Dusty1337 Posted April 15, 2019 Report Share Posted April 15, 2019 Okay guys so here goes. I bought this Orion a few months back and I'm having a wattage issue. My wattage setting is at 15 watts. Battery voltage and level are 95% and 4.1v. I should be getting a nice 15 watts hit right? Instead it peaks from the start a 2 watts or so and drops down to one. I used escribe to get a .CSV file I'll include in the post. Please and I million thank yous in advance for any help you can give. low fire wattage.csv Link to comment Share on other sites More sharing options...
cool2019 Posted July 9, 2019 Report Share Posted July 9, 2019 在 2019/4/15 在 AM8點05分, Dusty1337說: Okay guys so here goes. I bought this Orion a few months back and I'm having a wattage issue. My wattage setting is at 15 watts. Battery voltage and level are 95% and 4.1v. I should be getting a nice 15 watts hit right? Instead it peaks from the start a 2 watts or so and drops down to one. I used escribe to get a .CSV file I'll include in the post. Please and I million thank yous in advance for any help you can give. low fire wattage.csv me too low fire wattage1.csv Link to comment Share on other sites More sharing options...
James Posted July 9, 2019 Report Share Posted July 9, 2019 What is the resistance of the coil? Go to the Mod tab and click Atomizer Analyzer to see. You'll need to set EScribe to at least Advanced mode (Options -> User Interface -> Advanced). What is the coil rated at? There it looks like it's at about 0.67 Ohm. Link to comment Share on other sites More sharing options...
cool2019 Posted July 9, 2019 Report Share Posted July 9, 2019 4 小時前, James說: What is the resistance of the coil? Go to the Mod tab and click Atomizer Analyzer to see. You'll need to set EScribe to at least Advanced mode (Options -> User Interface -> Advanced). What is the coil rated at? There it looks like it's at about 0.67 Ohm. Thanks for reply what should I do Link to comment Share on other sites More sharing options...
Wayneo Posted July 9, 2019 Report Share Posted July 9, 2019 @cool2019 Your file contained 'no puff data'. What is the current resistance of the coil? Link to comment Share on other sites More sharing options...
cool2019 Posted July 10, 2019 Report Share Posted July 10, 2019 (edited) 謝謝你的幫助 13功率設定後,泵功率僅為13功率 15個 電源組,僅13個電源 17個 電源組,僅13個電源 低火瓦數2.csv Edited July 10, 2019 by cool2019 Link to comment Share on other sites More sharing options...
Wayneo Posted July 10, 2019 Report Share Posted July 10, 2019 @cool2019 That's the best you're gonna get from those unsupported pods. Link to comment Share on other sites More sharing options...
cool2019 Posted July 10, 2019 Report Share Posted July 10, 2019 (edited) So 0.25 & 0.5 pods will not cause this problem? Thanks answer Edited July 10, 2019 by cool2019 Link to comment Share on other sites More sharing options...
Wayneo Posted July 10, 2019 Report Share Posted July 10, 2019 The default values of both those pods are the equivalent of the ranges on store bought coils. Yes you can raise them much higher, but they'll burn out quicker. The DNA GO can output 30 watts, the pods cannot handle that. Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 10, 2019 Report Share Posted July 10, 2019 The maximum voltage output on a Go board is around 3.5 volts, figure from there what resistance is needed to attain up to 30 watts. An Orion DNA pod can barely handle 20 watts with the 0.25 one, less with the .5 Link to comment Share on other sites More sharing options...
James Posted July 10, 2019 Report Share Posted July 10, 2019 If that coil is 0.658 Ohms cold, the limit they have set of 0.7 Ohm will (if it is a temperature-sensing coil) not produce significant vapor. Is it marked as a 0.5 Ohm coil? If so, perhaps you got one that was well outside the appropriate variance. You could try upping the limit from 0.7 Ohm to 0.8 Ohm and see. (At your own risk.) Link to comment Share on other sites More sharing options...
cool2019 Posted July 11, 2019 Report Share Posted July 11, 2019 (edited) Thank you everyone Edited July 11, 2019 by cool2019 Link to comment Share on other sites More sharing options...
