uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 First post here, hello I decided to create a custom profile for my dual coil Limitless Plus which I have set up with a set of paralel SS316L coils. I created a profile on steam engine and the CSV came out as this:[CODE]"Temperature (degF)","Electrical Resistivity"-58,0.92306468,1212,1.08302,1.126392,1.168482,1.207572,1.246800,1.3369666667[/CODE]I created a profile using that CSV and when I select it on my mod (Los Vape Triade), it shows degrees, but it also shows volts on the main display. I have temperature mode set up to show watts and degrees, not volts. There appears to be no temperature control used at all when I use this profile. It just burns and burns, no temp limiting at all.I have some screenshots of my settings in Escribe and am hoping someone can identify what's going wrong.Thanks in advance! If any other information is needed just let me know. Link to comment Share on other sites More sharing options...
retird Posted January 12, 2017 Report Share Posted January 12, 2017 The device is not seeing your coil as a TC type coil. It is vaping in power mode and in power mode while running it is set to display volts.What type of material are you using to build your coil and what type coil are you building (standard, clapton, fused, etc.)? Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 I figured it wasn't detecting it as a temp. coil. Here is a picture of my steam engine setup: Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 retird said: The device is not seeing your coil as a TC type coil. It is vaping in power mode and in power mode while running it is set to display volts. Expand Something that's odd is when using the profile, it shows volts, but the main stat it's showing (in the big letters) is the temperature. Link to comment Share on other sites More sharing options...
VapingBad Posted January 12, 2017 Report Share Posted January 12, 2017 There is no need to make a profile for that wire or any single metal construction, you just get the standard 316L/Elite profile and I would just use the in built 316 profile for 316 & 316L, the L (low carbon) makes almost no difference.Profile in OP[CODE]"Temperature (degF)","Electrical Resistivity"-58,0.92306468,1212,1.08302,1.126392,1.168482,1.207572,1.246800,1.3369666667[/CODE]Standard SE 316L/Elite profile[CODE]"Temperature (degF)","Electrical Resistivity"-58,0.92306468,1212,1.08302,1.126392,1.168482,1.207572,1.246800,1.3369666667[/CODE]Evolv 316 profile[CODE]"Temperature (degF)","Electrical Resistivity"-100,0.8937021493911740,0.95631814002990770,1200,1.07169163227081400,1.17003667354584600,1.25565493106842800,1.33229231834412[/CODE]The board needs to see the coil raise temp 185 F in the first 2 seconds, try increasing your preheat. Link to comment Share on other sites More sharing options...
retird Posted January 12, 2017 Report Share Posted January 12, 2017 Can you post a Device Monitor screenshot showing Power, Power Set, Temperature, Temperature Set, Cold and Live ohms? Each coil you have is almost 0.8 ohm's?Have you tried using a default profile for SS316L? Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 VapingBad said: There is no need to make a profile for that wire or any single metal construction, you just get the standard 316L/Elite profile and I would just use the in built 316 profile for 316 & 316L, the L (low carbon) makes almost no difference.Profile in OP[CODE]"Temperature (degF)","Electrical Resistivity" -58,0.923064 68,1 212,1.08 302,1.126 392,1.168 482,1.207 572,1.246 800,1.3369666667[/CODE]Standard SE 316L/Elite profile[CODE]"Temperature (degF)","Electrical Resistivity" -58,0.923064 68,1 212,1.08 302,1.126 392,1.168 482,1.207 572,1.246 800,1.3369666667[/CODE]Evolv 316 profile[CODE]"Temperature (degF)","Electrical Resistivity" -100,0.893702149391174 0,0.956318140029907 70,1 200,1.07169163227081 400,1.17003667354584 600,1.25565493106842 800,1.33229231834412[/CODE]The board needs to see the coil raise temp 185 F in the first 2 seconds, try increasing your preheat. Expand I guess I'll just use the pre-programmed 316 profile. I still don't understand why it's not sensing the temperature though. Link to comment Share on other sites More sharing options...
retird Posted January 12, 2017 Report Share Posted January 12, 2017 uberbdon said: Something that's odd is when using the profile, it shows volts, but the main stat it's showing (in the big letters) is the temperature. Expand You have Temp Dominant checked in your profile thus Temp is displayed. Link to comment Share on other sites More sharing options...
VapingBad Posted January 12, 2017 Report Share Posted January 12, 2017 uberbdon said: I guess I'll just use the pre-programmed 316 profile. I still don't understand why it's not sensing the temperature though. Expand The board needs to see the coil raise temp 185 F in the first 2 seconds or it will stop trying to use temp protection, try increasing your preheat. Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 retird said: Can you post a Device Monitor screenshot showing Power, Power Set, Temperature, Temperature Set, Cold and Live ohms? Each coil you have is almost 0.8 ohm's?Have you tried using a default profile for SS316L? Expand It doesn't seem to be detecting a temp. at all Link to comment Share on other sites More sharing options...
VapingBad Posted January 12, 2017 Report Share Posted January 12, 2017 I think retird meant a pic while you are vaping and it not doing what you expected. Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 VapingBad said: The board needs to see the coil raise temp 185 F in the first 2 seconds or it will stop trying to use temp protection, try increasing your preheat. Expand But with the same pre-heat settings for the default 316 profile it works just fine Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 retird said: Can you post a Device Monitor screenshot showing Power, Power Set, Temperature, Temperature Set, Cold and Live ohms? Each coil you have is almost 0.8 ohm's?Have you tried using a default profile for SS316L? Expand Here we go:Oddly it appears to be working now... I'm at a loss Link to comment Share on other sites More sharing options...
VapingBad Posted January 12, 2017 Report Share Posted January 12, 2017 uberbdon said: But with the same pre-heat settings for the default 316 profile it works just fine Expand But I think you probably have a larger coil now which will take longer to get up to temperature. The material profile stays the same for a type of metal, but you may want to vary preheat for different builds, tanks or even flavours, it is far more a personal preference thing as long as you coil get up to temp fast enough. Link to comment Share on other sites More sharing options...
retird Posted January 12, 2017 Report Share Posted January 12, 2017 If your coils are contact coils try spacing them also... 15 wraps per coil is a lot of wraps. Link to comment Share on other sites More sharing options...
uberbdon Posted January 12, 2017 Author Report Share Posted January 12, 2017 retird said: If your coils are contact coils try spacing them also... 15 wraps per coil is a lot of wraps. Expand When I get a chance today I'll rebuild it and not do contact coils Thanks for the help guys! Link to comment Share on other sites More sharing options...
retird Posted January 12, 2017 Report Share Posted January 12, 2017 You welcome.... enjoy and somebody here is usually available for further discussion. Your last screenshot post was most helpful.... THX Link to comment Share on other sites More sharing options...
Wayneo Posted January 12, 2017 Report Share Posted January 12, 2017 How can you be at a loss. Your first Device Monitor shot showed you were in Profile 3, your second (which matches with your profile setting 5) shows it works.Edit: excellent screen captures. Makes helping so much quicker.Beautiful solid TC you got there Link to comment Share on other sites More sharing options...
Viruk Posted January 12, 2017 Report Share Posted January 12, 2017 I like contact coils with SS, just make sure you dry burn it before wicking and work out any hotspots if you're using contact coils. Link to comment Share on other sites More sharing options...
