Jeepster67 Posted January 11, 2016 Author Report Posted January 11, 2016 It would be nice if I could change the accelerator settings. How fast it scrolls through the watts/temp, how long to go slow, ramp up time to full speed and full speed settings would all be nice.
stuartro Posted January 12, 2016 Report Posted January 12, 2016 +1 It speeds up too fast, and then rushes past the value I'm trying to reach. Rather annoying.
Jeepster67 Posted January 12, 2016 Author Report Posted January 12, 2016 That's exactly the trouble I have with the current settings.
pateyevee Posted January 13, 2016 Report Posted January 13, 2016 Where is this accelarator setting and is it and firmwar update or an add on or something? or are you talking about the "look and feel" part under the theme tab? Jusst making sure there isn't something im missin out on haha.
Jeepster67 Posted January 13, 2016 Author Report Posted January 13, 2016 No options for it that I've found, I'm requesting that the option be added to the software.
Cryonosis Posted January 14, 2016 Report Posted January 14, 2016 +1 from me, would be nice to slow things down a bit I will say adjusting the increments up to .5 from the default .1 helped out a lot though!
Jeepster67 Posted January 15, 2016 Author Report Posted January 15, 2016 I don't see the option to adjust increments, where do I find it?
Viruk Posted January 15, 2016 Report Posted January 15, 2016 I'd also like to see this feature. I'm just about to experiment with the "watts hold" increment and see if that mitigates the acceleration...
Jeepster67 Posted January 15, 2016 Author Report Posted January 15, 2016 That actually helped quite a bit. I changed both press and hold to .5. Speeds up the low end and slows down the top end. Accelerator settings would be nice also but this definitely helps. Thanks.
drunkvaper Posted January 21, 2016 Report Posted January 21, 2016 I don't have "look and feel" on the theme tab??? I just re-downloaded escribe using the link on evolv...
VapingBad Posted January 21, 2016 Report Posted January 21, 2016 drunkvaper said:I don't have "look and feel" on the theme tab??? I just re-downloaded escribe using the link on evolv... You need the pre release version top of the list on the first post https://forum.evolvapor.com/topic/66731-topic/
