Rob_H
Everything posted by Rob_H
I think I heard something like that somewhere. Makes sense no need for a 200 when you have a 250 that does all the same things just more powerful.
Was suppose to be here yesterday but the mail is late cause Christmas I think but should be early next week. The price was really good and considering it wont be used in a commercial application just for my occasional needs it should be fine I think.
Good to know thank you. I got a rework station coming pretty excited about that. I was worried about tackling this there is allot work to do on the daughter board. Here is the one I got what do you think? http://www.ebay.com/itm/like/131713244885?lpid=82&chn=ps&ul_noapp=true
Thanks for the pics I am going to be doing the same this takes the guess work out of it.
I hope its soon really want to get my hands on a couple.
Ive the same idea for my RDNA. Lots of de-soldering though from the daughter board but would be worth it for the Zip charging.
So how did you wire inside the device to run a 5amp charger. Are you still plugging into the stock location or did you run a remote usb. edit: I see the plug now in the first image.
You can remove it and use the remote pads for a new switch. It will not affect anything.
Thats cool I like it
I seen that one its pretty nice. I was asking about the Evolv DNACustom mods if any have been sent out yet. I am guessing no.
Anyone have one yet, or are their any mechanical drawings available? Sure would like to see one to make my mind up on getting one.
Impressive I really dig the brass did you mill it yourself?
First I have heard of it and have not seen anything on their page about it.
Dna60 in a Reference mod enclosure with a bottom trap door for 18650 replacement. Same kinda system that the Hana Modz V4 has. No caps to unscrew you just push back a lever and the door pops open.
My wants for what this mod are the Dna60 in a Reference case and removable 18650. That would be pretty awesome, super small and be able to swap cells easily.
Its really good I think. The flavor is not as good as my Kayfun 5 but for something with a decent amount of airflow its nice. I have a 30g over 26g Ni80 clapton 5 wraps 2.5mm @ .60ohms running in it now and its pretty decent. Its easy to fill too I have not had to close the air off in it with no leaks.
That is very far from the truth and I myself have had a Dna200 failure. I also have had two SX failures with one that was never resolved and never received the board back. Evolv products are very reliable and your issue is a rare one as far as I can see. If your are so inclined to do so you could pull the board and send it into Evolv. They will repair or replace it I am sure. The other option is sending that mod to wherever they have warranty work which could be China? Here is where to contact Evolv https://helpdesk.evolvapor.com/index.php?a=add
That is the same as the Reference mod used wasn't it? I would expect them to be the same as those were even the Dna60 but that one would have a different button lay out.
Can you hook it up to Escribe and check the settings on your SS profile and maybe upload a screen shot. And are you locking in the resistance of the atomizer?
I have seen it done on various different mods not necessarily a Vapor Shark but it could work. Found a pic with my Googlefoo http://imgur.com/gallery/B6ft5
Extensions should be available just as easy as the screens are and will have a part number on them also. Contacting MIT could be the easiest way letting them know what is needed. I am sure they are available.
Can you get us the part number off of your screen. The pic ive uploaded shows where to find it. It most likely came from MIT and you may get lucky and they be in stock. http://www.multi-inno.com/oled.asp
