9 hours ago, James Bellinger said:
@Magigamix, what device are you downloading settings from? That is not a Linux-specific error. Is it a DNA Go or Reflex by any chance?
Yes !
It is a Tek Division mod: Shred v3, which uses a Dna Go board.
5 hours ago, James said:
I've posted up a version that fixes the bug with DNA Go and Reflex. If that's the problem you were having, it should be fixed now. Let me know :)
God bless.
James
Thank you so much.
I just tested the new version (SetupEScribe2_SP71_INT.run), it fixed the error, now it works perfectly.
Thankyou for your great work James!
Here is my Debian stable / trixie install
$ uname -rms
Linux 6.12.48+deb13-amd64 x86_64
$ cat /etc/debian_version
13.1
# apt install mono-complete
$ mono --version
Mono JIT compiler version 6.12.0.199 (tarball Thu Apr  3 15:13:01 UTC 2025)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
        TLS:
        SIGSEGV:       altstack
        Notifications: epoll
        Architecture:  amd64
        Disabled:      none
        Misc:          softdebug
        Interpreter:   yes
        LLVM:          supported, not enabled.
        Suspend:       hybrid
        GC:            sgen (concurrent by default)
$ wget https://downloads.evolvapor.com/SetupEScribe2_SP71_INT.run
$ chmod +x SetupEScribe2_SP71_INT.run
$ ./SetupEScribe2_SP71_INT.run
(It complains about gtk-3-0 not found but installation completes succesfully)
> > > Connect E-Cig to USb port
$ usb-devices
P:  Vendor=268b ProdID=043a Rev=01.01
S:  Manufacturer=Dimension Engineering
S:  Product=Oxva Pro 2 DNA
Diagnostic information:
Firmware Version: 1.1 SP130.1 INT
Firmware Date: 2025-09-25
Revision Code: 311113088
It works like a charm on my lenovo ThinkPad T420 🙂
Alessandro
@Magigamix, I'm glad it's working for you! Turns out the bug wasn't Linux-specific, and was a rather serious bug! Thanks for reporting it!
@Alessandro D.... Wow, investigating on Debian 13, the installer script is looking for the package libgtk-3-0, which they have renamed libgtk-3-0t64. Also, they've removed the locate program from the default install, which was my fallback in case the package lookup didn't work.  I'm not nearly smart enough to understand the wisdom of Debian, but, I'll change the script to look for libgtk-3-bin. That at least does not appear to have changed. Thanks for reporting this. It will be fixed in the next version. For what it's worth it would have also offered to install mono-complete if you hadn't installed it as well.
ECigStats still seems to be broken. I'll need to investigate that.
  • Thanks 2
Hi James, thankyou for reply. I confirm Debian 13 has flagged libgtk-3-0 as virtual package
# apt show libgtk-3-0t64
Package: libgtk-3-0t64
Version: 3.24.49-3
Priority: optional
Section: libs
Source: gtk+3.0
Maintainer: Debian GNOME Maintainers <pkg-gnome-maintainers@lists.alioth.debian.org>
Installed-Size: 10,3 MB
Provides: gtk3-binver-3.0.0, libgtk-3-0 (= 3.24.49-3)
Depends: adwaita-icon-theme, hicolor-icon-theme, shared-mime-info, libatk-bridge2.0-0t64 (>= 2.15.1), libatk1.0-0t64 (>= 2.35.1),>
Recommends: libgtk-3-bin, librsvg2-common
Suggests: gvfs
Breaks: libgtk-3-0 (<< 3.24.41-1.1), libgtk-layer-shell0 (<< 0.9.0)
Replaces: libgtk-3-0 (<< 3.24.41-1.1)
They removed it from essential "findutils" and packaged in its own optional package, so it is not installed by default.
# apt install locate
Affermative. The package provides libgtk-3-0t64
# apt show libgtk-3-bin
Package: libgtk-3-bin
Version: 3.24.49-3
Priority: optional
Section: misc
Source: gtk+3.0
Installed-Size: 319 kB
Depends: gtk-update-icon-cache, libc6 (>= 2.38), libcairo2 (>= 1.14.0), libgdk-pixbuf-2.0-0 (>= 2.40.0), libglib2.0-0t64 (>= 2.57.2), libgtk-3-0t64 (>= 3.24.49-3), libgtk-3-common (>= 3.24.49-3)
Breaks: gtk-3-examples (<< 3.24.13)
Replaces: gtk-3-examples (<< 3.24.13)
Again, I thankyou for your great work and I look forward to test next version.
As a side note, I succesfully installed Escribe Suite SP71 (INT) on a fresh paravirtualized Debian trixie (Oracle Virtualbox 7.2) with a base system and a minimal X window manager (openbox)
# apt install xorg openbox obconf xdg-utils mono-complete
libgtk-3-bin and libgtk-3-0t64 are dependencies of package obconf (openbox's simple preferences manager) so automatically installed 🙂
Just one note on udev hotplug backend if using a minimal X configuration such as one I reported here. To gain access permissions (without asking interactive password from your WM) to DNA controlled USB device (OXVA XLIM Pro 2 DNA version, in my case)  run this Bash oneliner as root:
# echo "KERNEL==\"hidraw*\", SUBSYSTEM==\"hidraw\", ATTRS{idVendor}==\"268b\", MODE=\"0660\", GROUP=\"plugdev\", TAG+=\"uaccess\", TAG+=\"udev-acl\"" > /etc/udev/rules.d/60-dimension_engineering.rules
or, without backslashes
# echo 'KERNEL=="hidraw*", SUBSYSTEM=="hidraw", ATTRS{idVendor}=="268b", MODE="0660", GROUP="plugdev", TAG+="uaccess", TAG+="udev-acl"' > /etc/udev/rules.d/60-dimension_engineering.rules
Happy EScribing & Puffing !!!
Alessandro
Edited by Alessandro D.
Fix some typos
Normally, the program will recognize that it lacks the necessary permissions and ask for root access to install that rules file if it needs it.. Does pkexec not work for some reason in the setup you are describing? I've made some effort to not require any command line manipulation whatever.
Also, I've updated the installer. It will look for libgtk-3-bin now, and use find instead of locate if it can't find that. (Hopefully.)
Thanks!
God bless.
James
Hi James,
The fallback pkexec textual authentication agent doesn't work (see log and a possible reason at the end) so I reverted to a quick bash onliner.
Most linux desktop environments (GNOME, KDE, LXQT, Mate etc.) have their own graphical authentication user agent preinstalled so EScribe Suite perfectly fits with them.
In my reported minimal configuration (EScribe Suite is started from a controlling terminal such as xterm), openbox could work too in this way but there are some tweaks to do before the Openbox X Session is started
# apt install pkexec lxpolkit
$ mkdir -p $HOME/.config/openbox
$ echo "lxpolkit &" > $HOME/.config/openbox/autostart
$ chmod +x $HOME/.config/openbox/autostart
>>> Start Openbox X Session
$ startx
Here is the log of pkexec's textual authentication fallback agent (EScribe Suite is started from xterm with only pkexec package installed, no lxpolkit)
---------------------------------- < cut here > ---------------------------------
==== AUTHENTICATING FOR org.freedesktop.policykit.exec ====
Authentication is needed to run `/tmp/de-escribe/Grant_USB_Permission.sh' as the super user
Authenticating as: root
Password:
** (process:1904): WARNING **: 04:55:50.418: Got unexpected EOF while reading from controlling terminal.
==== AUTHENTICATION FAILED ====
Error executing command as another user: Not authorized
This incident has been reported.
---------------------------------- < end cut > ----------------------------------
I suspect EScribe should wait pkexec process to get root password from controlling terminal (user has to manually enter it in terminal to be authenticated by polkit) before executing Grant_USB_Permission.sh script
I hope this could help you.
Bye
Alessandro
Added some specs
Hi James,
just a consideration on it from a Debian user point of view and a quick mono runtime debug session
FIX some required library dependencies and their paths
# apt install libwebpmux3
# apt install libwebpdemux2
$ ln -s /usr/lib/x86_64-linux-gnu/libc.so.6 ~/.local/opt/evolv/escribe-suite/components/ecigstats/libc.so.6
$ ln -s /usr/lib/x86_64-linux-gnu/libdl.so.2 ~/.local/opt/evolv/escribe-suite/components/ecigstats/libdl.so.2
$ ln -s /usr/lib/x86_64-linux-gnu/libwebpmux.so.3.1.1 ~/.local/opt/evolv/escribe-suite/components/ecigstats/libwebpmux.so
$ ln -s /usr/lib/x86_64-linux-gnu/libwebpdemux.so.2.0.16 ~/.local/opt/evolv/escribe-suite/components/ecigstats/libwebpdemux.so
In mono debug log (before the process raise an exception and gets killed) I see
Mono: no implementation for interface method Gtk.ITreeModelImplementor::IterNext(TreeIter&) in class A.SPC/ZPC
Mono: METHOD .ctor(A.SPC)
Mono: METHOD GetIter(Gtk.TreeIter&,Gtk.TreePath)
Mono: METHOD GetPath(Gtk.TreeIter)
Mono: METHOD GetValue(Gtk.TreeIter,int,GLib.Value&)
Mono: METHOD IterChildren(Gtk.TreeIter&,Gtk.TreeIter)
Mono: METHOD IterHasChild(Gtk.TreeIter)
Mono: METHOD IterNChildren(Gtk.TreeIter)
Mono: METHOD IterPrevious(Gtk.TreeIter&)
Mono: METHOD YY(Gtk.TreeIter&)
Mono: METHOD YY(Gtk.TreeIter&,int)
Mono: METHOD IterNthChild(Gtk.TreeIter&,Gtk.TreeIter,int)
Mono: METHOD IterParent(Gtk.TreeIter&,Gtk.TreeIter)
Mono: METHOD GetColumnType(int)
Mono: METHOD RefNode(Gtk.TreeIter)
Mono: METHOD UnrefNode(Gtk.TreeIter)
Mono: METHOD get_Flags()
Mono: METHOD get_NColumns()
I don't know if it could be related to broken ecigstats so I hold on your more accurate debug investigation 🙂
'Bye
Alessandro
  • 4 months later...
Normally, Linux EScribe will ask "Would you like to grant permission?".
It won't do this if certain things are missing, but they shouldn't be missing...
Do you have /usr/bin/pkexec?
Is your user in the "plugdev" group? (Does the group exist on your PC?)
Does /etc/udev/rules.d exist? If so, is 60-dimension_engineering.rules present? If so, it's a text file. What does it look like?
Essentially, EScribe uses /usr/bin/pkexec to prompt for a root password, and then adds your user to plugdev and writes the .rules file into /etc/udev/rules.d. It does this because on Linux, by default, a USB HID device can only be written to by the root user.  If /usr/bin/pkexec isn't present on your system, I'd be curious as to why. If there's a solid reason I can write fallback code.
Thanks!
God bless.
James
Great! Out of curiosity, why did your system not already have pkexec? I had thought it was standard on nearly all Linux distributions. Is it a new install?
