ziaibrahimadv@yahoo.com Posted May 7, 2016 Author Report Posted May 7, 2016 Suddenly the screen on my dna200 become very dim...... when i press the fire button, the message displays "check atomiser". i have checked and attached it with escribe, there is no issue with battery. I cant understand what is issue. i have attached other atomizers but the same message displayed.....and the screen remained very dim.
VapingBad Posted May 7, 2016 Report Posted May 7, 2016 It may be the screen cable getting pinched under the fire button.
BillW50 Posted May 7, 2016 Report Posted May 7, 2016 Have you used the Device Monitor to see what is happening with the cell voltages, power output, resistance, etc. when you press the fire button?
ziaibrahimadv@yahoo.com Posted May 7, 2016 Author Report Posted May 7, 2016 VapingBad said:It may be the screen cable getting pinched under the fire button.Maybe there is some issue with screen connections but the board is also not giving power to the atomizer.....on pressing the power button "Check Atomizer" is showing on the dim screen.
ziaibrahimadv@yahoo.com Posted May 7, 2016 Author Report Posted May 7, 2016 BillW50 said:Have you used the Device Monitor to see what is happening with the cell voltages, power output, resistance, etc. when you press the fire button?When i press power button, the escribe shows variations in the graph but the device does not gives power to atomizer rather a message "check atomizer" displays.
BillW50 Posted May 7, 2016 Report Posted May 7, 2016 Yes that is what I want to see under the Device Monitor. Things are changing, but what things when you press the fire button?
awsum140 Posted May 7, 2016 Report Posted May 7, 2016 What kind/brand of mod are we talking about here? Things to check, besides what's already been mentioned regarding the screen ribbon cable. Check the 510 connector on the mod, could be a problem there. Check the wiring from the board to the 510. If you can post a screen capture of eScribe while attempting to fire the device, that might help as well.
black lace Posted May 7, 2016 Report Posted May 7, 2016 Is it drenched in juice? Also is this the same mod that you had quite a drama with in january? i'm only on mobile but i remember you!!!
VapingBad Posted May 7, 2016 Report Posted May 7, 2016 It's the screen dimming when the button is pressed that is consistent with a shorting screen cable.
BillW50 Posted May 7, 2016 Report Posted May 7, 2016 But would a screen cable short also cause a check atomizer error?
black lace Posted May 7, 2016 Report Posted May 7, 2016 Wish i could get a short screen cable.. oh sorry "screen cable shorting"..... ,,,,,, ,,,,,got juice on it..
VapingBad Posted May 7, 2016 Report Posted May 7, 2016 BillW50 said:But would a screen cable short also cause a check atomizer error?IDK but I wouldn't rule it out, but it is the only cause of the screen dimming when firing I can remember.
black lace Posted May 7, 2016 Report Posted May 7, 2016 Ziaibradv: While there talking amongst their selves, if you take the back off, disconnect your battery first what evere you do or you will have anouther blown fuse issue. look for any liquid on your board, and see if you can notice anything wrong with your screen ribbon....i know you can do it son..
black lace Posted May 8, 2016 Report Posted May 8, 2016 Dont know where the op got to but i thought he was taking the mick several weeks ago..
