WTVapes Posted June 20, 2016 Author Report Posted June 20, 2016 My wifes dna 200 will only come on when i have it plugged in to escribe and will not read an atomizer if someone could help me out. Hopefully i want have to get another board but if i do i do
dwcraig1 Posted June 20, 2016 Report Posted June 20, 2016 Generally when it only comes on when plugged in with the usb the fuse has blown.What does it show in EScribe for pack and cell voltages?
WTVapes Posted June 20, 2016 Author Report Posted June 20, 2016 it is 22.2WH and it 2-cell and it is not reading an atomizer could the fuse cause that too?
Spector NS5 RD Posted June 20, 2016 Report Posted June 20, 2016 WTVapes said:it is 22.2WH and it 2-cell and it is not reading an atomizer could the fuse cause that too? dwcraig1 is asking what each of the cell voltages and pack voltage is. In escribe's device monitor. And yes if the fuse is bad it will not read your resistance.
WTVapes Posted June 21, 2016 Author Report Posted June 21, 2016 cell1-4.12V, cell2-4.12, pack is 8.24V
Spector NS5 RD Posted June 21, 2016 Report Posted June 21, 2016 WTVapes said:cell1-4.12V, cell2-4.12, pack is 8.24Vso you are able to connect to escribe and see your voltages in device monitor? is it displaying the correct 'pack' voltage?
dwcraig1 Posted June 21, 2016 Report Posted June 21, 2016 So does EScribe add up the voltages from the balance tap or is it read off the power side to get pack voltage? This is something I'm unsure about.
dwcraig1 Posted June 21, 2016 Report Posted June 21, 2016 dwcraig1 said:So does EScribe add up the voltages from the balance tap or is it read off the power side to get pack voltage? This is something I'm unsure about.I'll answer my own question as well as the poster's.Here's what I did, I removed the battery from my DX 200 and plugged it into EScribe.No cell voltage, no pack voltage listed in EScribe.Next I plugged just the balance connector from a loose balanced lipo into the DX 200It read pack as well as cell voltages in EScribe but appeared unbalanced..BTW it showed charging which I really didn't expect.The loose lipo was checked for balance with a meter.So with a blown fuse pack voltage will still be shown in EScribe.@WTVapes it appears that your fuse is gone.
BillW50 Posted June 21, 2016 Report Posted June 21, 2016 My Hotcig DX200 v2 shows the following when I unplug my lipo.Pack: 2.91vCell 1: 0.01vCell 2: 1.35vCell 3: 1.56vWith a low lipo it reads:Pack: 11.23vCell 1: 3.75vCell 2: 3.75vCell 3: 3.74v
dwcraig1 Posted June 21, 2016 Report Posted June 21, 2016 Did you dis-connect the usb for each step?Is that with the balance connector in?
BillW50 Posted June 21, 2016 Report Posted June 21, 2016 No I didn't disconnect the USB. If you did, it disconnects from EScribe. And the DX200 you really can't just disconnect the balance connector alone very well without making a test cable or disassembly.
dwcraig1 Posted June 21, 2016 Report Posted June 21, 2016 BillW50 said:No I didn't disconnect the USB. If you did, it disconnects from EScribe. And the DX200 you really can't just disconnect the balance connector alone very well without making a test cable or disassembly.I had an extra lipo sitting hereOne of those Lion Power 1800's of an earlier topic...LOL
BillW50 Posted June 21, 2016 Report Posted June 21, 2016 Oh yes, well the only 3S lipos I have are the DX200 ones.
BillW50 Posted June 21, 2016 Report Posted June 21, 2016 So with just the balance connector connected, how does the DNA act? Does it read the pack voltage too? Does it fire? I won't fire with any amount of watts, just something low like 1 watt. I don't know how many watts you can safely draw off of the balance connector.I didn't try to fire it with only the balance connector on but as I posted earlier pack voltage was there but the cell voltages while adding up to the pack were unbalanced.Checked with a meter though they were balanced. I'll try again when I actually get up.
dwcraig1 Posted June 21, 2016 Report Posted June 21, 2016 I didn't try to fire it with only the balance connector on but as I posted earlier pack voltage was there but the cell voltages while adding up to the pack were unbalanced.Checked with a meter though they were balanced. I'll try again when I actually get up.
WTVapes Posted June 21, 2016 Author Report Posted June 21, 2016 ChunkyButt200 said:so you are able to connect to escribe and see your voltages in device monitor? is it displaying the correct 'pack' voltage?
WTVapes Posted June 21, 2016 Author Report Posted June 21, 2016 Yea it reads it correctly but as soon as I disconnect from escribe it is back to nothing I guess I need to take the board out and check the fuse I've been looking for a replacement fuse online and everwhere is out of stock
black lace Posted June 21, 2016 Report Posted June 21, 2016 WTVapes said:Yea it reads it correctly but as soon as I disconnect from escribe it is back to nothing I guess I need to take the board out and check the fuse I've been looking for a replacement fuse online and everwhere is out of stocksorry to bother, what is the mod?, how long was it running before it broke down? you seem conversant or confident enough to take the board out to look at the fuse,you could try emailing evolv for a fuse.. or look for threads on here on fitting an automotive fuse..........
WTVapes Posted June 22, 2016 Author Report Posted June 22, 2016 Efusion Duo... yea I have thought about emailing evolv for a fuse cuz everywhere I have found one they are out of stock
