DMAN
Everything posted by DMAN
  1. Totally disagree with your opinion. Replay enabled devices are perfect for starters/newbies. Find a vape you like, press Replay. Sorted.
  2. Replay will only work with TC wires. In a fancy coil, the core needs to be a TC wire.
  3. I should edit this post. The atty is working fine now that I understand Replay better. The coils I was using at the time had a Kanthal core. They worked on another DNA mod because I had allowed dubious coils. The Lotus is actually a pretty sweet atty with a restricted lung hit.
  4. Probably unconnected, but I had a similar problem using Replay. The power kept switching off and on through the vape. It was jumping all over the place. It only happened with the one atty, so I knew it wasn't the board. The atty was the Vandy Vape Triple 2, so a fairly crowded deck with 3 coils. I had carelessly added an extra wrap to one coil. I removed the extra wrap and all was good.
  5. That's what I do, I trust the chip to sort things out. When I build a coil, or use a stock coil, I have a rough idea what power it needs. I start low and up the power until I get a nice vape then Replay it. It doesn't matter to me if Steam Engine says it needs 85 watts, i'll run it at 60 watts if it vapes fine, or go past 85 watts if needed. I guess it could drive you nuts if your the type that needs to know exactly how something works.
  6. I use the 'Gauges' theme on mine. Works perfectly.
  7. I will leave you to your elevation. You are too high for me, I just want a nice vape.
  8. I must be missing something here. How much more simple can it get? Up the power until you get a vape you like. Press Replay. Done. End of.
  9. Mine work fine on various DNA 250C mods, including the Triade. I don't have it set to allow dubious coils.
  10. Yeah, same settings. I think it's a 510 pin issue. I almost got it to work on one of the other mods. The 'save puff' was there, but the draw after that was a horrible dry hit after I saved it. I don't really care about this issue, so don't spend any time trying to figure it out mate. I just posted about it to put the issue out there. The atty is a cracker, and it's worth buying no matter if you use it in Replay, TC or Power mode on any mod. It's almost impossible to get a dry hit because of the floating deck.
  11. Very strange. I've just got myself a LV Mirage, and this atty works in Replay on it using the same coil as before. It doesn't work on a LV Triade, a LV Paranormal or a Thinkvape Finder.
  12. Just got the Hugsvape Lotus RTA and it doesn't seem to like Replay. Used a couple of 316l claptons that work in Replay mode on other attys.
  13. Just got the Hugsvape Lotus RTA and it doesn't work.
  14. Same here. Mine is also working perfectly now, so the general release of the firmware must be imminent.
  15. I've just submitted a ticket, thanks.
  16. Someone on another thread returned their mod. It came back with a new board, and still had the original fault.
  17. Has there been any progress in fixing the 'wake up from sleep' bug on the Lost Vape Paranormal? Surely Evolv needs to make a statement on if there is a bug that can be fixed, or a new board is needed.
  18. Any news on a fix for this issue?
  19. I don't know if I should send mine to Evolv or not. It's expensive shipping I would guess, so maybe better to wait for the firmware fix.
  20. That's good news. Mine has this fault too, but It always switched on eventually. I was considering opening a ticket, but will hold off for now.
  21. Thanks for this. I love the 316st coils from Freemax. I was looking for a big volume tank, and the 8ml Voopoo T1 tank is giving me a lovely vape with these coils.
  22. I downloaded one of the themes on the forum, and now i'm a happy vaper.
    Looks great on my black Vapecige VTBox DNA250c. Thanks.
  23. Thanks for your help retird.
  24. I kept on pressing stuff until I found a menu with '4 cells'. I changed it to '2 cells' and Replay now works! I'm a happy vaper, but wish I had found that before I lost the multi coloured screen.
