The_Vapin_Architect Posted November 30, 2015 Author Report Posted November 30, 2015 Ive been trying and trying to make a TFR for nife30 for the dna200 and I cannot get it to work for the life of me...has anyone had any luck with a TFR for this? Thanks Wire is from stealth and I'm using wizard for stealth..please who has really used this wire on a DNA200?? worked fine on my Mclass with tcr
AGoyer001 Posted November 30, 2015 Report Posted November 30, 2015 While I have not used this wire Steam engine does have it listedhttp://www.steam-engine.org/coil.asp?mat=nife30
Dampmaskin Posted November 30, 2015 Report Posted November 30, 2015 I am using this wire myself, with the Steam Engine TFR curve of course. It works for me. What kind of problems are you having?
The_Vapin_Architect Posted November 30, 2015 Author Report Posted November 30, 2015 Of course I have used steam..it's not working at all in temp, I've tried a basic 26g 7 wrap 3mm spaced and made the TFR...does not work..will burn
The_Vapin_Architect Posted November 30, 2015 Author Report Posted November 30, 2015 I think steam is way off on my build 26g 3mm 7wrap spaced single coil it says my resistance should be about .145?? And when I build it the resistance is close to .5 and settles to .45, and thus is nife30 from stealth and I'm choosing stealth on the wizard
dwcraig1 Posted November 30, 2015 Report Posted November 30, 2015 There are at least 3 NiFe30's available and they all have a different setting, where did you buy yours?
The_Vapin_Architect Posted November 30, 2015 Author Report Posted November 30, 2015 Wire is From stealth
dwcraig1 Posted November 30, 2015 Report Posted November 30, 2015 Sorry, I see that you stated that already in the first post.
The_Vapin_Architect Posted November 30, 2015 Author Report Posted November 30, 2015 I really want to know if someone has actually had this working because I've talked to a lot and they haven't...most say it works fine just use the wire wizard, wizard is definitely not working and want to know if I'm doing something wrong
Dampmaskin Posted November 30, 2015 Report Posted November 30, 2015 I am vaping on the 0.40 mm NiFe30 wire from StealthVape as we speak.In my DNA 200 mod, I use the CSV from the Wire Wizard for this wire.It works for me.The resistance in the calculator was tested by StealthVape and fine tuned accordingly. I do get slightly higher resistance when I build with the wire, but that could be my atomizer. In any case, the resistance does not affect the TFR curve or vice versa.
The_Vapin_Architect Posted December 1, 2015 Author Report Posted December 1, 2015 what do you think 26g Stealth nife30 7 spaced wrap single coil resistance be at?
The_Vapin_Architect Posted December 1, 2015 Author Report Posted December 1, 2015 so the resistance has nothing to do with the TFR? so i dont even have to input a build? just pick the wire and download the tfr and it should be good?
WileE Posted December 2, 2015 Report Posted December 2, 2015 Back in early Sept. Crazy Wire got in a shipment of bogus NiFe 30 & shipped quite a bit out. Not sure were it all went, maybe Stealth got some from same supplier? Ultimately via testing it was narrowed down to most likely be 304SS instead of NiFe 30. Coincidentally your build 26ga 7 wrap @ a .5? would be dead on if it was 304SS??Put a magnet on it. NiFe 30 is magnetic & the 304ss is not.
The_Vapin_Architect Posted December 2, 2015 Author Report Posted December 2, 2015 Thank you cause that's exactly what it is!! Thanks
VapingBad Posted December 2, 2015 Report Posted December 2, 2015 I doubt StealthVape get their wire from those cowboys, they have been in the game much longer and actually know a lot about vaping.
The_Vapin_Architect Posted December 2, 2015 Author Report Posted December 2, 2015 I will be checking if it's magnetic tonight...funny thing is I used the tfr for SS304 cause it was matching the resistance and it was working..thanks again for your help
Daz 7401 Posted December 4, 2015 Report Posted December 4, 2015 F.W.I.W. The roll of .4 I received from Steath Vape UK yesterday is definitely magnetic. I have not had chance to try it yet though.
lexalove Posted December 4, 2015 Report Posted December 4, 2015 Toss-up between Nickel and Stainless... I would be glad I got the Stainless! Pleased you solved the mystery because someone gave me a reel of that same wire a few months back and I think I dumped it I got so frustrated trying to get it to work with the TFR from steam-engine. Now I find out it was stainless it all makes sense.
Dampmaskin Posted December 5, 2015 Report Posted December 5, 2015 As far as I know, the 0.4 mm NiFe30 from StealthVape really is NiFe30. Rob got a huge batch of 0.4 mm NiFe30 custom manufactured.I am using it myself, and it works great for me.[quote]so the resistance has nothing to do with the TFR? so i dont even have to input a build? just pick the wire and download the tfr and it should be good?[/quote]As long as you use one single coil material, then yes, the build is irrelevant to the TCR. The build only affects the TCR if you mix two or more different materials in the same coil/build.
skineedog Posted December 9, 2015 Report Posted December 9, 2015 As long as you use one single coil material, then yes, the build is irrelevant to the TCR. The build only affects the TCR if you mix two or more different materials in the same coil/build.Well, that answers one question I asked in another post a moment ago. So if the build doesn't matter, should the atty make a difference? I am using 3 attys with the same NiFe30 wire from Stealth. One of the attys works fine, as I expect. The other two are bit moody. Starts out hot as hell & tasting burnt. Reaches temp limit almost immediately. If I keep vaping it, the temp settles down and is usable. This is with out changing any settings between switching attys.Hard booting sortta resolves the issue for one of the 3. I have another issue where the mod doesn't recognize the TC wire. Hard booting the mod via escribe ALWAYS resolves this.
