If you have a DNA250 chip & are looking to build a mod, Here's a link to a really good deal on an enclosure that includes a 3S lipo :)
https://www.ebay.com/itm/HANA-MODZ-DNA-250-200-75-Do-It-Yourself-DIY-Mod-kit-Billet-11-colors/112634727027?ssPageName=STRK%3AMEBIDX%3AIT&var=413073911872&_trksid=p2060353.m2749.l2649
I have bought several of these, the quality is great! The box is all aluminum the 510 is pretty good, He includes every thing you need & it sits a 24mm atty perfectly :)
@Toffi69 I'd download the dna datasheet, and the back pages are the board measurements/details. I'd measure the actuator placements first and screen dimensions to get an idea of what you could be getting into
Good Idea. I found 2 people who did this too. One said it is no problem and everything fits, the other said he had to work on the enclosure to make it fit - mmmh?
Bigger problem is that i cannot find a dealer for the board in Germany and in UK its almost sold out :-(
  • 1 month later...
@STEAMER861               thats the exact box i bought,it is great,but smaller than i thought.i have a few questions since you have done some.first it is ok mounting board directly to the aluminum housing?every thing looks like it will fix like a glove(board is arriving today),except getting the battery and its wires in.that is my main concern.the 510 looks good,doesnt have a ground lug,so i guess solder ground on the threaded portion?any tips you could give me will be highly appreciated.thanks
Yes the board gets attached directly to the Case with included screws, no need for Ground to 510. The board grounds direct to enclosure.
It would have been nice if there was room for a battery connector (XT30) but there is not. A live connection to the battery is ok.
The way I have put mine together is, I pre fit the chip to make sure the buttons work with out any problems. I cut the 510 + wire to size & tin the end.
Make sure there is enough slack in the wire for the spring in the 510 to travel freely.
I put a bend in the screen lead, carefully so it loops back onto it self, this important or the lead will get trapped under the fire button & malfunction.
I put a small piece of foam attached to the board with electrical tape directly behind the screen, this will keep slight pressure on the screen between the board & the back of the screen to hold it nicely in place.
I solder the + - from the battery direct to the board, Carefully put the chip in the enclosure, making sure the screen is in the recesse ( a small piece of tape on the back of the screen helps here) once the board is fitted, I check  the  buttons move freely  & the screen is working & postioned well while holding the chip in with my hand.
If every thing looks good? Connect the board to the enclosure with the provided screws, carefully solder the + 510 wire to the board.
At this point, if all went well just fold the battery into the enclosure & install the included case screws :)
I have done three with 200/250's, all work well :) For the money this makes a very nice mod, that will fit a 24mm atty nicely :)
Hope this helps :)
Edited by steamer861
thanks again  steamer861.all your tips spot on.got it all put together today.works great.i updated firmware in escribe.i was reading a tutorial says to setup the battery info in escribe.must be an old tut cause the mod tab isn't there now.did you have to setup any battery parameters?mine showed half charged when assembled and shows all 3 cells balanced after charging.full charge for pack shows 12.6 though and not 11.1,board temp is  81c
Yes some setup is needed, on the mod tab, sub tab battery,
Choose Lithium Polymer    3 cells
10.54 watt hours
Soft cell cut off 3.09 volts
Electrical Tab     mod resistance = .004
Thermal Tab
Case cooling time constant 339.36
Case heating time Constant   1000
Case Usb Connect temperature rise  8.3
Case Usb Charge Temperature rise 9.84
Minimum Ambient Temperature -20
Maximun Ambient Temperature 110
This is how I have mine setup :)
  • 2 months later...
On 1/29/2018 at 5:48 PM, Toffi69 said:
Hi,
I want to put a DNA 250 chip into a Hugo Boxer Mod which has a simple chip in it.
Has someone tried this yet?
Thank you
Yes, it can be done. I just got a DNA 250 board out of a c2d1 mod and installed it successfully into a Hugo Vapor Boxer Rader mod. It was worth the effort!
  • 3 months later...
On 1/29/2018 at 7:48 AM, Toffi69 said:
Hi,
Thank you
I didn't try that. But I installed Evolv DNA250C board in SXK Boxer Clone. I also have an original Ginger Vaper Boxer DNA250C, but this one came out better.
  • Like 2
20 minutes ago, Spector NS5 RD said:
@AMDtrucking I should have my SXK Boxer clone soon, as well.  Thanks for the pics. I suspected (hoped) it would be a direct replacement for the SXK board. Can you PM me or post some pics of the stock SXK board? Thanks!
OK. No problems.
Because the DNA250C board is longer on the bottom, I milled (with Dremel) a small cavity in the bottom of the case. Also, nonexistent "SELECT" middle button has a hole in it. I filled it up with a little white delrin plug. I made that photo for my Russian friends and marked it in Russian. But I'm sure, you'll understand.   Карман - cavity, Заглушка - plug. Also, DNA250C has one of it's inductive transformers offset to one side, you will need to cut a hole for it in the plastic cover.  Окно - hole in this case. And I'm sure you know how to solder jumpers, on the board, to make it work properly, with two batteries.
Edited by AMDtrucking
  • 9 months later...
