Everything posted by Ken Nutter
My Replay settings. It has ran everything amazingly. General Tab Boost: On 5 Warmth: 5 Material: Watts Mod Tab Replay: Allow Dubious coils I will typically guess about were my build should run wattage wise. My first puff is normally a little cool(that first puff should be slightly cool) but as heat builds up the 2-4 puff will be amazing. Then click save puff. And the device will make any necessary adjusts to recreate that puff. Have used this with SS, TI, NIFE 30. My normal go to build is dual SS fused clapton's(24awg cores 34awg wrap) 6 wrap 3.5mm center OHMing in at about 0.9ish. Running about 120watts with the above replay settings.
Larger Reference Case 1300mah
Ken Nutter replied to Russ ModCrate's topic in Connectors, Components, and Accessories
Looks great... Nice work -
Need Temp Control Help (Opus 200)
Ken Nutter replied to a topic in Manuals, Instructions, and Tutorials
My Opus TC control issues started to minimize after I tightened down everything in/on the 510... I have preheat 150watts/0.25sec/4punch... Keep watts around 100 and temps usually 300-400 range. Any higher I'll start charing cotton on occasion. Hope this helps... Also I have better luck with contact coils. -
20awg square TI... Ahhhhh its OK... Going to try Clapton TI now that I got more wire and a couple smaller gauges.
I know that... Thank you for the reminder though
Im not worried till I come to log in and it says "YiHiscribe"... Lol... I about died laughing when Brandon said that
Damn them there @ it again
I seen the issue yesterday and thought it was fixed. This is from just a moment ago...
Very nice build bro
O also I dropped my ramp time to .25sec and 150°f
I've had better luck with TI contact coils... Also was have major issues with TC before I checked and tightened up my 510 even more...all of it have a little extra tighten. If I run much over 400 I'll get burnt... Usually around 350 somewhere
On the bright side. If it didnt mess the screen up u have an extra screen now
Lmao... Literally laughed out loud. Thanks Brandon
What battery are you using/planning to use?
Ken Nutter replied to vaporlips's topic in Batteries and Charging
Turnigy airsoft battety Capacity: 1200mAh Voltage: 3S1P / 3S Cell / 11.1V Discharge: 15C Constant / 25C Burst Weight: 94g (including wire, plug & case) Dimensions: 128x17x20mm (Each) Balance Plug: JST-XH Discharge Plug: Mini-Tamiya (Mini Molex) Would this battery be sufficient? The lower C rating has me worried but I did read an article in here before talking about C ratings being iffy from manufactures. So any thoughts? Thanks, Ken -
Ti Temp. Protection lighting my cotton on fire
Ken Nutter replied to Sticky907's topic in General Discussion
I have same issue alot of times... Check your 510ground connection. On your Atty. I have an opus200 the ground really shouldn't be causing an issue for me because of board grounds to case and the ground wire... But I still have it act up... The ground is soldered good... But it still acts up. So idk. Just check it out make sure it all looks good jiggle it around. I had alot of issues with same thing. Then it just started working right again -
Velocity, Hobo v3.1, Stro mini are ones I know of that have that post design
O yhea sorry bought dirty coils. Not as bad as it looks in pic
First time I actually thought... "What am I doing???" To much... Lol. Quad parallel 7wrap TI around 2.5mm reading in @0.03
Mod Crate 1590A CNC
Ken Nutter replied to Podunk Steam's topic in Connectors, Components, and Accessories
Have you tried the "acetone smoothing" technique for 3d prints? Wonder how well it works -
If I did tryed it in the lemo2 I was going to pack the crap out it...lol. I made a nice very in my velocity but ran the wick through the coil
Mod Crate 1590A CNC
Instead of paint you could do a mydipkit and that would probably look amazing. I definitely like the design looks cool -
So weird I just was messing with my lemo2 today for 1st time in awhile... Drilled out airflow wholes in bottom and juice feed wells some... Yhea I put an RDA back on... I'm hooked on quad coil TI build and airflow. I did think about trying a TI chimney build in lemo2
