) <3EA927D6-EF26-3EA0-9822-3301C9C93213> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard 0xa5565000 - 0xa559cff3 libCRFSuite.dylib (41) <4601C64B-B599-3206-A7B6-C91404BD7D91> /usr/lib/libCRFSuite.dylib 0xa559d000 - 0xa55a7ffb libChineseTokenizer.dylib (28) <569F6E83-32A0-3E58-8DE7-60D2C1EE99BD> /usr/lib/libChineseTokenizer.dylib 0xa5643000 - 0xa5644fff libDiagnosticMessagesClient.dylib (103) <02584E6D-A85D-3C65-9855-C3B03181A7F6> /usr/lib/libDiagnosticMessagesClient.dylib 0xa5676000 - 0xa5860ff7 libFosl_dynamic.dylib (17.6) <810CC13A-CD7B-3EAF-893E-CD8142F9718F> /usr/lib/libFosl_dynamic.dylib 0xa5868000 - 0xa5868fff libOpenScriptingUtil.dylib (172) <1F06BFCE-838F-303E-AC7F-0DF08C07F3FA> /usr/lib/libOpenScriptingUtil.dylib 0xa58b1000 - 0xa58b5fff libScreenReader.dylib (541) <23E15444-0A40-3281-8BB8-A41AD2461453> /usr/lib/libScreenReader.dylib 0xa58b6000 - 0xa58b7fff libSystem.B.dylib (1252) <521ADCA0-B208-307F-B6DF-DA3545E6715A> /usr/lib/libSystem.B.dylib 0xa58c6000 - 0xa58dbff7 libapple_nghttp2.dylib (1.20.3) <2840747B-C3E6-3E3A-9CD3-59CB06540532> /usr/lib/libapple_nghttp2.dylib 0xa58dc000 - 0xa5907fff libarchive.2.dylib (54) <00F5F49B-9332-3F4D-B9AA-F249655D7C35> /usr/lib/libarchive.2.dylib 0xa5908000 - 0xa5a57ffb libate.dylib (1.13.1) <E109CCBF-357D-3C87-9CE5-D53AE03609A2> /usr/lib/libate.dylib 0xa5a5b000 - 0xa5a5bff3 libauto.dylib (187) <CE2A78CC-670F-3E07-9539-822DCD2F6084> /usr/lib/libauto.dylib 0xa5a5c000 - 0xa5a6cfff libbsm.0.dylib (39) <440D12EA-6757-340F-9E40-CAF77A60DFB8> /usr/lib/libbsm.0.dylib 0xa5a6d000 - 0xa5a79ff7 libbz2.1.0.dylib (38) <77C24A36-BE84-3702-A786-935C597A0A86> /usr/lib/libbz2.1.0.dylib 0xa5a7a000 - 0xa5ad3ffb libc++.1.dylib (400.9) <AD612EEF-6CE3-315D-82C2-58248BE13431> /usr/lib/libc++.1.dylib 0xa5ad4000 - 0xa5af5fff libc++abi.dylib (400.7) <41323E53-C7EA-3E9A-BD30-38E82399F843> /usr/lib/libc++abi.dylib 0xa5af7000 - 0xa5b08ff7 libcmph.dylib (6) <EC7664F1-B5A1-37F4-B7DC-F6AC10587E35> /usr/lib/libcmph.dylib 0xa5b09000 - 0xa5b1cff7 libcompression.dylib (46) <68FF8566-6C92-3B29-9C61-8176EF1529EA> /usr/lib/libcompression.dylib 0xa5b1d000 - 0xa5b34ffb libcoretls.dylib (155) <A24271C7-E511-3884-851E-46D70579A55F> /usr/lib/libcoretls.dylib 0xa5b35000 - 0xa5b36fff libcoretls_cfhelpers.dylib (155) <4833FC6B-DE9B-3134-A680-B8D7790150BC> /usr/lib/libcoretls_cfhelpers.dylib 0xa5cb7000 - 0xa5e5efff libcrypto.35.dylib (22) <EE1BA2F7-F2F4-387B-8866-5B4A7023D29F> /usr/lib/libcrypto.35.dylib 0xa601e000 - 0xa6075fff libcups.2.dylib (460) <4914ECEE-BCDF-3B91-BA2A-33D17B1634DF> /usr/lib/libcups.2.dylib 0xa618a000 - 0xa618afff libenergytrace.dylib (16) <34FC43C7-D9B6-3C01-8B65-E49059D31279> /usr/lib/libenergytrace.dylib 0xa61be000 - 0xa61c2fff libheimdal-asn1.dylib (518) <CE784EBC-AB01-3EAD-B178-BC9D20BF63DE> /usr/lib/libheimdal-asn1.dylib 0xa61ee000 - 0xa62deff3 libiconv.2.dylib (51) <FE6D05A5-18DB-3FD8-A52F-B7BADB232C78> /usr/lib/libiconv.2.dylib 0xa62df000 - 0xa6501ffb libicucore.A.dylib (59110.0.1) <773DFD96-07DA-383C-9946-77CDCC32921F> /usr/lib/libicucore.A.dylib 0xa6549000 - 0xa654afff liblangid.dylib (128) <120FE992-47E4-3A73-A039-1B401F5696DC> /usr/lib/liblangid.dylib 0xa654b000 - 0xa6563ff7 liblzma.5.dylib (10) <8A5C9679-430A-3A19-AF68-9D21BAC442C7> /usr/lib/liblzma.5.dylib 0xa6564000 - 0xa6579fff libmarisa.dylib (9) <805453EE-B829-3DA5-8DF3-5132D03D5B74> /usr/lib/libmarisa.dylib 0xa662e000 - 0xa6858ffb libmecabra.dylib (773) <BCDA52D6-5A44-3EED-9F42-04B0A7D97DF3> /usr/lib/libmecabra.dylib 0xa6a1f000 - 0xa6aedff7 libnetwork.dylib (1218) <0972906C-D3A8-300D-925F-C52383F191C2> /usr/lib/libnetwork.dylib 0xa6aee000 - 0xa6ece14b libobjc.A.dylib (721) <1D5E3EB4-124F-3A17-BAC5-3D9FB358395C> /usr/lib/libobjc.A.dylib 0xa6ed2000 - 0xa6ed5fff libpam.2.dylib (22) <7106F43C-84DD-3F26-905A-B52780AFEB3E> /usr/lib/libpam.2.dylib 0xa6ed8000 - 0xa6f09fff libpcap.A.dylib (77) <F97781A1-5A84-351B-8169-C92D2558DD4D> /usr/lib/libpcap.A.dylib 0xa6f47000 - 0xa6f62ffb libresolv.9.dylib (65) <65A43F5B-CF88-3948-AE5C-D7CA02D814A1> /usr/lib/libresolv.9.dylib 0xa6f9a000 - 0xa6fabff7 libsasl2.2.dylib (211) <31BFF961-171E-331A-BA3A-F79E69C6E63B> /usr/lib/libsasl2.2.dylib 0xa6fac000 - 0xa7136ff7 libsqlite3.dylib (269.1) <98A079DD-A661-34A8-B57F-97BB56938C7E> /usr/lib/libsqlite3.dylib 0xa72da000 - 0xa7314fff libusrtcp.dylib (1218) <C7BFEDAF-D8DD-3A43-BEAE-F4F27FACD076> /usr/lib/libusrtcp.dylib 0xa7315000 - 0xa7318fff libutil.dylib (51) <C041EF3C-8E30-3F43-BCE2-7DA3E3673A8A> /usr/lib/libutil.dylib 0xa7319000 - 0xa7327ff7 libxar.1.dylib (400) <2825FAB8-86FF-3457-B233-F433E595C01C> /usr/lib/libxar.1.dylib 0xa7328000 - 0xa7406ff7 libxml2.2.dylib (31.6) <7DAA0E8D-C153-3034-AF46-97523DDB3651> /usr/lib/libxml2.2.dylib 0xa7407000 - 0xa742fff3 libxslt.1.dylib (15.10) <1A3DC7B8-7C92-3D73-BF82-D60E64BC3DF0> /usr/lib/libxslt.1.dylib 0xa7430000 - 0xa743eff7 libz.1.dylib (68) <1D5DFBBC-7F7F-332F-B41B-B806F870991D> /usr/lib/libz.1.dylib 0xa7477000 - 0xa747bfff libcache.dylib (79) <0D8C7D98-AA10-3FEA-AF7E-4B211EC8E373> /usr/lib/system/libcache.dylib 0xa747c000 - 0xa7486fff libcommonCrypto.dylib (60117) <C069343B-EBEC-314F-929E-C8C2B9A0C7DD> /usr/lib/system/libcommonCrypto.dylib 0xa7487000 - 0xa748cfff libcompiler_rt.dylib (62) <4CC1F6B4-7FC7-3D74-9AD1-4D7396C42406> /usr/lib/system/libcompiler_rt.dylib 0xa748d000 - 0xa7496ff7 libcopyfile.dylib (146) <4924171F-9AF3-3214-B345-F00A25FBDBC4> /usr/lib/system/libcopyfile.dylib 0xa7497000 - 0xa74fefff libcorecrypto.dylib (557) <C8F0E8ED-7A5C-3C0C-AFA8-90A683592A32> /usr/lib/system/libcorecrypto.dylib 0xa7568000 - 0xa75a2ffb libdispatch.dylib (904) <B6064116-68E1-3B0B-BAA8-D59B9973C46A> /usr/lib/system/libdispatch.dylib 0xa75a3000 - 0xa75befff libdyld.dylib (514) <2F2B0486-2631-3209-B0AC-FC1E2A87E39F> /usr/lib/system/libdyld.dylib 0xa75bf000 - 0xa75bffff libkeymgr.dylib (28) <5BD17CF9-A050-3BCF-BEC1-950C56E5BD4B> /usr/lib/system/libkeymgr.dylib 0xa75c0000 - 0xa75ccff7 libkxld.dylib (4532.0.0.0.1) <6071D59A-ED98-372E-B7FE-1B910D300485> /usr/lib/system/libkxld.dylib 0xa75cd000 - 0xa75cdfff liblaunch.dylib (1194) <E8BE0520-2495-3EC6-9CAF-44E5FB3C2910> /usr/lib/system/liblaunch.dylib 0xa75ce000 - 0xa75d3fff libmacho.dylib (900) <8AB8C56A-6F93-3D5B-8672-FD386A5A3B79> /usr/lib/system/libmacho.dylib 0xa75d4000 - 0xa75d6fff libquarantine.dylib (86) <8435F6B3-AA1E-39E8-AABE-DCCF50ACE70D> /usr/lib/system/libquarantine.dylib 0xa75d7000 - 0xa75d8fff libremovefile.dylib (45) <C3130308-FDC3-3ED0-9D8E-A36786D9476C> /usr/lib/system/libremovefile.dylib 0xa75d9000 - 0xa75f0fff libsystem_asl.dylib (356) <2BA228DE-EBCC-3E4C-A52F-9453B37C7B4B> /usr/lib/system/libsystem_asl.dylib 0xa75f1000 - 0xa75f1fff libsystem_blocks.dylib (67) <CB0A6740-D734-34F6-9F85-E387D1CD5053> /usr/lib/system/libsystem_blocks.dylib 0xa75f2000 - 0xa767efff libsystem_c.dylib (1237) <DAB86DA4-2A57-37AA-9E9C-12149BF29EDF> /usr/lib/system/libsystem_c.dylib 0xa767f000 - 0xa7682fff libsystem_configuration.dylib (958) <9D7489A8-513B-3DF0-8131-17A821ECFA95> /usr/lib/system/libsystem_configuration.dylib 0xa7683000 - 0xa7686fff libsystem_coreservices.dylib (50) <0E752A26-589E-3B64-97D4-C8F6A7A4B602> /usr/lib/system/libsystem_coreservices.dylib 0xa7687000 - 0xa7688fff libsystem_darwin.dylib (1237) <E666FAE8-27B2-3A7B-9017-E0246BD450BB> /usr/lib/system/libsystem_darwin.dylib 0xa7689000 - 0xa768fff3 libsystem_dnssd.dylib (877) <577CFF19-F6B8-3911-8BE4-F694DB2AD9B1> /usr/lib/system/libsystem_dnssd.dylib 0xa7690000 - 0xa76dfffb libsystem_info.dylib (517) <3359AB82-F362-3E48-A4AB-CEB4FB43BE5C> /usr/lib/system/libsystem_info.dylib 0xa76e0000 - 0xa7703ff3 libsystem_kernel.dylib (4532.0.0.0.1) <AC184534-336D-30C6-B01B-12ED70EDC909> /usr/lib/system/libsystem_kernel.dylib 0xa7704000 - 0xa7753fdb libsystem_m.dylib (3145) <B90E5226-A444-3EC6-B678-DBC830AB58FA> /usr/lib/system/libsystem_m.dylib 0xa7754000 - 0xa776efff libsystem_malloc.dylib (137) <3998344C-9752-3162-94A1-E46E18B745B9> /usr/lib/system/libsystem_malloc.dylib 0xa776f000 - 0xa780bfff libsystem_network.dylib (1218) <1334B776-54C5-3706-A04C-06C40F0506FB> /usr/lib/system/libsystem_network.dylib 0xa780c000 - 0xa7816fff libsystem_networkextension.dylib (754) <73DADCBA-AE09-3120-850D-F50CCA642660> /usr/lib/system/libsystem_networkextension.dylib 0xa7817000 - 0xa781fff3 libsystem_notify.dylib (172) <A8C495D1-0598-349A-A3E1-77C2966762D4> /usr/lib/system/libsystem_notify.dylib 0xa7820000 - 0xa7826ff3 libsystem_platform.dylib (159) <5DE71B30-BE7E-33E1-8969-2BA1FB66851D> /usr/lib/system/libsystem_platform.dylib 0xa7827000 - 0xa7831ff7 libsystem_pthread.dylib (294) <2C315B3C-7CE1-3BD4-B8E8-AD7A4FED260D> /usr/lib/system/libsystem_pthread.dylib 0xa7832000 - 0xa7835ffb libsystem_sandbox.dylib (756) <4B72CBFC-FD73-34BB-A264-972245207E98> /usr/lib/system/libsystem_sandbox.dylib 0xa7836000 - 0xa7838fff libsystem_secinit.dylib (29) <C12E47FA-3CB2-35E4-9423-421F5BC0AF92> /usr/lib/system/libsystem_secinit.dylib 0xa7839000 - 0xa7841ff7 libsystem_symptoms.dylib (808) <E4178EEA-505A-3069-9D93-B08182F9BCAC> /usr/lib/system/libsystem_symptoms.dylib 0xa7842000 - 0xa7854fff libsystem_trace.dylib (815.0.0.1.1) <68653ADC-DAEB-3C92-BED6-30E4810FF88E> /usr/lib/system/libsystem_trace.dylib 0xa7856000 - 0xa785cfff libunwind.dylib (35.3) <BA65B06D-78FC-354C-AE36-8B0FB5F1193A> /usr/lib/system/libunwind.dylib 0xa785d000 - 0xa7885ff7 libxpc.dylib (1194) <D15A460B-9096-3FC6-ADFD-8574F36C6B38> /usr/lib/system/libxpc.dylib 0xba300000 - 0xba301fff libCyrillicConverter.dylib (69) <46896376-1B6F-33FA-9F0B-E4C1E72BDDF2> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 1096 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=293.7M resident=0K(0%) swapped_out_or_unallocated=293.7M(100%) Writable regions: Total=65.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=65.1M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Activity Tracing 256K 2 Kernel Alloc Once 8K 2 MALLOC 38.2M 20 MALLOC guard page 48K 13 Stack 12.4M 12 Stack Guard 56.1M 12 VM_ALLOCATE 14.3M 14 __DATA 12.6M 254 __FONT_DATA 4K 2 __LINKEDIT 83.4M 9 __OBJC 6008K 110 __TEXT 210.3M 260 __UNICODE 556K 2 mapped file 238.4M 210 shared memory 64K 8 =========== ======= ======= TOTAL 672.6M 915 Model: MacBookAir7,2, BootROM MBA71.0167.B01, 2 processors, Intel Core i5, 1,6 GHz, 8 GB, SMC 2.27f2 Graphics: Intel HD Graphics 6000, Intel HD Graphics 6000, Built-In Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54424C41522D4E5444 Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54424C41522D4E5444 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.77.33.0.1a1) Bluetooth: Version 6.0.0d51, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Serial ATA Device: APPLE SSD SM0256G, 251 GB USB Device: USB 3.0 Bus USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller Thunderbolt Bus: MacBook Air, Apple Inc., 27.2 Expand Edited July 11, 2017 by GamulinAO Link to comment Share on other sites More sharing options...
znapr Posted July 11, 2017 Report Share Posted July 11, 2017 (edited) On 7/11/2017 at 7:15 AM, GamulinAO said: Try to run Escribe suite on latest MacOs High Sierra and have this error. Expand Same problem here. Edited July 11, 2017 by znapr Link to comment Share on other sites More sharing options...
Lowbytes Posted July 12, 2017 Report Share Posted July 12, 2017 But we still have users running Escribe MAC on High Sierra................ Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 @ndb: I found what I believe to be the root cause of the issue you're having with it failing to fire. We are testing it now. @peraspera: You can exit the program by clicking the red X. I'll see what I can do, though, as it strikes me that's how folks quit programs on Windows, not Mac. @GamulinAO, @znapr: Could you try going to Applications in Finder, right clicking, selecting Show Package Contents, and let me know what error you get from running Contents/MacOS/RunProgram? The error message from that will tell me more definitively what the problem is. Thanks! Link to comment Share on other sites More sharing options...
GamulinAO Posted July 12, 2017 Report Share Posted July 12, 2017 On 7/12/2017 at 10:33 AM, James said: @ndb: I found what I believe to be the root cause of the issue you're having with it failing to fire. We are testing it now. @peraspera: You can exit the program by clicking the red X. I'll see what I can do, though, as it strikes me that's how folks quit programs on Windows, not Mac. @GamulinAO, @znapr: Could you try going to Applications in Finder, right clicking, selecting Show Package Contents, and let me know what error you get from running Contents/MacOS/RunProgram? The error message from that will tell me more definitively what the problem is. Thanks! Expand I have this message Last login: Tue Jul 11 10:12:14 on ttys000 MacBook-Air:~ arturgamulin$ /Applications/EScribe\ Suite.app/Contents/MacOS/RunProgram ; exit; 2017-07-12 16:09:41.678 mono-sgen32[2434:193049] ### Failed to Soft Linked: /System/Library/Frameworks/Contacts.framework/Contacts Stacktrace: at <unknown> <0xffffffff> at (wrapper managed-to-native) MonoMac.ObjCRuntime.Dlfcn.dlopen (string,int) <0x00012> at MonoMac.Foundation.NSObject..cctor () [0x0008e] in <0f3e0340a0da4554a42288a16e768e3c>:0 at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) [0x0001e] in <3fa441acb6894d4aa42ab4b0403fb297>:0 at <unknown> <0xffffffff> at (wrapper managed-to-native) System.Runtime.CompilerServices.RuntimeHelpers.RunClassConstructor (intptr) <0x00012> at System.Runtime.CompilerServices.RuntimeHelpers.RunClassConstructor (System.RuntimeTypeHandle) [0x0002a] in <3fa441acb6894d4aa42ab4b0403fb297>:0 at MonoMac.AppKit.NSApplication..cctor () [0x0053e] in <0f3e0340a0da4554a42288a16e768e3c>:0 at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) [0x0001e] in <3fa441acb6894d4aa42ab4b0403fb297>:0 at <unknown> <0xffffffff> at N.ob.NJ () [0x00042] in <24abdc25f8f14553a2cdf459b57817f6>:0 at h.Vw.nn () [0x00017] in <b904e73d288a482e8cdab1292168c3cc>:0 at e.Wp.Vy () [0x0000f] in <c9166dfc50154e6f8aa718fb872b8baa>:0 at e.Wp.Vu () [0x0002c] in <c9166dfc50154e6f8aa718fb872b8baa>:0 at e.eC.a (string[]) [0x00025] in <42d2c994112d41bea8324a9dd43e16ca>:0 at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) [0x0004e] in <42d2c994112d41bea8324a9dd43e16ca>:0 Native stacktrace: Debug info from gdb: xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun ================================================================= Got a SIGSEGV while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= Abort trap: 6 logout Saving session... ...copying shared history... ...saving history...truncating history files... ...completed. Deleting expired sessions...none found. [Процесс завершен] Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 Mm. OS X High Sierra b3 evidently breaks all 32-bit MonoMac applications: https://bugzilla.xamarin.com/show_bug.cgi?id=58110 Hopefully they'll fix the bug before release. On the plus side, I don't use Core Location at all in EScribe, so for now I'll work around it by changing the MonoMac binding. Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 I've posted up a version that should be compatible with OS X High Sierra b3. @ndb, let me know if it fixes your firing problem, by the way. Thanks! Link to comment Share on other sites More sharing options...
znapr Posted July 12, 2017 Report Share Posted July 12, 2017 The new version fixes it James. Thank you very much! Link to comment Share on other sites More sharing options...
ndb Posted July 12, 2017 Report Share Posted July 12, 2017 On 7/12/2017 at 8:33 PM, James said: I've posted up a version that should be compatible with OS X High Sierra b3. @ndb, let me know if it fixes your firing problem, by the way. Thanks! Expand Hi @James, just tried and unfortunately nothing changed wrt the immediate temp protect problem. Neither on the Therion nor on the vapedroid. I can't use eitherof them unless I go through the wattage profile first. I've uploaded a video showing the behavior on the Therion, the vapedroid does exactly the same with a different atomizer and a different (higher ohms, ~1.3) build. Please have a look if you can: (By the way, my room temp is currently ~84F, which is what I've forced into the cold ohm settings, while the board reports 91F) Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 Could you try resampling your Cold Ohms? Link to comment Share on other sites More sharing options...
ndb Posted July 12, 2017 Report Share Posted July 12, 2017 (edited) On 7/12/2017 at 10:16 PM, James said: Could you try resampling your Cold Ohms? Expand Well, I had just resampled (to the 0.614ohm seen in the video) from escribe right after applying the service pack and before shooting the video. In any case, even if I had just done those two test fires, I resampled and to my surprise I got an even lower 0.609ohm. The good news is that it now seems to be firing again without temp protection, the bad news is that it seems really like a misread cold ohm value, since I now have an anemic vape and had to crank temperature up to 480F.. Note that this atomizer reads ~0.623 on other DNAs. EDIT: right after posting this and trying to have a vape, I got another couple of temp protects on first fire (and it hadn't even got locked in the meantime), but this time it started firing again at the 3rd attempt without having to go through watts... Edited July 12, 2017 by ndb Add additional info Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 Hmm. Does Atomizer Analyzer consistently say 0.609? Also, is it a commercial atomizer? If so I'll order one for testing. What kind of resistances are you seeing while firing? Link to comment Share on other sites More sharing options...
ndb Posted July 12, 2017 Report Share Posted July 12, 2017 (edited) Well, I've now vaped it another 3 or 4 times, so it's not at base temperature for sure, but atomizer analyzer is fluctuating btw 0.616 and 0.621. That particular atomizer is a Squape X-dream, so yes, it is commercial, but keep in mind I'm having the same experience with another completely different commercial atom (a serpent SMM) on the vapedroid, where I already resampled another three times and still getting temp protect. The only difference on the vapedroid/serpent combo the ohm reading didn't get too low. I'm feeling a bit lost... EDIT: Sorry, I forgot to mention that on the therion atomizer analyzer shows a resistance up to 0.704 while vaping with temperature set to 420F EDIT2: Looking at live res with AA is not the right thing to do, here's a screenshot of device monitor for the therion/squape, after resampling again, this time @ 0.619ohm, live res going up to 0.721 Edited July 12, 2017 by ndb Link to comment Share on other sites More sharing options...
James Posted July 12, 2017 Author Report Share Posted July 12, 2017 Could you PM me your .ecig file? Curious if there is anything unusual with your settings. Link to comment Share on other sites More sharing options...
emilio_n Posted July 13, 2017 Report Share Posted July 13, 2017 Works perfect to me with Sierra. Thanks!!! I only got some crashes in the theme designer but taking care and saving frequently is not a big problem. Now learning how to use in depth! 😉 Link to comment Share on other sites More sharing options...
