Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 I just got a replacement Aria anarchist from Beyond vape an have plugged it into escribe and everything my mod resistance is zero and have tried setting stainless steel profiles but none of the ones I set up seem to be working Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted September 2, 2016 Report Share Posted September 2, 2016 not working, as in kicking you out of TC and dumping you into regular wattage mode? did you back up the ecig file from your previous anarchist? you could load that mods entire settings directly into your new one as long as it's the same mos, which it is. do yo remember what the mod res was? post a screen shot of device monitor while firing the device with the SS build in question. make sure all power, temp and ohm boxes are checked. Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 So at some points the area that displays temp will say for example 400 soon as I fire I get the dash lines showing its kicking out then I go to another profile an it seems the temp fluctuates an I have set the mods resistance to .009 as of now an it's reading my current dual claptons at .18 but seems iffy compared to my other DNA 200s which read them at .15 guess cuz I haven't messed with those mods resistance any an seem to fire in TC fine Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 And I don't think I did but I copied the profile from my first DNA to it an still seems to be acting funky Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted September 2, 2016 Report Share Posted September 2, 2016 you mean your first anarchist dna 200? it should be that mod's settings and not another manufacturers. for instance, don't put a VT200's manufacturers settings in an anarchists manufacturers settings .009 is a very high internal mod res. to give you an example none of my 200/75's are over .004 with the exception of my VS DNA 200 being the highest at .007 are you using the stock evolv 316SS material curve or 0.00092 TCR? Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 I'm using the .000915 curve Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted September 2, 2016 Report Share Posted September 2, 2016 a screenshot of device monitor would help in diagnosing your problem. Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 Alright Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 What cause a profile to read temp protected on a atty that isn't built with TC wire cuz I'm using a flawless production built with 10 Wrap nichrome and on one of my ss profiles it always reads as temp protected Link to comment Share on other sites More sharing options...
VapingBad Posted September 2, 2016 Report Share Posted September 2, 2016 Logically the resistance goes up when you fire it, you can check the live ohms in device monitor while you fire it, it could be a poor connection, wrong wire or loops shorting between each other. Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted September 2, 2016 Author Report Share Posted September 2, 2016 Alright cuz like I said the atty I was using wasn't a stainless steel built atty it had nichrome but for some reason it was reading in TC an saying temp protected and what would cause a atty built with stainless to stay in TC but act like it was kicking out cuz i have a tsunami with ss claptons an I lock resistance and everything with both profiles an one of them always acts like it's kicking out of TC showing the dash lines but still works fine kinda confuses me Link to comment Share on other sites More sharing options...
BillW50 Posted September 2, 2016 Report Share Posted September 2, 2016 Juggaloassassin123 said:Alright cuz like I said the atty I was using wasn't a stainless steel built atty it had nichrome but for some reason it was reading in TC an saying temp protected and what would cause a atty built with stainless to stay in TC but act like it was kicking out cuz i have a tsunami with ss claptons an I lock resistance and everything with both profiles an one of them always acts like it's kicking out of TC showing the dash lines but still works fine kinda confuses meThe simple solution for Nichrome is to turn the temperature as high as you can go and one more click and it should display off. You could create a Profile for it and you can use it for Kanthal too if you want. Link to comment Share on other sites More sharing options...
black lace Posted September 4, 2016 Report Share Posted September 4, 2016 Ive noticed with mine,,,the basics are important! some materials moor than others, if the board temperature hasnt stabalised, performance will be hopeless,, best starting point is a cold board (mod) to cold coil. Swapping attys with different builds over on a warm board, they will fire but the readings and tuning will be off. (Haywire with some metals) Link to comment Share on other sites More sharing options...
