mactavish Posted March 17, 2018 Report Posted March 17, 2018 I’m using Escribe 2.0 SP12 on MAC. If I recall correctly, in older versions, there was a way to turn off a setting to disable charging when you connect the device via USB to a laptop computer, NOT connected to AC power. When working with a device connected to my laptop, I don’t want it to be constantly draining my OLD laptop battery. I charge my vape batteries in a charger. Thanks!
VapingBad Posted March 17, 2018 Report Posted March 17, 2018 In EScribe for Windows it in Device Monitor - Diagnostics - Disable USB Charging. For 75, 75C, 200, 250 & 250C you can also issue put the following python command in a text file and run it the run script box "ECig['USB Current'] = 0.0", there maybe a serial equivalent.
Wayneo Posted March 18, 2018 Report Posted March 18, 2018 @VB In Escribe 2.0 SP12 on MAC - FYI, it's in the same place as you said. Device Monitor - Diagnostics - Disable USB Charging
mactavish Posted March 19, 2018 Author Report Posted March 19, 2018 I would have responded sooner, but as in the past, certain threads I “follow”, even one like this that I started, and choose “email when new responses”, I don’t receive any email notifications. Regardless, THANKS to you both, I would never have found that setting, since it’s kinda buried in the Device Monitor, which of course one has to manually open that screen, and you have to have a mod connected, so it’s not a setting you can edit just by opening Escribe. It does however STICK, and stays in the last state, after removing and reconnecting the device. Also found you don’t need to save setting back to mod, seems it’s basically a hardware switch that turns USB CHARGING “ON/OFF”, as it’s described. Only issue is, if you choose OFF, you can’t charge the device even from a USB wall charger. I was hoping and thought I vaguely remembered long a go being able to configure a setting that ONLY disabled USB charging when I was working with the device, and once removed from laptop, I could still manually charge from wall USB charger. But I’m probably wrong about that as I doubt the device hardware would have any way to distinguish between a USB wall charge, versus a USB charge running off a laptop battery. It’s still a NICE option to have, to AVOID draining ones laptop battery over long Escribe sessions, one just has to REMEMBER to turn USB Charging BACK ON, in device monitor when you are finished with your Escribe session.
arvelo Posted August 3, 2023 Report Posted August 3, 2023 i need to disable usb charging everytime i connect it to my mac. how can i fix it?
arvelo Posted August 3, 2023 Report Posted August 3, 2023 6 minutes ago, Wayneo said: What chipset in your mod? dna100c - steam crave hadron mini
Wayneo Posted August 3, 2023 Report Posted August 3, 2023 escribe -> mod -> battery tab. Shuts off internal charging completely. Upload settings to mod. 2
executed Posted January 30 Report Posted January 30 I don't see such options on DNA60C (Cthulhu Sentinel). None of mentioned menus exist in my Escribe: "Device Monitor - Diagnostics - Disable USB Charging" ❌ escribe -> mod -> battery tab - Max USB Charge Rate: 1.5 ❌ Please help me locate the menu. Serial command would be OK too. More info: I'm using a ESP32-S2 board trying to read stats from DNA60C by reading it as CDC device. Seems like current/voltage from ESP32 is not enough to make mod become available as CDC device (at least to show charging status). This is why I want to try disabling USB charging.
Wayneo Posted January 31 Report Posted January 31 15 hours ago, executed said: Serial command would be OK too If that feature works on the 60C you can try the serial command u=0 A to disable charging. 1
executed Posted February 2 Report Posted February 2 (edited) On 1/31/2026 at 2:34 PM, Wayneo said: If that feature works on the 60C you can try the serial command u=0 A to disable charging. Unfortunately that didn't work. What also did not work: ECig['USB Current'] = 0.0 The only parameter available out of 3 (current, power & voltage) is voltage (5V in my case) - it's not possible to change that either, only read (understandable though). Dissapointing. I've specifically ordered the most modern DNA board mod in hope all of the features I read on this forum are going to be there. The mod is capable of charging through USB-C, yet you cannot control the USB current unlike older board versions. P.S. regarding not being able to connect board as CDC device ESP32-S2 - it's possible, just had to ground USB-ID GPIO pin for ESP32 talking USB host mode and turn on VBUS GPIO pin so that DNA board wakes up and enumerates itself. Edited February 2 by executed follow-up on ESP32
dwcraig1 Posted February 2 Report Posted February 2 The charger is a separate board for DNA60 and DNA60. Since the charger is not on the board there is no communication. 1
