75c "Replay" update missing feature ??
neX
8 minutes ago, tramog said:
What does checking this condition involve?
Is it related to Replay Mode or is it generic?
I'd say generic, meaning all non-temperature sensing coils after its ticked stop working.
Edited by jackobo
11 minutes ago, tramog said:
So you want to say that if I do a coil in Kanthal this does not work even if I do not use the temperature control but only VW?
exactly, when this option chosen, all say ni80, kanthal coils stop working, dna board says check your atomizer, tested last saturday
t remains a "mystery" about its purpose and why it was inserted under "Ohm Lock Range".
Guess no mystery behind it but physics. All temp sensitive coils tend to change their resistance after heating up and chilling down. So then, to somehow stabilize wattage provided for the coil theres this option there. The fluctuation range will be +-25% max in case of using this option.
  • 1 month later...
On 4/28/2018 at 4:38 PM, Darxtorm said:
I see the feature but it's not allowing me to "record" the box just stays blank. Is it because I'm using Ni80?
Ni80 is not a Temp sensing wire, you need to use SS, Ti or Ni200 to enable replay. if you mix any of these 3 wires with Ni80  or Kanthal.it will also work.
