MAHBUB Posted July 6, 2020 Report Share Posted July 6, 2020 Motherboard : evolv dna 250 Device: hcigar vt250 After change battery charge not increasing. What to do? Please help me. Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 6, 2020 Report Share Posted July 6, 2020 Could you post a snippet of Device Monitor showing the cell voltages? Like this one> Link to comment Share on other sites More sharing options...
MAHBUB Posted July 6, 2020 Author Report Share Posted July 6, 2020 Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 6, 2020 Report Share Posted July 6, 2020 Device monitor shows that it is charging at a rate of 0.28 amps so it is charging but slowly. Try a different cable and\or power source. Check to see if USB port on the mod has dirt/lint in it. Your cells are slightly unbalanced but I don't think it's affecting charging but perhaps it is. Do you have access to a stand alone charger? If so charge them that way and get them balanced and see if that helps. Charging with data connection max is 1 amp and without data connection max is 2 amp. Link to comment Share on other sites More sharing options...
MAHBUB Posted July 6, 2020 Author Report Share Posted July 6, 2020 1 hour ago, dwcraig1 said: Device monitor shows that it is charging at a rate of 0.28 amps so it is charging but slowly. Try a different cable and\or power source. Check to see if USB port on the mod has dirt/lint in it. Your cells are slightly unbalanced but I don't think it's affecting charging but perhaps it is. Do you have access to a stand alone charger? If so charge them that way and get them balanced and see if that helps. Charging with data connection max is 1 amp and without data connection max is 2 amp. I try with different charger different cables... result is same... now will try to stand alone charger... lets see... thanks brother for your quick response & co-operation Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 6, 2020 Report Share Posted July 6, 2020 After looking at your Device Monitor snippet I see now what I missed earlier. Your cell #1 is 4..2 volts, that is full charge. Therefore the charger is balancing the cells and that's a bit of a slow process. After you bring all 3 up to 4.2 volts I suspect your problem will be gone. Let us know how it goes. Link to comment Share on other sites More sharing options...
MAHBUB Posted July 6, 2020 Author Report Share Posted July 6, 2020 37 minutes ago, dwcraig1 said: After looking at your Device Monitor snippet I see now what I missed earlier. Your cell #1 is 4..2 volts, that is full charge. Therefore the charger is balancing the cells and that's a bit of a slow process. After you bring all 3 up to 4.2 volts I suspect your problem will be gone. Let us know how it goes. How can I deduct which one Cell 1, 2 & 3? is there any sign inside mod Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 6, 2020 Report Share Posted July 6, 2020 Well one way would be to number the cells 1 ,2,& 3 with a marker and change their position in the sled and then look at Device Monitor and see where they moved to. Note the voltages of the cells first so you can discern which is which. Other wise you would have to check how the sled is wired to the balance tap on the bottom of the board....too hard. Link to comment Share on other sites More sharing options...
MAHBUB Posted July 6, 2020 Author Report Share Posted July 6, 2020 42 minutes ago, dwcraig1 said: Well one way would be to number the cells 1 ,2,& 3 with a marker and change their position in the sled and then look at Device Monitor and see where they moved to. Note the voltages of the cells first so you can discern which is which. Other wise you would have to check how the sled is wired to the balance tap on the bottom of the board....too hard. I've another 2 batteries with one extra mod... I'll charge all batteries by that mod... then it will be very more easy Link to comment Share on other sites More sharing options...
retird Posted July 6, 2020 Report Share Posted July 6, 2020 May I inject one note: When using 3 batteries in series they should be married and only used together. They get charged together and used together. Don't use in another device unless it uses 3 cells also. Link to comment Share on other sites More sharing options...
MAHBUB Posted July 6, 2020 Author Report Share Posted July 6, 2020 4 minutes ago, retird said: May I inject one note: When using 3 batteries in series they should be married and only used together. They get charged together and used together. Don't use in another device unless it uses 3 cells also. that is the main problem stars I changed 2 batteries from my another mod to 3 cell's mod. now can not recognised which 3 one I should use... seeing all same Link to comment Share on other sites More sharing options...
Wayneo Posted July 6, 2020 Report Share Posted July 6, 2020 Here's me injecting one note. When you're all done figuring out what batteries you're gonna use, use the 'watt hour calculator'.Yours currently shows 9Wh, and that's usually about right for 1 new high quality battery Link to comment Share on other sites More sharing options...
