Brofessor Posted January 31, 2016 Author Report Posted January 31, 2016 Hi, new to the forum and the vaping world in general. Thought i should quit smoking sooner than later. Any ways, as you can see from the title, my vt200 wont power on unless its plugged in. Also throws the "ohms to high" error when it is. So just to confirm, this is more than likely the fuse, since it would only be running usb power causing the ohms to be too high. Thanks in advance.
dwcraig1 Posted January 31, 2016 Report Posted January 31, 2016 It certainly fits with what others have posted.
Brofessor Posted January 31, 2016 Author Report Posted January 31, 2016 Okay, that's what I was thinking. I just now how electronics can be. Now, the other part I don't know, getting it fixed/fixing it. I can't find my torx set so i haven't gotten into yet. Thanks Again.
Brofessor Posted January 31, 2016 Author Report Posted January 31, 2016 Also, have no idea what blew the fuse in the first place. ive been using a herakles plus with the 0.4 ohm kanthol coils. Did use the Ni one for a day, but it worked after putting the kanthol back in.
Spector NS5 RD Posted January 31, 2016 Report Posted January 31, 2016 Brofessor said: Also, have no idea what blew the fuse in the first place. ive been using a herakles plus with the 0.4 ohm kanthol coils. Did use the Ni one for a day, but it worked after putting the kanthol back in. Expand when you plug into escribe, what is your pack voltage and cell voltages?
Brofessor Posted January 31, 2016 Author Report Posted January 31, 2016 11.52 on the pack and 3.84 across each cell. I come from the RC world so im fairly familiar with lipo packs. Kinda what drew me to the vt in the first place
VapingBad Posted January 31, 2016 Report Posted January 31, 2016 It does sound like a fuse, the main power is fused, but the battery monitoring is not, don't leave it plugged in too long as the balancing circuitry will got hot, I am not sure that damage will result just a precaution.
Brofessor Posted January 31, 2016 Author Report Posted January 31, 2016 Thanks guys! Now for the other part. I can solder, but don't trust my self to solder a board. I bought it online and the vendors RMA process is a bit ridiculous. How do you suggest i go about getting it fixed?
blueridgedog Posted February 1, 2016 Report Posted February 1, 2016 You could try the Evolv RMA process.
Brofessor Posted February 1, 2016 Author Report Posted February 1, 2016 Yeah its either going to be that, or I have a buddy who mods. I bought a second hand r80 and its honestly getting the job done in the mean time. So its not a big worry, except for the $100 paper weight I have in the meantime. Thanks again guys. You can go ahead and close this if that's a thing on this forum.
