My new Aria solara anarchist edition dna 200 mod bricked
here is what happened: I turned off profile 1 to use in power mode as I am still not used to tc mode . I then checked my battery settings to make sure sure it was correct . I then went to device manager and checked all 3 cells were reading and performing correct . I then set some very basic settings as in what I wanted to see on the display and a picture on the welcome screen . after uploading I put an atty on at 3.67ohms at 57.4w hit the fire button and it shut off completely bricked I removed the atty and it came back on only now with the screen blinking from very bright to dimming slightly with what seems like a very very light reddish tint plugged the device back in to the software no charge indicator no response but the device is still recognized and except for what I described seems to have a normal appearance I removed the device and it shuts off . The device will only power on when plugged into the usb and when it comes on it is as I just described oh and if I put an atty on it shuts off, device manager shows 3.7v on all 3 cells . I am so lost as to what to do Yes I did try a hard and soft reboot and a usb recovery charge and nothing oh and restoring all factory defaults and recalculating the battery settings can someone please help thank you all so much
The redish tint, do you think you may have juice in there and also, the coil ressistance, did you build the coil to that ressistance or do you also think very a high reading and that the mod may be malfunctioning becsuse of swamped with juice, as vb and bill said somthing has clearly blown the fuse and the reading is crazy.. you see you have warning flashes like shorted or ohms to high so i cant see a bad coil blowing the fuse on its own. .
