On a Rebel squonk dna 75c , watts works great, replay without saving puff is great ,the problem I'm having is after I "save puff" the check atomizer warning comes on. It's not everytime but enough to drive you mad. I read somewhere a while back before I had this squonker that this was a issue some folks were having but I can't find a fix for it. If anyone knows would you let me know.
 I've tired different rda's, different coils, different batteries.. I've even reset the theme to factory..all to no avail.
I havent figured out if it actually is making a difference but when the check atomizer comes on I unscrew the rda a half turn then retighten, sometimes squonk juice up..and at times it will work..at times,..so I kind of doudt any of this is affecting it ,its probably coincidence.
THANKS FOR ANY HELP  !
1 hour ago, Wayneo said:
IMHO, this could be the 510 connection on your mod. I'd clean the threading and positive pin on it with IPO and make sure it still springy. :hand_splayed:
First, thank you for offering help..its appreciated.
 I cleaned it earlier but did so again to be certain I hadn't missed something. Still getting "ck atomizer" though.
Whats strange is , it functions great in "watts" mode and in "Replay" mode..no ck atomizer warning at all...as soon as I "Save Puff" is when the check warning comes on..not everytime but pretty frequent.
The ohms stays the same if the warning light is on or not.
33 minutes ago, retird said:
Can you take that atty and do Replay/Play on your 250C and see what results you get?
I tried both rda's I'm using with the 75c, on my paranormal 250c's...used replay, both functioned as they should.
I figured out my problem...after inspecting the premade coils I was using I found problems with all of them. I changed them out and the problem hasn't occured again. I would have thought it to be unlikely that several premade coils were bad . Nonetheless the warning has not came back on...fingers crossed though.
I am having a similar issue with an atomizer. I tried many different types of coils and they are not the problem. Maybe your contacts were loose on the coils. When you changed them out they made better contact.
