ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 Hi, my reuleaux won't start up when i switch to my 2nd set of batteries. The 3rd battery bay has a problem (when you remove the battery cover the inner left battery is cell 1, the middle battery is cell 2, and the inner right battery is cell 3). The battery installed there keeps giving me 0.85v while the rest of the cells are above 3v.It only turns on when connected to usb but doesn't charge or anything.I tried switching the batteries around but whatever battery goes in cell 3 it reads low around 0.85v.Anyway i could fix this bay?Pictures attached. The positive right connection piece seems to be lower than the left one.
VapingBad Posted December 18, 2015 Report Posted December 18, 2015 There is a white foam plug in the battery bay covering the ground connection from the batter cradle to the board you could try and give the screw a tweak, don't over tighten. It is also one of the connections for the balance connectors for cell 1 so there is more than a good chance it is your problem.
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 VapingBad said:There is a white foam plug in the battery bay covering the ground connection from the batter cradle to the board you could try and give the screw a tweak, don't over tighten. It is also one of the connections for the balance connectors for cell 1 so there is more than a good chance it is your problem.Thanks i'll try itEdit: Didn't work, still not turning on. Thanks though
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 Nevermind. It's the F**king Efest 3000.I put 3 other batteries same brand but not married and it worked fine!!!!!Sorry for the trouble. Befware of the Efest 3000mah batteries with the wismec.
jlmr731 Posted December 18, 2015 Report Posted December 18, 2015 I had a connection problem with a few batteries, i just simply filed down the plastic cup on the positive side. only needed a little bit maybe took a 1/4 of it off and now all batteries work no matter what position they are in.worth a try if your battery is still good
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 jlmr731 said:I had a connection problem with a few batteries, i just simply filed down the plastic cup on the positive side. only needed a little bit maybe took a 1/4 of it off and now all batteries work no matter what position they are in.worth a try if your battery is still good Thanks for your reply, my batteries are Brand new and that's why i would like to have a solution than buy 6 more.I didn't quiet understand what you meant by file down the cup on the positive side; how do i take 1/4 off of it?Could you elaborate? Thanks!
VapingBad Posted December 18, 2015 Report Posted December 18, 2015 The plastic ring around the brass coloured contact on the positive contacts could prevent some batteries making a good connection.
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 VapingBad said:The plastic ring around the brass coloured contact on the positive contacts could prevent some batteries making a good connection.Oh ok, i'll see if i can find a way to do that, not sure what to do it with though I also fear i'd ruin the device.
jlmr731 Posted December 18, 2015 Report Posted December 18, 2015 I just use a small file for most of it, then i used an Emory board (wifes nail file) to get into the harder places, it may not take much and may only need to do it to the cell area thats causing the problem
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 jlmr731 said:I just use a small file for most of it, then i used an Emory board (wifes nail file) to get into the harder places, it may not take much and may only need to do it to the cell area thats causing the problem Great thanks i'll look around and i'll keep it as a last resort and will post here
VapingBad Posted December 18, 2015 Report Posted December 18, 2015 If a thin disc magnet on the positive end of the battery fixes the issue then lowering that ring may be the answer, if not it is something else, but it is a issue some people have and will vary between batteries.
ramzik Posted December 18, 2015 Author Report Posted December 18, 2015 If my other set didn't work at all i'd lower the deck for the positive but because my other set makes a connection i think it's just the bad efest 3000
ramzik Posted December 28, 2015 Author Report Posted December 28, 2015 Turns out it's all about centering the batteries in your device and fiddling with them while have escribe - device monitor on.
Voku Posted December 29, 2015 Report Posted December 29, 2015 If my other set didn't work at all i'd lower the deck for the positive but because my other set makes a connection i think it's just the bad efest 3000https://www.e-cigarette-forum.com/forum/threads/warning-efest-purple-35a-3000mah-is-now-a-10a-battery.720251/[CODE]https://youtu.be/vOLfAQovmGM[/CODE]Batteries only LG HG2 or Sony VTC5 Efast there is no specification of the battery is not a company that produces batteries
ramzik Posted December 29, 2015 Author Report Posted December 29, 2015 Yes i read this article and sadly, i unwrapped my 3 set batteries (efest 3000mah) to find that they have 4 legs on the positive side. I had already bought wraps in case any battery had wrapping issues and re-wrapped all 3 batteries and they work instantly when inserted into the device.I also did the escribe battery analyzer, it took a while but turns out that the 3 efest 3000mah (4 legs) are at 28 watt hours after the test. so i set it to that value. the only scary thing was that after i did the battery analyzer the device was so damn hot as well as the batteries and i had to cautiously open the cover and remove the batteries.I have another set of efest 3000mah but with 3 legs on the positive post.I'm going to do a battery analyzer on those as well today to see how they perform.will update this post with the result.Update: My other 3 efest 3000mah batteries with 3 legs are at 27.5 w/h after battery analyzer test.
Vaportron Posted December 30, 2015 Report Posted December 30, 2015 ramzik said:the only scary thing was that after i did the battery analyzer the device was so damn hot as well as the batteries and i had to cautiously open the cover and remove the batteries. How did you perform this test?
ramzik Posted December 30, 2015 Author Report Posted December 30, 2015 Open Escribe, go to the "mod" tab, click on the last option in the mod page, the rest of the page will open; click battery analyzer. I advise not setting the power to 40w as they advise because if the batteries are bad the device will be toooo hot as happened with me.Unless you know you're batteries are good and they are not efese then 40w is ok Good luck and be cautious. if it got too hot use a fan directed at the device while the test is taking place. it's a long test that will discharge battery to zero.
Spector NS5 RD Posted December 30, 2015 Report Posted December 30, 2015 do not just throw a tank or any atomizer on and run battery analyzer that's asking for trouble. here read this thread first before attempting to run it. https://forum.evolvapor.com/topic/65611-topic/?do=findComment&comment=886989
ramzik Posted December 30, 2015 Author Report Posted December 30, 2015 ChunkyButt200 said:do not just throw a tank or any atomizer on and run battery analyzer that's asking for trouble. here read this thread first before attempting to run it. hang on let me find.I used an RDA, just coils on it.
Spector NS5 RD Posted December 30, 2015 Report Posted December 30, 2015 ya that'll def heat the f... out of your mod. NO GOOD. read through that link i posted
bobjohnson Posted January 6, 2016 Report Posted January 6, 2016 ramzik said:[QUOTE=ChunkyButt200]do not just throw a tank or any atomizer on and run battery analyzer that's asking for trouble. here read this thread first before attempting to run it. hang on let me find.I used an RDA, just coils on it.[/QUOTE]When i read things like this, my own fear of blowing my batteries up lowers drastically... Oh let me just run my 10a efest batteries dry through this coiled rda... jesus christ.
Spector NS5 RD Posted January 7, 2016 Report Posted January 7, 2016 when i run batt analyzer, along with the correct size loops of kanthal, i have a pc power supply fan i gutted from an old pc rigged up and i aim it at the mods battery and vent holes to make sure my batts and board receive some airflow. that's how i do it.
