Everything posted by Jetro
When I made the theme all I did was make a battery screen that has voltage fields for four cells. Cell1, Cell2, Cell3 and Cell4. It makes no difference whether the batteries are charging or not or whatever voltage they are at. I am seeing the same small amount of voltage on cells 3 &4 on the Paranormals and cell 4 on the Finder. As far as how I am getting these voltage readings on the nonexistent batteries I have no idea. All I can say is what I see in the fields on the screen. Because of the way the balance connection is jumpered from the positive terminal of the battery to the unused pins on the balance connector it should not show any voltage on the nonexistent cells. But it does. Other than voltage or current leakage in the balance circuit I have no explanation to why it shows these small voltages. But it does and it is fairly consistent. Also on the Finder and Paranormal that wake up and work properly the voltages are very small ( .005 to .056 volts ). The Paranormal that will not wake up as in my first post in this thread the voltages on cells 3 & 4 are between .234 & .932 volts. Again, I have no idea why. PM sent JT
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Ian, I just called the buyer. They are out of town on vacation and will not be back for seven days. When they get back he will let me have the mod and I will get csv for the batteries. I can appreciate not wanting to run the analyzer. The mod and batteries get really hot in the process. I only ran it once to get the csv. I kinda feel stupid for deleting my Triade file after I sold the mod, but oh well. If you want you can set the battery watt hours to 24k to see if the readings match better. JT
ruudde , No problem on the testing, just trying to help diagnose. retird , Yes all my mods are set up in EScribe with the correct number of batteries. The theme is set up on the battery screen to show the voltages from Cell1 , Cell2 , Cell3 and Cell4. On a 2 battery mod like the Paranormal there should be zero volts showing on cells 3 and 4 and on a 3 battery mod like the TV Finder it should show zero volts on cell 4. But probably due to component tolerances or leakage they show a small amount of voltage. like mine do in my post above. I am sure that my Paranormal that shows consistently above a half a volt is a problem. As it will not start properly at 3.71 volts or above as in my first post. For everyone wanting to use the theme I posted above. DO NOT change the battery amount in EScribe. Just install the theme and look at the Battery screen. I should have stated that in that post, I will edit it . Well, I can not edit the post. I hope it does not cause anyone a problem. JT Retird, if you think that my post with the theme will cause a problem then I will hide it and repost.
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Did you run the battery analyzer in EScribe to get that whr value? On the Triad that I sold if I remember correctly. When I ran the battery analyzer it came up with something just short of 23.5 for VTC5a's. If you want I can try to get the info from the buyer. JT
Tazrok you can turn off autolock on the Safety tab in EScribe by unchecking the Automatically lock when idle box. Or you can use the theme I posted above. It might help you to do this but there is no way to disable deep sleep that I know of. I also tried setting the lock time to 480 minutes ( 6 hours ) but that did not work. Hope this helps. JT
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
My Paranormal that won't startup properly is still dependent on the battery voltage be under 3.70 volts to start with no issues. Themes and firmware make no difference. I also got a Thinkvape Finder 250c. It has zero issues starting or vaping. I now have 3 250c mods. Two that have no problems and one that won't startup properly. I read some where on the web that someone was having startup issues and they had strange voltages on battery 3 and 4 on their Paranormal. As you know these boards can be wired for 2, 3 or 4 batteries. So I modified the default theme to show the 4 batteries. This is what I found : The Paranormal with problems starting, battery 3 reads 0.234 to 0.932 volts usually 0.547 volts , battery 4 reads 0.354 to 0.737 volts usually 0.604 volts. The Paranormal with no issues, battery 3 reads 0.010 to 0.035 volts usually 0.010 volts, battery 4 reads 0.007 to 0.009 volts. The TV Finder with no issues, battery 4 reads 0.005 to 0.056 volts, usually 0.024 volts. If you want to check this out here is the theme. You can lock the mod and turn off autolock from Main screen. The battery screen is accessed from the Settings screen so you can see the voltages. JT Default 250C 4 Batt for testing.ecigtheme
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
This is absolutely brilliant!!!!! I have finally figured out how use User Toggles...........................SuWeet!!! Like you I wanted to be able to hide time and date on the lock screen at times. Also I think i'll try them in a few other places as well. Your theme is looking great! Thanks much. JT
I'll add this. You can see the difference in Device Monitor. With 75w watts enabled you will see around 6.8 watts per step in preheat punch or boost punch ( 11 steps ) . With 100 watts enabled you will see around 9.1 watts per step. If your theme has preheat power and temperature instead of preheat punch. You can adjust the preheat power to 100 watts. But sadly your main wattage remains at 75 watts. But the added power in boost / punch and preheat power is Sweet! JT
I have some questions too. I have not uploaded a theme yet and wanted to know when you upload a theme does it display the screen images like they are on the right side of Theme Designer? Can you upload images from the computer to supplement those images or do you need to use an image hosting site? Or can you not upload separate images at all? I'm in the same place as SirTimmyTimbit as the main screen looks completely different depending on whether it is in watts, tc or replay mode. Also several screens show nothing because all the fields start from a hidden condition and change state depending on the mode. Thanks in advance... JT
Conrad thanks for starting this thread. When I got this Paranormal 250c 4 weeks ago. I threw in a pair of VTC5a's that were not fully charged ( about 85% ). I pressed fire button and nothing happened. So I held the button down and the mod started. I thought that was strange because the 4 DNA 75c mods I have more or less come on instantly. So I the put in a set of fully charged batteries and ran the battery analyzer. I then put in the original pair of batteries that were about 50% charged and vaped on and off for three days with no issues at all. I put on a new theme and a set of fully charged batteries and everything was fine until the next morning. The mod would not come on at all. So I opened Ecribe and hooked the mod up, as soon as I plugged in the usb cable the mod came on. That started a week or so of resetting defaults, hard reboots etc.... Any way. I found this thread and watched what you had posted. While fooling around trying figured out what was happening with this mod. I got a second Paranormal 250c that has zero issues, what in the world? The I saw John's post asking for board and battery details. The battery inquiry went right over my head. So I kept fooling around. Then it dawned on me that the mod worked perfectly with low batteries. So I did some testing. At 4.2 to 4.05 volts the only way the mod will start up is to open the battery door or hook it to a usb cable. From 4.04 to 3.95 volts the mod would start by randomly pressing all the buttons and holding the fire button down. From 3.95 to 3.82 volts the mod would start by double tapping the fire button or holding it down after the double taps. From 3.82 to 3.71 volts a long press of the fire button would always start the mod. At 3.70 / 3.69 volts down the mod works perfectly. I then put in a set of fully charged batteries and after it went to sleep, it would not start. I then put in the low batteries and it started instantly and I vaped with no issues until I got a weak battery warning. As long as I do not put in batteries that are over 3.70 volts the mod works perfectly. For John, the Paranormal with the issues : sn: XTEZ ZOYW DVFY, board programed 18-0319, mod configured 18-0331 The Paranormal with zero issues : sn: XRGW SEMG XRAA, board programed 18-0226, mod configured 18-0402 John, I hope this info helps with a fix for this problem. Would you like to play with this mod? I would be happy to send it in for your inspection! Guys, Sorry for writing a book. But I was just flipped to figure out my mods issue. JT
- 186 replies
- 1
- lost vape
- paranormal
(and 1 more)
Tagged with:
Thanks, Smokin Dave. I'm glad you found them useful. JT I should have included this in the original post. These csv's were created in EScibe v2.0 SP12. I ran the battery analyzer at 40 watts at a resistance of .29 ohms. I also ran a couple tests at 60 watts to check the difference. There really wasn't any change , .05 to .10 watt hour less. Not enough to justify heating the mod and batteries that much more. JT
You are very welcome. The theme is almost the same as what was on my VT75D. I had it on mod testing the changes. The more I used it I just had to fix some things . I figured you would like the atty screen change and boost for kanthal. The only thing I did not like and did not change is on a lot of the screens if you press the fire button it returns to the main screen. If you're used to that happening, cool. Any who, If you want any changes to the theme let me know. JT
I made these csv's for my VT75D. These are for 2 batteries in parallel ; 2x 25R Batteries.csv 2x 30Q Batteries.csv 2x VTC5a Batteries.csv 2x VTC6 Batteries.csv These are single batteries for the VT75C 1x 25R Battery.csv 1x VTC5a.csv 1x HG6 20650.csv I made a 26650 to 20650 adaptor for the 75c, so I included the csv. JT
YES indeed, Thanks Brandon and James for this update. Very, very nice. JT
steamer861, Heres your theme. I have tested it this afternoon on a VT75D and it works great. Replay is on a separate screen, accessed from the Main screen. Replay power, warmth and boost are adjustable on 1 screen. Replay mode can turned on or off for any profile using the on / off switch on the Replay screen. To avoid inadvertent adjustments : When Replay is Playing the Settings screen is unavailable. The power, temperature. ohms, warmth, preheat or boost punch are read only. When Replay is off or not playing all screens and adjustments work as normal. Note : Main screen round robins instead of stopping at the bottom. Temperature setting is read only with non temp sensing wires. Disabled Temp Protection on/off for non temp sensing wires on the Settings screen. Fixed the ohms lock on the Atomizer screen. Added Boost controls on the Atomizer screen for non temp sensing wires. Disabled Temp Protection on/off for non temp sensing wires. Added Temperature adjust field to Atomizer screen for temp sensing wires. This allows power, temperature, preheat power and preheat temperature to be adjusted on 1 screen with temp sensing wires. Power and boost can be adjusted for non temp sensing wires as well. Enjoy!! JT Vapecige SD75c Replay.ecigtheme
