MikeTheVapeDude Posted August 7, 2015 Report Share Posted August 7, 2015 John said:The entire 510 just screws in, it is an M18-.75 thread. So Hana Modz could send me the same 510?And Tom, I pretty much am doing that, but I never tap my 510's.Also, if I unscrew the board, and remove it, what's the process of doing so and then putting it back in? I'm only going to desolder the wire on the stock 510, so once the board is unscrewed, what's on the other side and what's the process of removing and putting it back in like? Link to comment Share on other sites More sharing options...
KTMRider Posted August 7, 2015 Report Share Posted August 7, 2015 Is your 510 broken? I think the Hana 510 is WAY better than a FDV 510. Link to comment Share on other sites More sharing options...
Tomr1088 Posted August 7, 2015 Report Share Posted August 7, 2015 MikeTheVapeDude said:[QUOTE=John]The entire 510 just screws in, it is an M18-.75 thread. So Hana Modz could send me the same 510?And Tom, I pretty much am doing that, but I never tap my 510's.Also, if I unscrew the board, and remove it, what's the process of doing so and then putting it back in? I'm only going to desolder the wire on the stock 510, so once the board is unscrewed, what's on the other side and what's the process of removing and putting it back in like?[/QUOTE] Hardest part is getting the board off and on without damaging the screen as its glued in. U prob can chalk the screen up as a loss Link to comment Share on other sites More sharing options...
Tomr1088 Posted August 7, 2015 Report Share Posted August 7, 2015 John is it possible to replace my Hana 510 with one from the beta? Or acquire one at all Link to comment Share on other sites More sharing options...
John Posted August 8, 2015 Report Share Posted August 8, 2015 Tom your beta unit should have gone out today. Link to comment Share on other sites More sharing options...
KTMRider Posted August 8, 2015 Report Share Posted August 8, 2015 Tomr1088 said: Hardest part is getting the board off and on without damaging the screen as its glued in. U prob can chalk the screen up as a lossIsopropyl alcohol on a q-tip will take that glue off easily w/o damaging anything. I used a piece of closed cell foam with electrical tape reversed and sandwiched it between the screen and board. Link to comment Share on other sites More sharing options...
Tomr1088 Posted August 8, 2015 Report Share Posted August 8, 2015 John said:Tom your beta unit should have gone out today. Oh wow I had no idea. Never got a response back on my help ticket. Thank you so much Link to comment Share on other sites More sharing options...
blueridgedog Posted August 8, 2015 Report Share Posted August 8, 2015 So Hana Modz is still using hot glue? Why? Link to comment Share on other sites More sharing options...
BobC Posted August 8, 2015 Report Share Posted August 8, 2015 Anybody got a cheap Wheel Barrow so's I can carry one of these mods Though I own a DNA200 for testing purposes, Im so hoping for a smaller footprint chip with the same characteristics as the DNA200 (less max wattage, single 18650) so a squonker like me can take part in all this excitement, you just can't build a reasonably sized squonker with this chipAs the owner of almost a dozen DIY DNA 40 devices, the only thing Im missing with the chip is the extended capabilities of setting TCR and other customizations offered by the DNA200, UId be very happy with 40 watts and all this capability Link to comment Share on other sites More sharing options...
MikeTheVapeDude Posted August 8, 2015 Report Share Posted August 8, 2015 Why? What's so great about the preheat function is the access to higher wattages, your coil heats up instantly, and curves out at your base temperature. Useful for nickel claptons and such. Plus 40W never did it for me anyway. Also, the V200 is very small, I don't get the wheel barrow thing at all.. Also, how do you just sandwich that tape in the board and remove the glue?And no my 510 is not broken but it has skimpy little thin threads and I just don't like it. Link to comment Share on other sites More sharing options...
KTMRider Posted August 8, 2015 Report Share Posted August 8, 2015 The glue comes off with isopropyl alcohol and a q-tip. I cut a small piece of foam and taped one end of a 2" piece of electrical tape on it, then wrapped it backwards with the sticky side out so it stays put. The pressure of the foam sandwiched between the board and screen holds it in place and the tape makes sure it doesn't move. The enclosure has a slot milled out for the screen so the display lines up perfectly. Link to comment Share on other sites More sharing options...
blueridgedog Posted August 8, 2015 Report Share Posted August 8, 2015 BobC said:Anybody got a cheap Wheel Barrow so's I can carry one of these mods ...can't build a reasonably sized squonker with this chipI have laid out three squonkers. Currently testing this one:https://www.shapeways.com/product/R52DK7LSJ/dna200-squonker-v2-7?li=shop-results&optionId=57414597How big is too big? Link to comment Share on other sites More sharing options...
BobC Posted August 8, 2015 Report Share Posted August 8, 2015 Well done Blue, the height on that is fantastic, the width is a bit much though for comfortable squonking, which I do exclusively Link to comment Share on other sites More sharing options...
BobC Posted August 8, 2015 Report Share Posted August 8, 2015 My issue is carrying a device in a suit, I can carry extra batteries in my briefcase, but can't put a large device in my jacket pocket (GDNAs fit wonderfully) Link to comment Share on other sites More sharing options...
MikeTheVapeDude Posted August 8, 2015 Report Share Posted August 8, 2015 Bob, are you aware of the DNA200 devices that take only 2 18650's? I heard they cap out at 130 Watts, enough for you, but you could save space if the device is made right. Then again, if you vape such low wattages, an 800 Mah 2S Lipo is TINY, could give you the capped 130 watts and save space. I'm not sure if a 2S Lipo would work, but if two 18650's will I don't see why not..Though I'm not sure of the 130 watts dual 18650 option, but I see a lot of modders offering it as an option so I'm sure it is true. Link to comment Share on other sites More sharing options...
John Posted August 8, 2015 Report Share Posted August 8, 2015 It is 133 watts not 130. Link to comment Share on other sites More sharing options...
MikeTheVapeDude Posted August 8, 2015 Report Share Posted August 8, 2015 John said:It is 133 watts not 130. Would a 2S lipo work? Link to comment Share on other sites More sharing options...
blueridgedog Posted August 8, 2015 Report Share Posted August 8, 2015 MikeTheVapeDude said:[QUOTE=John]It is 133 watts not 130. Would a 2S lipo work?[/QUOTE]Yes Link to comment Share on other sites More sharing options...
BobC Posted August 8, 2015 Report Share Posted August 8, 2015 Still want a single 18650 option, it will suit most single coil MTLers as well Link to comment Share on other sites More sharing options...
Mad Scientist Posted August 8, 2015 Report Share Posted August 8, 2015 Although a single 18650 would be great for "the small mod" there are some small 2S and 3S lipos that come pretty close. If you want a really teeny tiny mod, the DNA 200 might not be the best platform to start with. Get or build a DNA 200 mod to develop and analyze your best coiling and wicking technique, then also have another teeny tiny mod for the suit pocket. As another approach, there are some 18350s where a pair would allow you to go up to about 40 Watts. My understanding is there is some way to set a somewhat permanent limit on the DNA 200 so it wouldn't allow going above a defined power level. Link to comment Share on other sites More sharing options...
monster92 Posted August 8, 2015 Author Report Share Posted August 8, 2015 So I've had my Hana v200 for about 3 days. Everything seems to be working good. The only thing I changed was under battery type in escribe I put in the correct type of WH for battery capacity. Let's hope they've fixed everything. Link to comment Share on other sites More sharing options...
blueridgedog Posted August 9, 2015 Report Share Posted August 9, 2015 Shouldn't Hana Modz be loading out a correct setup of the chip, specifically as it relates to battery? I am confused...are folks saying the chip is coming without having been configured for the battery that they installed? Link to comment Share on other sites More sharing options...
KTMRider Posted August 9, 2015 Report Share Posted August 9, 2015 Mine had all default settings. I had to set the Wh. Link to comment Share on other sites More sharing options...
MikeTheVapeDude Posted August 9, 2015 Report Share Posted August 9, 2015 What would be the WH on the V200? 900Mah is 9.99WH so I assume 950 is 10.545WH? Correct me if I'm wrong. Plus, this has a 1amp charger and it only charges at like .44A Link to comment Share on other sites More sharing options...
monster92 Posted August 9, 2015 Author Report Share Posted August 9, 2015 Yes correct. It even walks your through it. Just put in the Milliamps and 11.1 for a 3S lipo. Can you change the charge rate? Link to comment Share on other sites More sharing options...
