Podunk Steam
Everything posted by Podunk Steam
  1. A brief run with Cinnamon Desktopped CatchyOS and SP69 INT GTK Test2.run looks pretty sweet although I didn't go into great depth.
  2. In LM 22 load Software Manager In Software Manager, search for Synaptic If it's not installed, install it. Search Synaptic for your dependencies, check the box, click apply, confirm with another click on apply and it should load.
  3. SetupEScribe2_SP67_US looking very sharp on MX Linux 23.6 AHS.
  4. Older mod, but it's still functional after a few battery door repairs. The springs for the battery door catch are an odd thing to fabricate, although I've managed the task a few times. I thought I'd check to see if there may be some metallic 3D prints or parts that are still out on the market?
  5. A Linux phone would be a thought, but I doubt I'll personally go any further than the thought.
    Before I go too far, this is from a Linux perspective, LMDE6 running SP57 on this system in conjunction with a DNA 75C. So far "day2ish, a couple of hours of total tinkering", I've found this theme to be slightly counterintuitive with the Xs and Checks of the indication boxes but easily comprehended and adapted to. I've managed to make a few adjustments for the old aging four-eyes, with adjustment texts switched to red text and adjustment highlights in a brighter shade of green than the near matching blue to the black background. My only real shortcoming with this very well-prepared and configured landscape theme is my inability to add decimal incremental adjustments to the profile screen itself in the theme designer. Could be a Linux glitch, I really haven't dabbled enough to know all the ins and outs. In the atomizer screen, I have managed to add the decimal integers, so the functionality is in place for my oddball MTL wires being used for direct lung vaping. Outside those few points, this theme is by far one of the more appealing themes I've used, without question, and I've been through more than just a few. Excellent use of space allotted with bold texts, wide scope of functionality and visually appealing.
  6. Any suggestions, I mean besides some new 10 amp Sanyos? https://ibb.co/LN8Vt0j
  7. Just checking in with a minor scaling issue in the monitor display section of the latest internation Linux release. Kind of a blast from the past as I've looked around a bit and didn't find an option for resolution, pun intended. I'm using LMDE6 on this rig, the monitor is completely functional, just the scaling is off a little, likely because I use fractional scaling at 150%, old guys eyes. No biggy really, just a heads-up. Picture link https://ibb.co/0VDPZwQ
  8. Your picture helped me out in a huge way, Bill! My hyperion was sitting for months until moments ago. A pocket knife blade between the button's house and the body of the mod with a little friendly persuasion in a few areas to break loose the adhesive and the actuator plate released. After trimming the broken plastic "spring" parts away (the two small legs from both sides), I used about half a drop of contact adhesive to glue the plastic actuator that broke away to the interior of the switch's plate and we're back in business. Thank you sir!
  9. I thought I'd take another run at an MX Linux install being it's Debian based with SP50us, it didn't fly and SP50int didn't either. I checked all the prerequisites which were already installed, gave the .run file permission through properties and Gdebi-gtk said (Could not open 'SetupEscribe2_SP50_US.run') same with SP50_INT Said something about the file could be corrupted or I don't have permission... I do have administrative permission and was signed in. As many years as I've used Linux (since Ubuntu 9.1) I should understand the Terminal prompts better than I do but I don't. Got script? I'm not the VM type and already have Escribe on this notebook in the Linux Mint 20.2 drive so it's no big deal, just doing a little testing with the possibility of convenience in not rebooting while I'm in MX Linux drive. Edit: I went looking for terminal prompts and finally got Escribe installed on MX Linux " MX-19.4_x64 patito feo" the information I found was on YouTube, try at your own risk!
  10. Thank you for the reply! LMDE 5 is different as it's Linux Mint "Debian Edition" where most or all Linux Mint distros are Ubuntu based. I've been using Escribe on Linux Mint Ubuntu versions for quite a while. Ubuntu is getting a bit bloated for older slower system and Debian is generally very stable and fairly light weight is my reason for the interest. I have read of the new Debian installer thanks to @James again which I may have to make a run at once my RAM and SSD arrive. Yep me buying DDR2 in 2023, go figure! LOL!
  11. Checking in to see if anyone has installed on Linux Mint LMDE 5 yet? I haven't even test driven it yet. My old desk top is now my entertainment center server temporarily and Evolv Escribe might be a nice option. Sep. 2008 built HP Pavilion Dual Core Pentium E2200 boasting a whole 3GB DDR2 RAM, same old 500GB HHD. Yes, if it were butterfly inter-netting they'd all get away!
  12. The X470 may be worth researching as there have been issues with both Microsoft and Linux related USB ports acting janky. This is one of numerous reports.
  13. I won't be able to follow up any time soon but did you start with the simple stuff like making sure you're using a good data cable? Check the USB with another data device? It's been quite a while since I have had to designate USBs with any Linux distro, that's going back to the 9.x Ubuntu distros thinking about it.
  14. Looking sharp! My Mint theme was adopted with this update.
  15. I've had no issues with this theme. I didn't go through every wire profile but 316 and NI worked fine for me. The puff counter is on the Replay display. There is a slight counterintuitive nature being settings are changed while highlighted but that's no real issue. It works well. https://i.ibb.co/1d5Tzwp/20210908-231354.jpg Jealousy in the air? Amimosity maybe?
    Nice! I like the contrasting colors and the battery bar graph update doesnt stress my aging eyes.
  16. I've just updated a Linux laptop with 20.1 Mint Cinnamon and installed Escribe. I've done previous installs of Escribe that have taken on my computers theme, I'm a dark theme type, this time my computers theme was not adopted by Escribe. Am I asking for trouble trying to incorporate my computers theme?
  17. No sweat! The only reason I bought this mod was it looked to have the potential for this swap if the original circuit didn't pan out for me. The only other part that's a little tricky is widening the bed for the display. It seems to be a pretty soft ABS plastic and can be carved with a knife easily. I did just that, took my time at it with a knife, that was the longest part of the process.
  18. One part of the assembly was missing in the video, sliding the circuit board and plastic parts into the mod body. With the dust protection for the display and silicone button gaskets this can be frustrating. The scotch tape trick works well here. A piece of scotch tape a little more than three times the length of the height of the mod folded sticky side to sticky side with no wrinkles makes for a reasonably good tool for the process. Similar thin plastic that won't stretch or tear will work too, scotch tape is just a common household Item. Slide your folded tape through the mod with a little sticking out the 510 end, as you slide the circuit board and plastic parts in the tape will help your parts slide through the mod body until the parts are near their final position. Once near the final position, hold the plastic parts at the battery entry end and pull the tape out from either end. I pulled mine out the 510 end of the mod.
  19. Fine job you're doing sir. The video I posted isn't mine. I believe the gentleman's name is Stuart and he's over the other side of the pond.
  20. I guess I should have mentioned the 14 was on my own accord, thanks retird! Just got to make things interesting ya know. 😉
  21. 14 gauge is a bit much for the battery leads IMHO, 16 will save you some effort. Done deal.
  22. You're a good man Wayneo! Gotta bite that PP bullet I guess. A guys just feeling kinda cornered these days ya know.
  23. Thanks Wayneo! Being electronics I'd hope to manage this state side honestly, I'm not saying what I'm putting it into. 😉 I may have blazed through Stealthvape already and only seen the large screens if memory serves me. I was wrong, Stealth does have them in stock.
