retird Posted December 4, 2017 Report Share Posted December 4, 2017 So what do you mean by " Im really happy about solution " ?? Link to comment Share on other sites More sharing options...
giz_60 Posted December 4, 2017 Report Share Posted December 4, 2017 Hey retird...check out the date in Escribe & the date on my computer in this screenshot...looks like Escribe is reading the date wrong? Link to comment Share on other sites More sharing options...
retird Posted December 4, 2017 Report Share Posted December 4, 2017 That is strange??? Have not seen this before..... I didn't load the theme you guys did and guess what.... my theme shows the same thing..... may be a bug not noticed before??? Guess we all are using the INT version of EScribe....?? I'm gonna load another different ecig file and check it out... Link to comment Share on other sites More sharing options...
giz_60 Posted December 4, 2017 Report Share Posted December 4, 2017 2 minutes ago, retird said: That is strange??? Have not seen this before..... I didn't load the theme you guys did and guess what.... my theme shows the same thing..... may be a bug not noticed before??? Guess we all are using the INT version of EScribe....?? I'm gonna load another different ecig file and check it out... Have you tried changing the date manually on your device yet? Link to comment Share on other sites More sharing options...
retird Posted December 4, 2017 Report Share Posted December 4, 2017 Yes.... I can change date on-device and goes incorrect in Device Monitor.... I'm gonna turn off Internet sync and see what that does... Link to comment Share on other sites More sharing options...
retird Posted December 4, 2017 Report Share Posted December 4, 2017 Turning off Internet sync didn't help.... I can keep 2017 on the device until I run Device Monitor then it goes to 2016.... thinking it's a bug since it happens on multiple different ecig files.... James may want to chime in.... Note: on my device I need to adjust year to 2018 to get it to set at 2017..... gotta go for a few hours.... Link to comment Share on other sites More sharing options...
giz_60 Posted December 4, 2017 Report Share Posted December 4, 2017 9 minutes ago, retird said: . Note: on my device I need to adjust year to 2018 to get it to set at 2017..... I am seeing the same here...really interesting because I have run the Device Monitor on all my 75C's many, many times & have never seen this before.... Link to comment Share on other sites More sharing options...
retird Posted December 5, 2017 Report Share Posted December 5, 2017 I've not seen this before either or just didn't notice it....been away from the house for about 4 hours and date on device stayed @ 2017 while vaping these 4 hours... hook up to Device Monitor and poof it's back to 2016.... EScribe Version 2.0 SP9 with Version 1.1 SP27 INT Link to comment Share on other sites More sharing options...
Floh85 Posted December 5, 2017 Author Report Share Posted December 5, 2017 yeah, that all thigs same to me, haven't seen before too Link to comment Share on other sites More sharing options...
Floh85 Posted December 5, 2017 Author Report Share Posted December 5, 2017 so have tryed to change service pack, back to default. have try other theme, same thing. thing is happend when change date it jumps from 2017 to 2016, dont get it off. escribe have wrong date too. so for me i hate those crazy things Link to comment Share on other sites More sharing options...
James Posted December 5, 2017 Report Share Posted December 5, 2017 Turns out this is an off-by-one error in the real-time clock code affecting the month of December. (If you change your PC clock to another month and then run Device Monitor, it will work in any other month. It's related to PC-synchronized time, not on-device time.) I will be fixing it in the next Service Pack. Thanks for finding this! 1 Link to comment Share on other sites More sharing options...
Floh85 Posted December 5, 2017 Author Report Share Posted December 5, 2017 Ok, thank you. great to can help. Link to comment Share on other sites More sharing options...
Wayneo Posted December 6, 2017 Report Share Posted December 6, 2017 @James You're not gonna believe this. It's Tuesday Dec 5, 8pm. Linking up 3 non 75C devices are now showing December 6. You can check there, or I can give you a printscreen here. One 75, 200, and 250. Link to comment Share on other sites More sharing options...
James Posted December 6, 2017 Report Share Posted December 6, 2017 Ahh, the ECigStats server's timezone is set to GMT. I should probably make it display in the browser timezone. 1 Link to comment Share on other sites More sharing options...
giz_60 Posted December 7, 2017 Report Share Posted December 7, 2017 On 12/5/2017 at 0:42 PM, James said: Turns out this is an off-by-one error in the real-time clock code affecting the month of December. (If you change your PC clock to another month and then run Device Monitor, it will work in any other month. It's related to PC-synchronized time, not on-device time.) I will be fixing it in the next Service Pack. Thanks for finding this! @James,...is this why when resetting the date (yr.) on the device & not hooked to Escribe, when finished it drops it back 1 yr...ie, in order to get it to set the yr. to 2017, am having to set it to 2018 & when finished, it drops back to 2017. Also, each subsequent scroll through the date field will drop it back another yr...2016, 1015, etc.... Link to comment Share on other sites More sharing options...
