Wayneo Posted July 6, 2018 Report Posted July 6, 2018 So almost 3 years ago, the creator of steam-engine said this "I don't believe we will ever have accurate standard SS files anyway. It is better to use NiFe or Ti if you want accuracy, IMHO. I suspect that the people using SS adjust to taste and call it good enough - which is fine if that's what you want" 1
Photo Pete Posted July 6, 2018 Author Report Posted July 6, 2018 Interesting. Stealthvape recommend the Steam Engine file for their wire. Are you suggesting this recommendation may be wrong and a higher TCR might be required? Is Ti the best option to try and calibrate to? Still seems odd that arctic fox consistently handles the Steam Engine SS316L file in a more expected manner.
Photo Pete Posted July 6, 2018 Author Report Posted July 6, 2018 So my ticket has suggested I return the mod to Evolve for what could be a resistance reading problem. I am to ship the mod from UK to USA at my own cost and the terms and conditions state they hold no responsibility for any damage caused during the repair. They’re kidding right? On that basis I’ll be returning it to the vendor in the UK for a full refund and use the money to buy another brand that works.
retird Posted July 7, 2018 Report Posted July 7, 2018 Evolve warranty covers the board only for 1 year.... they do a very good job of repair but surely you understand their warranty only covers the board... I guess you could just ask them to let you send only the board..... vendor replacement with a new Paranormal 250C may be your best bet....
WingedLion Posted July 8, 2018 Report Posted July 8, 2018 I just got my Paranormal back from Evolv with a new board and it still has the same problem, I'm guessing they're going to have to fix the firmware because a new board doesn't fix the problem.
Photo Pete Posted July 8, 2018 Author Report Posted July 8, 2018 On 7/8/2018 at 9:49 PM, WingedLion said: I just got my Paranormal back from Evolv with a new board and it still has the same problem, I'm guessing they're going to have to fix the firmware because a new board doesn't fix the problem. Expand Sorry to hear that. Maybe this is a hardware problem with the Paranormal rather than a board or firmware problem? It would be a little ironic for me if it turned out to be a faulty 510 connector in the Paranormal, as a poor 510 connector is why I ‘upgraded’ from my much cheaper Wismec Reuleaux RX Gen 3.
WingedLion Posted July 9, 2018 Report Posted July 9, 2018 On 7/8/2018 at 11:28 PM, Photo Pete said: Sorry to hear that. Maybe this is a hardware problem with the Paranormal rather than a board or firmware problem? It would be a little ironic for me if it turned out to be a faulty 510 connector in the Paranormal, as a poor 510 connector is why I ‘upgraded’ from my much cheaper Wismec Reuleaux RX Gen 3. Expand One improvement of the new board is if you turn off deep sleep, then it works as it should. The old board turning off deep sleep didn't make a difference.
WingedLion Posted July 9, 2018 Report Posted July 9, 2018 On 7/9/2018 at 1:50 PM, retird said: And how does one turn off deep sleep? Expand By turning off automatically lock when idle
retird Posted July 9, 2018 Report Posted July 9, 2018 On 7/9/2018 at 4:23 PM, WingedLion said: By turning off automatically lock when idle Expand hum.... I always thought the lock feature was different than the sleep feature......
WingedLion Posted July 9, 2018 Report Posted July 9, 2018 On 7/9/2018 at 5:33 PM, retird said: hum.... I always thought the lock feature was different than the sleep feature...... Expand It still goes to sleep but doesn't lock when asleep.
retird Posted July 9, 2018 Report Posted July 9, 2018 On 7/9/2018 at 5:46 PM, WingedLion said: It still goes to sleep but doesn't lock when asleep. Expand Don't think it is going to sleep but the display is turning off as it does automatically.... Deep sleep on all DNA's I've had only kicks in after a long period of non-use. It is designed to save battery during long periods of not being used (such as setting on the shelve) .... The sleep function was never user adjustable as far as I recall.... The lock feature was set up to disable the buttons to be more pocket friendly...
WingedLion Posted July 9, 2018 Report Posted July 9, 2018 On 7/9/2018 at 5:56 PM, retird said: Don't think it is going to sleep but the display is turning off as it does automatically.... Deep sleep on all DNA's I've had only kicks in after a long period of non-use. It is designed to save battery during long periods of not being used (such as setting on the shelve) .... The sleep function was never user adjustable as far as I recall.... The lock feature was set up to disable the buttons to be more pocket friendly... Expand Oh I see. I guess that's where the problem is. Once it locks, you can't unlock it unless you hook it up to a computer or take the batteries out and put them back in.
retird Posted July 9, 2018 Report Posted July 9, 2018 With auto-lock disabled you should still be able to manually lock and manually unlock the device..... the display will go off after a period of time whether locked or unlocked..... You might try this example to see what you get: Set Lock time to 2 minutes and turn on Auto-lock.... let the device auto-lock and the display go off.... try to unlock...... the device won't go to sleep in 2 minutes so sleep is not a factor in this example..... Now turn auto-lock off and manually lock it and let the display turn off.... then manually unlock it....
DeadMan Posted July 10, 2018 Report Posted July 10, 2018 None of those prevent deep sleep from waking the device once you press a button. It still does not come back to life without hitting the buttons many times. I will have to test it and only press a single button and see if it comes back to life. Maybe it is just taking ages to come out of deep sleep.
WingedLion Posted July 10, 2018 Report Posted July 10, 2018 On 7/9/2018 at 6:30 PM, retird said: With auto-lock disabled you should still be able to manually lock and manually unlock the device..... the display will go off after a period of time whether locked or unlocked..... You might try this example to see what you get: Set Lock time to 2 minutes and turn on Auto-lock.... let the device auto-lock and the display go off.... try to unlock...... the device won't go to sleep in 2 minutes so sleep is not a factor in this example..... Now turn auto-lock off and manually lock it and let the display turn off.... then manually unlock it.... Expand OK I tried that and it seems deep sleep is the problem. I also I see I posted this in the wrong thread by accident. I meant to post in the deep sleep thread.
Wayneo Posted July 10, 2018 Report Posted July 10, 2018 On 7/8/2018 at 9:49 PM, WingedLion said: I just got my Paranormal back from Evolv with a new board and it still has the same problem Expand Hey @WingedLion, so when you said ^^^, were you only talking about your sleep issue?
WingedLion Posted July 10, 2018 Report Posted July 10, 2018 On 7/10/2018 at 9:03 PM, Wayneo said: Hey @WingedLion, so when you said ^^^, were you only talking about your sleep issue? Expand Yeah I made a mistake and thought this was the deep sleep thread when I posted in this thread.
Sternenwolf Posted July 11, 2018 Report Posted July 11, 2018 @Photo Pete Hi … if I understand your "problem" the right way: There is no sensor for temperature in any mod … and not in any atomizer. Temperature Control only concearns the heating wire. If you are using five different atomizers, you will have five different vapes at the same chosen "temperature". If you open or close the airflow, this will change the temperature of the vape … for example ... I am using ArcticFox-Firmware, too … but AF does not make the sensors for resistance or 510 connection in a mod any better - it uses them in a better way to calculate differences of resistence better … and this is called "temperature control" I have a dozen DNA mods and three dozen atomizers - six mods with ArcticFox - and 10 with normal firmware. The vapes are all different if I use a single atomizer at 240 ° C alternately in turns at all mods.
Photo Pete Posted July 11, 2018 Author Report Posted July 11, 2018 On 7/11/2018 at 6:13 AM, Sternenwolf said: I have a dozen DNA mods and three dozen atomizers - six mods with ArcticFox - and 10 with normal firmware. The vapes are all different if I use a single atomizer at 240 ° C alternately in turns at all mods. Expand Hi Is the vape similar when using each of your DNA mods or are they completely different to each other when using the same atomiser / tank? My arctic fox mods all vape similarly with the same tank (minor differences) but the Paranormal DNA mod is COMPLETELY different. It needs around 50F increase in temp to be comparable. What magnitude of difference are you experiencing with the same tank on different mods please?
Sternenwolf Posted July 11, 2018 Report Posted July 11, 2018 @Photo Pete I just tested an OBS Engine II on two Paranormals … same settings - same vape But the settings do not work the same on my Eleaf INVOKE with ArcticFox and 316L-TFR-curve… there same vape at 40°C less On my Wismec Presa with ArcticFox and 316L-DNA-Curve 40°C higher gives the same vape. This ist because no mod has a probe in the atomizer's chimney If you have 10 Mods and only 1 Atomizer, you can trim the 316L-settings on each mod - but if you have 10 different atomizers??? You have only 8 Profiles - and it is a lot of work. Just give it a few more clicks - and temperature is fine. My Ijoy Captains are for my 30mm atomizers - my Therions and Paranormals are for my Kylins and Aromamizer Supreme - my Finders are for my Triple RTAs - my Triades are for some other atomizers - as my old Reuleaux and other older mods. The DNA250C-mods are the best I have ever vaped with - very exact measuring of resistance … and very fine mods. But you can have a very fine vape with non-DNA-mods, too …
joeblowma Posted July 12, 2018 Report Posted July 12, 2018 (edited) I've been sticking mostly to replay mode on my paranormal 250c mostly because I get intermittent anemic (very cool) puffs in TC mode. That said, the closest I've come temp settings wise to ArcticFox on it is using jaquith's v4 ss316L profile. As in, when I use 316L TFR on AF I typically set the temp to 210C with this one atomizer and with the v4 profile I've been setting it to 213C on the paranormal. That isn't to say the temp is particularly accurate with that curve... but that it's where I've become used to it being. I do love my paranormal/DNA 250C board, far far better than the DNA75 I had used previous to it. Here's hoping it lasts a long time and never suffers the "won't wake up" issue 😊 Edited July 12, 2018 by joeblowma
Wayneo Posted July 12, 2018 Report Posted July 12, 2018 @joeblowma As a solid AF user, are you using V4 on both your DNA mods and AF mods, or is that 316L TFR from Steam-engine? So here's where we are; @Photo Pete gets great results with AF and the standard s-e profile (effectively 0.00088). And not so on his DNAs, yet swears by his Joyetech mods as the gospel. @retirdgets great results with his DNAs, and uses a profile (effectively 0.00100) The great DJLSB vapes, publishes 0.00092 Your Jaquith V4 (temp probe tested for his particular spool of UD wire) at 200C/392F is effectively 0.00133 (almost s-e's SS430), and at 250C/482F is effectively 0.001217. At Pete's 470F it would be 0.00123 I'm not arguing with any of you, just standing by every comment I've previously made. 🍻
GHammer Posted July 12, 2018 Report Posted July 12, 2018 (edited) @Photo Pete There is no way any AF capable chipset gives better results than any DNA chipset. Just isn't in the same league. Now, the mods the chips are put into are a different matter. Lost Vape, IMO, has dropped the ball on QC with nearly all their recent mods. Including their Modefined series. Your problem lies with them, not Evolve. I have one of their less than stellar Paranormal 250c mods and find it does odd things from time to time. I work around them as I love Replay mode. I'm actively looking for a new dual battery 250c and when I find it, will retire the Paranormal. Lost Vape is no longer on my list. For your issue, I can partly sympathize. If you are handy, open it up and look at the wiring especially at the 510 connector. Or, exchange the mod for a different one wherever you bought it if still in the return window. Else, bump the temp/use Replay and vape. Edited July 12, 2018 by ShowerHead Clarity
retird Posted July 12, 2018 Report Posted July 12, 2018 On 7/11/2018 at 8:57 AM, Photo Pete said: Hi Is the vape similar when using each of your DNA mods or are they completely different to each other when using the same atomiser / tank? What magnitude of difference are you experiencing with the same tank on different mods please? Expand The vape is similar on all of my DNA devices when using the same tank/atty with SS316L coil. This is across my DNA 75, DNA 75C, DNA 200, DNA 250, and DNA 250C devices. The profiles are set the same in all my devices.
