Not Charging???
greezmky
I purchased an Hcigar vt200 back in October, It crapped out on me in November (screen would not come on, nothing) Retailer said it was the battery. Contacted board manufacturer and they did an RMA. Had to do a battery recovery and all was well, until last night when I noticed that it had not charged in spite of it being on the charger over night. Now I am stuck with a broken mod once again.?
Current situation:
Screen comes on battery indicator does not show bolt (indicating charging)
Screen comes on without battery and is NOT dim (when plugged into computer)
Shows up in escribe
Pack : 4.88 V
cell 1: 1.64 V
cell 2: 1.58 V
cell 3: 1.66 V
battery had more charge but lost charge while plugged into wall charger (1A eleaf)
Charge: 0.000wh
USB Power: 0.079W
USB Current: 0.015A
USB Voltage: 4.814V
I inspected the board visually because I read there was at least one issues with smt resistors falling off near the USB connector, but all is well on my board. I tried battery recovery twice with no luck. I checked for anything else that looked burnt or missing with no luck. I tested the resistance of the four resistors to the right of the USB connector and got about 104 ohms each and the one single resistor to the left ohmed out at 5k
I am concerned that Evolv will not RMA again in such a short time is there anything else I can check?
Your battery is way below what it should be, i wouldnt go poking around on your board with a tester, you may bugger somthing els up, asume it works, because you said it was fine to start with, only test your battery with the multi tester, get your own battery a good quality one from say hobby king, to evolv recomendations aprox 25c constant 50c burst, without looking it up, am on mobile, no point in asking the builder of the mod for a battery you allready know there bad. Its allways going to be swings and rounderbouts, if you build your own mods you save nothing, only that you have the best components, if you buy a ready made mod its going to have some cheap bits on it, to make the money,,,
If I can get my hands on another battery I will try it. What bothers me is that it was working fine and it charged for two weeks just fine. The voltages were all where they needed to be prior to draining down and it still would not charge. I did not solder the battery connector on, Evolv did when I sent in the old board because I did not desolder it.
  • 4 months later...
So I finally got a battery ( Brand New ) rc type (glacier) and it seems to have been a waste of time!!! I am pretty peeved off now. After going through one board and now this WOW!!!! Any Ideas or do I need to contact evolv again? This sucks I am getting ready to leave out and doubt it will be resolved before I leave.
open device monitor and and try a few or bunch of usb recovery charges if the cells are under 2v mark. what are each of the cell voltages this time around with the new pack? total voltage? sucks you're having problems again. no charge symbol when usb is inserted?
Screen comes on battery indicator does not show bolt (indicating charging) I set my charging screen to show each cell, just to see if maybe it was aware that the usb was plugged in. I see all 3 cell voltages when the usb is plugged in but no bolt (I Did turn charge brightness up 100% still no bolt and still the drain while on the charger)
I tried numerous different usb cables and chargers. Plugged it in today to see what would happen and after 8hrs each cell is at 3.7 volts. Numbers below are after 3hrs of messing around in escribe trying to get it to work. It seems to me that it is just plain obvious there is an issue with the board, like others have had??
I did not do the recovery because my cells are not low on voltage or unbalanced. With that being said it is my understanding that it will do nothing for me and I was afraid it could damage the pack.
Shows up in escribe
Pack : 11.45 V
cell 1: 3.82 V
cell 2: 3.82 V
cell 3: 3.82 V
Charge: 6.941wh
USB Power: 0.053W
USB Current: 0.011A
USB Voltage: 4.810V
I can't think of anything else to try except try (save your device configuration first to the drive before continuing):
1) Tools -> Reboot Device -> Soft reboot
2) Tools -> Reboot Device -> Hard reboot
3) Tools -> Update Firmware
Try each of the above and check to see if it is now charging (if you didn't already). And what firmware version are you running on your HCigar VT200 anyway?
