Version v2.4
10,013 downloads
Replay ready! (with temp control and wattage modes available too) - See below if you are having trouble with Replay
Main menu is on the top right
You can hide data on main screen in Main Screen menu (resistance, voltage, etc)
You can hide date/time from Lock screen in Time Config page (also can choose MM/DD or DD/MM date format)
see downloads page: Clean-Color--ONE-WATT-#_#.ecigtheme
A LOT of other stuff.. check it out!'
Replay Available (if theme/coil supports Replay [read-only])
Replay Ready (Replay is ready to be activated [read-only])
Replay Active (you can toggle this switch to save your last puff and activate Replay).
You also cannot use a plain kanthal coil for Replay. You can use any temp sensing wire, including combinations (e.g. SS wrapped with kanthal).
