Juggaloassassin123 Posted August 10, 2016 Author Report Share Posted August 10, 2016 I have a cloud maker White out DNA 200 with the panel kit but most of the screws are stripped on it any idea on how I can get them out? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted August 10, 2016 Report Share Posted August 10, 2016 you can try and place a very thin piece of rubber between the screw head and screwdriver tip. like a rubber band or sumthin. Link to comment Share on other sites More sharing options...
Juggaloassassin123 Posted August 10, 2016 Author Report Share Posted August 10, 2016 How would that help? Link to comment Share on other sites More sharing options...
black lace Posted August 10, 2016 Report Share Posted August 10, 2016 Probly only be able to grind the heads off with a dremil or multi tool and then glue it shut after youve finnished. Link to comment Share on other sites More sharing options...
txmonkey214 Posted August 10, 2016 Report Share Posted August 10, 2016 If you are very careful, you can cut a groove with a dremel cutting tool and use a regular head screwdriver. You could also try cutting 2 small grooves and using a good (example: snap-on) screwdriver that is the correct size for the screw. Using too big a screwdriver will ruin the screw head. This may have been your problem, to begin with. Link to comment Share on other sites More sharing options...
Nick Posted August 10, 2016 Report Share Posted August 10, 2016 I hear Faygo is great in place of a penetrating oil. Link to comment Share on other sites More sharing options...
Nick Posted August 10, 2016 Report Share Posted August 10, 2016 Seriously though, which screws are they specifically?Depending on if there would be some thread sticking out you could drill the head off and then grip it with needle noses to remove it, or vise grips.I would have to know which ones though they are so I can look at the device and figure out a plan of action that may work. Link to comment Share on other sites More sharing options...
scooby Posted August 11, 2016 Report Share Posted August 11, 2016 The WO has small flat 1.3mm (I think) hex head screws. Edit: that's 1.3mm A/F Adding to the other suggestions you could try knocking a small torx screwdriver into the rounded off head so it bites enough to undo, T5 or T6.Sacrifice a key and epoxy it to the head, might work but as the Wo has a dozen screws and you say most are stripped that might not be viable.Carefully drill them out. Link to comment Share on other sites More sharing options...
wiredl0ve Posted August 11, 2016 Report Share Posted August 11, 2016 The rubber band between the screwdriver tip and screwhead fills in the space and provides some friction, to answer the 'how would it help' question. I've had some success with higher end gel-type super glues and gluing the tip into small screws. Epoxy, as suggested above would work (and if it's really bad would work better), but super glue is faster and can be heated after the screw is removed to destroy the bond between the screwdriver and screw. Just don't glue the screw into the box. Link to comment Share on other sites More sharing options...
black lace Posted August 11, 2016 Report Share Posted August 11, 2016 Working from the centre out, it might be possible to cut a slot for a flat head screwdriver, with a multi tool engraver, if the screws are stainless the engraver bit wont last long, probly one for each, if your replacing the pannels i would just grind them off and like nick said , if theres any stud left, twist it out with the pliers.. torx heads are often slightly tapered, if you go at them with an alen key they will mash up, Its often ok to go at an alen key head with a torx bit, i do it on me bike all the time but not vice versa.. Link to comment Share on other sites More sharing options...
norwegianvaper Posted August 13, 2016 Report Share Posted August 13, 2016 Answer Link to comment Share on other sites More sharing options...
black lace Posted August 14, 2016 Report Share Posted August 14, 2016 No you gotta keep it going,, how many people does it take to get a screw out, lol Link to comment Share on other sites More sharing options...
wiredl0ve Posted August 18, 2016 Report Share Posted August 18, 2016 black lace said:No you gotta keep it going,, how many people does it take to get a screw out, lolI wonder if they make EZOUTs that small Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted August 18, 2016 Report Share Posted August 18, 2016 wiredl0ve said:I wonder if they make EZOUTs that small i've seen some very small size ex outs before. i don't think autozone or advance will have em that small tho. let me see if i can find the link to them.......edit.....nope smallest is 3/32nd's if you have a left handed tiny drill bit you could use that in a drill at low speed. since the bit is left hand turn it will dig into the screw CCW and should remove it. take a look around here to see if anything will work.https://www.amazon.com/s/?ie=UTF8&keywords=left-handed+drill+bit&tag=googhydr-20&index=industrial&hvadid=89224283054&hvpos=1t1&hvnetw=g&hvrand=5397190977103050167&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9006313&hvtargid=kwd-25369225675&ref=pd_sl_28v8ovi3jc_e Link to comment Share on other sites More sharing options...
