Nick Posted October 19, 2015 Author Report Posted October 19, 2015 The DNA200 uses a 25A onboard fuse that can be found near the Battery + input. It is a small, green, rectangle shaped component that should appear physically blown when tripped.Replacement Fuses can be found here:http://www.mouser.com/Search/ProductDetail.aspx?R=3413.0332.22virtualkey69300000virtualkey693-3413.0332.22In case you need to find and order them somewhere else:Manufacturer: SchurterManufacturer Part #: 3413.0332.22Specs: 25A 63v Max DC Surface Mount Fuse
VapingBad Posted October 19, 2015 Report Posted October 19, 2015 In the UKStealthVape RadioSpares cheaper if you want a few
jurdanas Posted October 20, 2015 Report Posted October 20, 2015 Or farnell.com :http://uk.farnell.com/schurter/3413-0332-22/fuse-smd-25a-1206-slow-blow-full/dp/2136811
dclanz Posted June 20, 2016 Report Posted June 20, 2016 Nice! Thanks for link in case I ever need it, but newbie question...how difficult or rather which tools are required to replace the fuse (it looks super tiny)?
VapingBad Posted June 20, 2016 Report Posted June 20, 2016 Getting the old one off is the more difficult part as you should melt the solder at both ends at the same time, ideally with 2 soldering irons but you could heat tweezers with a gas torch. Putting the new one in is easier, you just do one end at a time.
Spirometry Posted June 20, 2016 Report Posted June 20, 2016 I found it easier to cut the fuse in half with a razor-blade then desolder the ends individually.
BillW50 Posted June 20, 2016 Report Posted June 20, 2016 I never replaced a DNA200 fuse yet, but I mostly use a desoldering pump (aka solder sucker) to remove solder and the component (you need to clean inside of them a lot). Never cared much for soldering wick which wicks solder up into the braid of flat wire. I'll use it if I have too. But my favorite for removing solder is a vacuum desoldering station. Oh I wouldn't buy one of those cheap soldering irons with a rubber ball that is suppose to vacuum up solder. Those just gets you frustrated more than anything else.
Spector NS5 RD Posted June 21, 2016 Report Posted June 21, 2016 BillW50 said:I never replaced a DNA200 fuse yet, but I mostly use a desoldering pump (aka solder sucker) to remove solder and the component (you need to clean inside of them a lot). Never cared much for soldering wick which wicks solder up into the braid of flat wire. I'll use it if I have too. But my favorite for removing solder is a vacuum desoldering station. Oh I wouldn't buy one of those cheap soldering irons with a rubber ball that is suppose to vacuum up solder. Those just gets you frustrated more than anything else.lol those ones with the turkey baster on top of the soldering pencil. garbage. you gotta have the spring loaded sucker, they work the best for me at least. desoldering braid works well for me too but i'm not fond of the constant heat you have to apply to the part to get the braid to work.
dclanz Posted June 21, 2016 Report Posted June 21, 2016 I can see the fuse (lower right corner), but it looks white so I'm guessing that it's blown. https://goo.gl/photos/bEYiyVMoLjoWUDZd8
dclanz Posted June 21, 2016 Report Posted June 21, 2016 Ah thanks! Looks like I'll have to invest in a couple of fuses later on.
e30Birdy Posted May 26, 2017 Report Posted May 26, 2017 What is the difference between SCHURTER 3413.0332.22 and the SCHURTER 3413.0332.11?
