awsum140 Posted July 29, 2016 Report Posted July 29, 2016 Chunky, I clean both the atomizer base and the 510 on the mod with IPA at every atomizer change, even though I have zero leaking problems with any of my builds. The TCR is the exact same one for each use, successful use followed by non-successful use, and the exact same TCR that works fine in other mods, DNA200s. Something strange is going on and I have yet to identify it or get feedback from forums or Evolv that can identify it. Multiple boards, added grounds and even did the "eggplant" dance with no changes in behavior.
JohnnyBigodes Posted August 16, 2016 Report Posted August 16, 2016 Same problem here ;o(It seems the Evolve chip isnt reading right.The same issue i know from Joyetech chips.It reads everytime to low, for some reason.If you adjust you ohm readings higher it vapes like a dream.The problem on all this is, that i am comparing a highend chip to a dirty cheap chip and both seem to have the same issues.
awsum140 Posted August 16, 2016 Report Posted August 16, 2016 I found a work around. All I did was raise the temperature until things worked properly. The DNA75 is set to 530F while a DNA200 with the same build is running fine at 480F. It may just be a question of tolerances in components. Beats me but it does work. The 50F difference does bother me though.
BillW50 Posted August 16, 2016 Report Posted August 16, 2016 Temperature sensitive connection it sounds like to me. I too have seen this behavior before on even DNA200 mods.
awsum140 Posted August 16, 2016 Report Posted August 16, 2016 The funny part is that the 75 is an Evolv 510 and the 200, at least one of them, is an FD V4.
awsum140 Posted August 16, 2016 Report Posted August 16, 2016 Yes, and when swapping the behavior of the 75 and 200 is the same with the 75 needing a higher temperature. I've changed boards, added grounds and done the "naked eggplant on my head" dance with no results. Simply raising the temperature on the 75 did the trick though.
BillW50 Posted August 16, 2016 Report Posted August 16, 2016 Did you try dancing naked in a ring of fire during the full moon yet?
awsum140 Posted August 16, 2016 Report Posted August 16, 2016 No, I'd need a fire permit and the fire department would need to be present
