Droopydroors
Everything posted by Droopydroors
It will be needed to lower the wattage to use nic salts. Right now with the airflow mostly closed off and on the lowest wattage setting it's still too much power. That's why escribe is needed. That is with the .5 pod
This is horrible. I bought the device because I wanted to use it with escribe and it does not work.... Horrible...
Any feedback on HCigar VT75 Color?
Droopydroors replied to dl12345's topic in DNA 75 Color and 100 Color
I wouldn't use efest batteries for multiple reasons. 1.) They suck and have a horrible sag that only let's you get down to around 40% on the battery before the sag stops the mod from working even at 30w. 2.) They are too long. When using the Efest 26650 the battery cap should not be tightened to tight. When you do tighten further than snug you will bend the flat top causing it to short. So even though the battery cap is not screwing in the whole way it's better than blowing your hand off from over tightening. The Ijoy and Brillpower batteries fit much better and the Ijoy is a far superior 26650 that acts much like an 18650 as far as sag. I have run the battery below 25% without issue. -
I was getting week battery with the Efest 26650 ( green & purple) at around the 45% mark. I purchased the Ijoy 26650 and haven't had a problem since. This battery has much less sag than the other 26650 it acts much more like an 18650.
High room temp after battery changes
Droopydroors replied to mrcrunch08's topic in DNA 75 Color and 100 Color
Curious as to what your results are for both case thermal and resistance could you possible take a snap shot? Thanks. -
Room temperature always wrong.
Droopydroors replied to Droopydroors's topic in DNA 75 Color and 100 Color
I have added a room temperature to the theme but can't figure out how to make it adjustable. So when it acts up I can manually correct it. Can this be done? -
Hcigar DNA75c The room temperature is always above 100F. Ran case analyzer still too high. Used thermal from phils review still at 100F. Used thermals from phils video that he said he worked with evolv with still 100f. What's going on? This causes the device to be run in the 500F range to get a decent hit.
Re-reading atomizer HCigar VT75C
Droopydroors replied to cloudednine's topic in DNA 75 Color and 100 Color
On most of the themes you can just select the ohm symbol and it will re-read the resistance. -
No one know the answer?
Or do I need to add an extra wire to the component board so there will be 2 ground wires?
This up & down button component only has 3 wires for both buttons. When I solder it on to the DNA60 board do I put the down wire in pin 1, the up wire on pin 6 and run the ground to pin 8 and leave pin 2 and pin 5 open? Sorry if this is a stupid question but im just playing around and want to make sure. Thanks in advance.
Hcigar vt200 unresponsive after it goes into hard sleep
Droopydroors replied to JAYRODDC's topic in Report a Bug
I had no problem with evolv replacing my board that had this problem. -
These are 3x26 NiFe52 core with Nichrome 80 alien wrap. TCR is .0039 ohm at .04. I have them set at 200 watt preheat at 450f. These hit as though the are running regular wattage mode until they start getting dry and then it drops down. Simply perfect. They stick on temp in device manager as well if not better than Ti.
I had to send mine back and they replaced it. Never found out the cause. I would start a ticket.
Vape quality and hit change after wake up.
Droopydroors replied to HybridFGSI's topic in DNA 200 and 250
Here is another possibility. Ive noticed if in escribe I have a profile set to 420f. Then when using the device I bump up the degrees to 480, through the mod ,when I switch batteries (hard reset) the temperature goes back to the 420 that was last set in escribe. So is it possible that when the device sleeps and gets woken up it reverts back to the stored temp of 420 even though the screen is showing the temp you bumped up to? Just another guess. -
I see the same issue quite often with it. Next time it happens either unplug the battery if possible or do a hard reset in escribe. That seems to fix the issue for me. For some reason I was thinking that maybe if you wake the device when it is doing a refinement it causes this issue. Just a guess. Because of this issue I always lock in my cold resistance so then it will not refine when sleeping. Seems to be constant when I do this. -
There is a significant shortage of them at the moment, so you are out of luck for a while. Some folks are working on sourcing an alternative, so stay tuned.[/QUOTE] Where should we stay tuned?
'Look and feel' - Wattage Increments
Droopydroors replied to KayBe87's topic in EScribe, Software and Firmware
Did u update to the test firmware? -
I made it habit to save all settings after building a DNA device so as if I make the same mod again I can upload those settings without running the tests.
I use Fatdaddy vapes 510. Is this considered a decent 510 for temp with the dna200? If not what should I be using. Or I guess which one is the best to use in a 3d printed box?
