renegadejade Posted August 16, 2015 Author Report Posted August 16, 2015 Opus200. Profile 2. 60watts. 125 preheat for 1second. Ohms locked. Everytime the device fully shuts off and i fire it back up i have to press up or down for new or old coil. Is this the way it is supposed to be? I find it rather annoying...
dwcraig1 Posted August 16, 2015 Report Posted August 16, 2015 It doesn't work that way on mine. Opus also for what ever that's worth.
blueridgedog Posted August 16, 2015 Report Posted August 16, 2015 What is the behavior with ohms unlocked?
renegadejade Posted August 16, 2015 Author Report Posted August 16, 2015 If i unlock the ohms the res raises. But it dosent make me choose between new coil/same coil...maybe since the mod detects a jump in res is why it askes me...
dwcraig1 Posted August 16, 2015 Report Posted August 16, 2015 Kind of working backwards to what one would expect.
blueridgedog Posted August 16, 2015 Report Posted August 16, 2015 renegadejade said:If i unlock the ohms the res raises. But it dosent make me choose between new coil/same coil...maybe since the mod detects a jump in res is why it askes me...That was my thinking...the resistance has changed since you locked ohms, so when it comes on it triggers the prompt. Perhaps you can lock ohms after it has settled and avoid it.
renegadejade Posted August 16, 2015 Author Report Posted August 16, 2015 I don't really understand it. I build and let it set for awhile...who knows.
basilray Posted August 17, 2015 Report Posted August 17, 2015 What is your lock resistance set to in EScribe? I believe the default is 25%
renegadejade Posted August 17, 2015 Author Report Posted August 17, 2015 No idea there? What does this setting do? I understand locking ohms etc.
mikepetro Posted August 17, 2015 Report Posted August 17, 2015 renegadejade said:No idea there? What does this setting do? I understand locking ohms etc. On the MOD tab of Escibe you will see:The Ohm Lock Range is what percent of resistance change will trigger the "New Atty" question.In the above case of 25%, if the atty was originally at 0.1 ohms then 0.075 or 0.125 would trigger the question.ETA, one thought is that "maybe" you have locked the ohms significantly lower than the reality. Lets say you locked it at .1 ohms, but after the atty settled maybe a screw tension changed or 2 wraps of a coil arent touching now but were, and now your real resistance is 0.14 ohms, that might cause the New Atty question upon waking the mod from deep sleep.Dont hit the atty for an hour, plug it and run Atty Analyzer and see what the true resistance is that it is reading now. Sometimes atties settle in a little different than when you first build them.
techbearus Posted August 21, 2015 Report Posted August 21, 2015 Quick question.. I have 3 different attys that I use with resistances 0.36 ohms, 0.22 ohms and another with 0.61 ohms. As I switch between these three it automatically switches to their respective resistances that I had used prior. I am just curious how many of these base resistances does the chip store in memory. If it had no memory it would be asking me when switching from 0.22 ohms to 0.61 ohms whether it is a new coil or not, but it doesn't and somehow magically switches to 0.61ohms correctly, like it has memory of that I used something similar to 0.61 prior to using 0.22 ohms. Also is there any way to clear up the previously stored resistances?
turbocad6 Posted August 21, 2015 Report Posted August 21, 2015 I think when it knows for sure that it's a different coil it don't ask, it just assumes it is and goes with the new reading, it only asks when it's close enough that it could be the same coil. I don't think it stores anything more than the last set base resistance
Legros Posted August 21, 2015 Report Posted August 21, 2015 On the MOD tab of Escibe you will see:The Ohm Lock Range is what percent of resistance change will trigger the "New Atty" question.In the above case of 25%, if the atty was originally at 0.1 ohms then 0.075 or 0.125 would trigger the question.It the reverse if it more then 25% it will not ask new coil question
techbearus Posted August 21, 2015 Report Posted August 21, 2015 .. facepalm ... thanks for the clarification @turbocad6 and @Legros .. was thinking way too much, in a wrong direction..
James Posted August 21, 2015 Report Posted August 21, 2015 techbearus, if you are using three different atomizers in the same profile you're probably better off with Ohm Lock off, as if it is working right that means your 510 is relatively stable/good. Ohm Lock isn't meant to be used if you are switching atomizers on the same profile. (Some people set up one profile per atomizer, though.)
