Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 I purchased a vt200 and i have been having problems with my battery. I only use it at 20watts and at 0.8ohms. I don't get even more than 4hrs of using it. I'm using my Istick 50w and it lasts me for 2 days. Is it possible I get a new battery sent to me? I can't even take it out with me to use because it does not last long enough. I paid £120 just so I can use it for a few hours at home. Please advise me in further what to? I have updated the software and changed the battery part from 9 to 14.43. It has improved but it still seems to be draining pretty fast compared to my other mods. There are not much to set for the battery as I have done some research online. I would like to be able to take my vt200 out with me and vape. Is there a warranty exchange? I have read others has last longer than a day using higher watts and temp control. My cells fully charged are Cell 1 4.20 Cell 2 4.20 Cell 3 4.20 Pack 12.60. Can barely get through have day now still using 20w @ 0.8. If I was to use it at 50w it would die in a couple of hours. Can someone please help me. Link to comment Share on other sites More sharing options...
Mad Scientist Posted September 30, 2015 Report Share Posted September 30, 2015 I would contact the vendor. Sounds like your battery pack might have issues. I vape all day at around 45 watts on a 17+ Wh pack with some capacity left over at the end of the day. 20 Watts on a 14+ Wh pack should last a lot longer than 4 hours. Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 I don't think there is much more I can change in the settings. Thought I could have some fun with this mod ;( Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 More advise and suggestions are welcome please. Link to comment Share on other sites More sharing options...
Mad Scientist Posted September 30, 2015 Report Share Posted September 30, 2015 I guess there is a misunderstanding. What I suggested was to contact your mod vendor because your battery pack is likely no good. Nothing to do with any settings.Wish I could give some other ideas but that seems to be the problem. Link to comment Share on other sites More sharing options...
VapingBad Posted September 30, 2015 Report Share Posted September 30, 2015 I agree with Mad Scientist and would contact the vendor. Link to comment Share on other sites More sharing options...
soblue Posted September 30, 2015 Report Share Posted September 30, 2015 Hopefully I'm understanding statistics correctly, if not someone can correct me. But it's kind of hard to compare battery capacity to someone saying I get a day out of mine when they may take 4 second draws every 15 minutes or so and you may take 10 sec draws every 5 minutes. If it were mine I would put a full charge on it, and either Reset Statistics in Device Monitor or write down the Total Energy mWh then use the device without charging it any further until I received the Weak Battery notification (making sure Cell Soft Cutoff is set correctly). If at that point your Total Energy is around 14Wh then it's performing pretty close to specs. If it's a little lower it may just be over stated battery specs. If it's significantly lower it may indicate a bad battery pack or something within the device. Link to comment Share on other sites More sharing options...
Mad Scientist Posted September 30, 2015 Report Share Posted September 30, 2015 soblue said:Hopefully I'm understanding statistics correctly, if not someone can correct me. But it's kind of hard to compare battery capacity to someone saying I get a day out of mine when they may take 4 second draws every 15 minutes or so and you may take 10 sec draws every 5 minutes. If it were mine I would put a full charge on it, and either Reset Statistics in Device Monitor or write down the Total Energy mWh then use the device without charging it any further until I received the Weak Battery notification (making sure Cell Soft Cutoff is set correctly). If at that point your Total Energy is around 14Wh then it's performing pretty close to specs. If it's a little lower it may just be over stated battery specs. If it's significantly lower it may indicate a bad battery pack or something within the device. You are right of course. But I vape pretty much all day, about 20+ml per day at 100 watts preheat, 75 watts setting and around 45 watts at the "ebb" of each draw -- so that's my point of reference and comparison. At 20 watts to get only 4 hrs use from 14+ Wh, that would be some pretty heavy duty vaping. But again you are right -- the guy might just chain vape like a boss then wonder why the battery gets drained lol. Link to comment Share on other sites More sharing options...
VapingBad Posted September 30, 2015 Report Share Posted September 30, 2015 Yep and I would expect all batteries too be slightly under their rating as the cut off on the DNA will be a higher than their capacity test. You can just not the total between charges rather than resetting if you prefer.BTW at 40 W 380-400 F a 900 mAh lasts me more than a day vaping 10 ml of liquid. Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 Lol vaping like a boss! I do the same on my istick 50w @20w 0.8ohm and it's definitely not lasting as long as that. I wanted to start dual coiling with high temps and get into temp control that's why I see it as a problem. I will get on the phone with the vendors today and see what they say and I'll keep you gets up date. ththa Link to comment Share on other sites More sharing options...
kraze6548 Posted September 30, 2015 Report Share Posted September 30, 2015 I have the same mod. At 50 watts and 500 f I get about 8hrs . Give or take. I just pulled the pack from the mod and got the measurements. I called max amps to see about a custom pack. I've used them for custom rc packs so they should be able to do it. If they can make one I will post in this forum what they are making me. I did notice that inside the battery holder there are 2 tabs to hold the pack. With the right tools u might be able to remove the tabs and use a bigger pack. Alot of work but until I can make my own mod with bigger packs that's all I can do. I'm hoping evolve reference box will hold bigger Batts when they release them Link to comment Share on other sites More sharing options...
Xx3dge Posted September 30, 2015 Report Share Posted September 30, 2015 My vt200 last all day at 60w 100w preheat. II vape about 25mls out of a aromamizer rdta. It took a few full discharge cycles till I noticed longer battery life. Link to comment Share on other sites More sharing options...
soblue Posted September 30, 2015 Report Share Posted September 30, 2015 Something else to consider, looking at the specs of the Istick 50 that I seen showed 4400mah 2x18650 parallel, The Hcigar VT200 listed 1300mah 3s series so the watt hours calculate out at about 16.28Wh for the Istick 50 and about 14.43Wh for the VT200. So if the specs I seen are correct and my calculations are up to par there is more capacity with the Istick 50 so it makes sense to get some additional usage from the Istick at lower power settings, not necessarily what your seeing though. Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 hey guys, i contacted the my vendor angelsfiremods.co.uk, great customers service! gave me another software to update and will see what happens next. my next problem is that i have been charging it for 5 hours and not using it. but the charging indicator is still there, so i cant do the battery analyzer. It looks like its fully charged though. so i still need to test it after it fully charges and then give them a call back and let them know how it is all going. before that i need it to fully charge first @@ Link to comment Share on other sites More sharing options...
VapingBad Posted September 30, 2015 Report Share Posted September 30, 2015 Looks fully charges with each cell at 4.2 V, it would have charged faster from a 1A supply btw and if you press fire during charging it pauses charging and shows the standard screen. Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 i am now trying for the battery analyzer but it says "waiting for battery to be fully charged..." Link to comment Share on other sites More sharing options...
VapingBad Posted September 30, 2015 Report Share Posted September 30, 2015 Have you got a resistor on top, not a normal coil, see https://forum.evolvapor.com/topic/67481-topic/ Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 26g kanthal dual coil 8 wraps 2mmok its working now using 1 ohmsbig thanks everyone Link to comment Share on other sites More sharing options...
VapingBad Posted September 30, 2015 Report Share Posted September 30, 2015 If it thinks that it is not full after it should be you could try and reduce the Wh a little on the mod tab. Link to comment Share on other sites More sharing options...
Toysoldiers Posted September 30, 2015 Author Report Share Posted September 30, 2015 blah its doing the same thing... needs to be fully charged! GRRrrrr Link to comment Share on other sites More sharing options...
Xx3dge Posted September 30, 2015 Report Share Posted September 30, 2015 It's better to use a resistor. The Atty is going to get extremely hot. Link to comment Share on other sites More sharing options...
soblue Posted October 1, 2015 Report Share Posted October 1, 2015 Wouldn't bother making coils, they retain to much heat on the atty. Just make a loop or a parallel loop and there's little to no heat retained on the atty / 510. Think the one I used was a couple 6" long strands of 26g kanthal coming in a little over 1? and worked fine. Link to comment Share on other sites More sharing options...
Toysoldiers Posted October 1, 2015 Author Report Share Posted October 1, 2015 And just put on top of tank? Link to comment Share on other sites More sharing options...
soblue Posted October 1, 2015 Report Share Posted October 1, 2015 Yea just make a loop or a couple loops depending on your atty and just place it on top the device for the loop to air cool. Link to comment Share on other sites More sharing options...
West84 Posted October 2, 2015 Report Share Posted October 2, 2015 VT200 after 7 hours and 208 puffs at 60W and 0.3 ohm Link to comment Share on other sites More sharing options...
