Hi, niandra3 - great theme... I love it, but still I have some issue at my Mirage - there is no ohm visible on screen. At Therion it is OK. I tried different colors and older versions, but still the same
Any sugestion how to fix it?
Thanx
Try to compare these pictures - depending on selected Temp-sensing check box You can see different possibility at Profile table - with or without Temperature box under Power settings box...
Also compare curves for Nickel200 a Watts under Temp-sensing checkbox... there is no difference
I tried the wattage material for Replay profile, it looks like Replay works but at higher power does not work TC, i got dryhits ... if i confirm Temp-sensitiv material u Wattage material table, it turns on curve for Nickel200, so for SS wires probably unusable...
BTW: is there a closed cycle of combinations that repeat over time, or the combination is always random - to know that maybe after 20 puffs I do not need to retest and adjust the watts for a new tuning?
