Llama Posted June 6, 2016 Author Report Share Posted June 6, 2016 I was looking for a 26650 DNA75 and settled on pre-ordering a DX75 from Hotcig, but apparently there's some problems with the DX75, and the VT75 from HCigar. At least on the mods that have been sent to this reviewer (skip to 20 minutes, you will see the problems)https://youtu.be/5_3TrVg0bTkBasically, the mod enter into weak battery error while the battery is fully charged, and some problem with ground turning the personnal vaporizer into a personal electrical stun stick.For the ground issue I guess it can be coming from the manufacturers, even though it's surprising that the two have done the same mistake, but the weak battery issue rather looks like a chipset issue.What's weird is that I haven't seen it mentioned in the few reviews available, anyone have seen these issues mentionned elsewhere ? Link to comment Share on other sites More sharing options...
awsum140 Posted June 6, 2016 Report Share Posted June 6, 2016 The "weak battery" can easily be a result of voltage sag caused by the high current demand of the preheat. Looking at eScribe as I fire my DNA75 with an 18650 shows the voltage drop during preheat is really quite high and not an indication of a problem with the chip or the battery, just a result of a very high load. Even a 26650 will sag, significantly, under loads like that which, in turn, trigger the "low battery" warning. The chip just sees the voltage drop to the "low" threshold and triggers the warning. Link to comment Share on other sites More sharing options...
VapingBad Posted June 6, 2016 Report Share Posted June 6, 2016 The shock thing is shocking, no pun intended, but as you say it is just something with that mod and I hope just some of the early versions, very strange though. On that mod there is something up with the battery connection and that would explain the Weak Battery message, I do note he gets it with another mod also.Weak Battery is a warning message and not an error, you get Check Battery when there is more of a problem. It just means that the battery couldn't supply the power you asked for without sagging below 2.5 V so the board protects your battery by backing off to keep it from dropping that low, which is a good thing IMO. You may get it a little more in temp mode with the preheat at 75 W, but all it means is you just get say 65 or 70 W preheat instead and mostly you will get full wattage for the rest of the vape, have a look in device monitor to see for yourself. 75 W is a lot from a single cell and the voltage from cells with high internal resistance will sag a little more, the high mAh cell that have got popular more recently and 26650s for instance. Also if the cells are really tired they take longer to recover than cells in good condition and you will see more warnings, info message would be a better term IMO. I am having no issues with VTC4s date codded Oct 2013 and 25Rs date codded Sept 2014, I am not running at very high wattage, but I do have the preheat maxed and get good performance from both of these batteries down to around 3.15 - 3.3 V before the vape drops off. Saying that I did get more warnings before I replaced the contacts on Keystone battery sled, inadequate wiring and battery contacts will make a difference too.If you get Weak Battery on a nearly fully charged battery I think it's because your battery, battery contacts or wiring are inadequate, when the battery is getting low expect to see the warning it's a heads up that you will need to charge or change the battery.(E: I got a PM asking how to get the 18650 battery date codes and thought others might be interested https://batterybro.com/pages/18650-date-code-lookup-tool ) Link to comment Share on other sites More sharing options...
Llama Posted June 7, 2016 Author Report Share Posted June 7, 2016 The irony is that I bought a cheap 26650 mod before, to test a bit battery life on 26650 before investing more in a dna75, but it doesn't have any of these problems. So I guess it's bad components used in thoses mods. Link to comment Share on other sites More sharing options...
VapingBad Posted June 7, 2016 Report Share Posted June 7, 2016 If you get warnings with fuller batteries running the 26650 than 18650 it's the battery, but both should be OK and I was just trying to include all the factors. If you do feel you are getting the warnings too early I urge you to look at the battery level in device monitor because it is probably jut the initial preheat that is triggering the warning and it may be an idea to turn that down a bit for that battery.E:See the battery voltage is the black line, it sags a lot with the 75 W preheat, but quickly recovers as the power reduces to 40 W. This is a Sept 2014 Samsung 25R that has always been charged at 2 A so is by no means a top condition battery, I don't get any warnings until the resting battery voltages goes down to about 3.3 V with this set up. Link to comment Share on other sites More sharing options...
Llama Posted June 7, 2016 Author Report Share Posted June 7, 2016 Just to clarify, I own none of these mods, I had the Hotcig on pre-order, but currently cancelling it after seeing this review.What you say makes sense, especially since the reviewer doesn't seem to have properly configured the mods using escribe, and probably pre-heats at 75W. But the battery weak message and cut-off seem to happen after the pre-heat time. Link to comment Share on other sites More sharing options...
VapingBad Posted June 7, 2016 Report Share Posted June 7, 2016 Yes it remembers the battery dipped that low, it is a little little like the temp protected message as regardless of how long the condition lasted it will flash after the puff because you can't see the screen while vaping on most mods. Link to comment Share on other sites More sharing options...
Lilpetabread Posted June 7, 2016 Report Share Posted June 7, 2016 Llama said:Just to clarify, I own none of these mods, I had the Hotcig on pre-order, but currently cancelling it after seeing this review.What you say makes sense, especially since the reviewer doesn't seem to have properly configured the mods using escribe, and probably pre-heats at 75W. But the battery weak message and cut-off seem to happen after the pre-heat time. If I recall correctly, he is trying to vape at 75 watts on a 26650 in this review. Everything I've recently read about 26650's states that vaping over 50 watts on a 26650 is going to be lackluster. I've heard sticking to 30-40ish watts is going to be the best performance. Link to comment Share on other sites More sharing options...
Llama Posted June 24, 2016 Author Report Share Posted June 24, 2016 Just as a follow up to this thread, I bought an Hotcig DX75, never got zapped so far after one week, and the mod doesn't go into weak battery error when it's not pushed to its limits. I'm very happy with it.Thanks for the informations ! Link to comment Share on other sites More sharing options...
Z.Oregon Posted June 25, 2016 Report Share Posted June 25, 2016 Fagen was shocked because the ground screw wasn't engaged in the bottom of the battery. I just uploaded the new update-look here-that fixes the check battery issue and it seems to be running smoothly so far. A thing to note is running the board upwards of 75 watt range will stress any battery. I'd say use 18650 for above 50 watts and 26650 for under. So far, the basen 4500 26650 isn't doing to bad and I've read running the battery analyzer improves it, which I plan to do this weekend. Link to comment Share on other sites More sharing options...
claudio.cavg Posted June 25, 2016 Report Share Posted June 25, 2016 USB connection stopped working, I've tried on multiple computers with the included USB cable and others, and I can not connect to the PC. Simply not detected. This happened in a hcigar vt75, with 4 days of use!!! Link to comment Share on other sites More sharing options...
Jace Posted June 26, 2016 Report Share Posted June 26, 2016 Z.Oregon said:Fagen was shocked because the ground screw wasn't engaged in the bottom of the battery. I just uploaded the new update-look here-that fixes the check battery issue and it seems to be running smoothly so far. A thing to note is running the board upwards of 75 watt range will stress any battery. I'd say use 18650 for above 50 watts and 26650 for under. So far, the basen 4500 26650 isn't doing to bad and I've read running the battery analyzer improves it, which I plan to do this weekend.Look Where ? Is there an update for the board or the mod, if its the mod what mod are you using ? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted June 26, 2016 Report Share Posted June 26, 2016 Jace said:Look Where ? Is there an update for the board or the mod, if its the mod what mod are you using ?this small update from evolv which tweaks the "weak battery" message. here's the link, read through.https://forum.evolvapor.com/topic/66088-topic/?do=findComment&comment=893826 Link to comment Share on other sites More sharing options...
Scarab Posted July 18, 2016 Report Share Posted July 18, 2016 VT75 little construction issue: Link to comment Share on other sites More sharing options...
kinkmangc Posted July 20, 2016 Report Share Posted July 20, 2016 Had this same problem with tons of strange error messages. Figured out it was just loose screw on the bottom. Tighten up and has been working like a charm since. But I damaged the bottom by over tightening the battery cover. It kind of bent the bottom case. Since its not a defect I can't claim warranty. Thinking of disassembling and bending it back.Scarab said:VT75 little construction issue: Link to comment Share on other sites More sharing options...
Scarab Posted July 20, 2016 Report Share Posted July 20, 2016 kinkmangc said:Thinking of disassembling and bending it back.Yes, disassembling and bending a bit it back must work. I saw the same solution for this trouble. Link to comment Share on other sites More sharing options...
µ_µ Posted August 1, 2016 Report Share Posted August 1, 2016 I've got the dx75. I don't test it too much with the default manufacturer settings. I've updated the profile. I don't know exactly what I did, but I cannot retrieve my defaults. Someone has the ecig profile by default from the manufacturer ? For the weak battery, I've got the same problem. I've got the message at around 50%. My cells are : efest 3000mah https://vapevine.ca/wp-content/uploads/2015/10/efest-18650-3000mah-35a-Canada.jpg Link to comment Share on other sites More sharing options...
Swainesmatee Posted August 1, 2016 Report Share Posted August 1, 2016 u_U you have you export your profile before you make changes if you want to revert to normal or you will revert to the dna chip factory settigns not your mfg factory settings.but contact them, vaporshark sent me over a file that had everything for the vapor shark 133 box, mod resistance, thermal properiteies, all the profile etc.. because my girl reset it thinking it would reset to factory specs. Link to comment Share on other sites More sharing options...
µ_µ Posted August 1, 2016 Report Share Posted August 1, 2016 Swainesmatee said:u_U you have you export your profile before you make changes if you want to revert to normal or you will revert to the dna chip factory settigns not your mfg factory settings.but contact them, vaporshark sent me over a file that had everything for the vapor shark 133 box, mod resistance, thermal properiteies, all the profile etc.. because my girl reset it thinking it would reset to factory specs.hi !thank, I just contact them for the profile. I need the "MOD" section, I'm on a dna 75 default profile. Link to comment Share on other sites More sharing options...
