fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 HCigar VT200 NOT CHARGINGWhat settings and where Do I need to go to fix this so the unit will charge? When I plug it in the battery just shows EMPTY!! Please help ASAP Thank youJosh Thomas Link to comment Share on other sites More sharing options...
VapingBad Posted November 28, 2016 Report Share Posted November 28, 2016 Are any of the cells below 2.5 V, you can check in EScribe - Device Monitor, if so you either need to return it to the vendor as they should not be sold in that condition and if they are very low for a long time it ages the battery and cane even stop them working altogether or you can try EScribe - Tools - USB Recovery Charge. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 I see an option to change the usb current limit is that what i change? if so what do i set it to.. this is a screen shot of my device monitor Link to comment Share on other sites More sharing options...
retird Posted November 28, 2016 Report Share Posted November 28, 2016 Yep... you have never even used the device..... Device shipped with batteries too low.... VapingBad's post gives you good guidance....Contact vendor and/orEScribe - Tools -Diagnostics - Perform USB Recovery Charging. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 ok i contacted the place it literally just came in the mail a few hours ago going to get a replacement if they ever reply. I have several other dna mods sealed in the box this is the first time I have ever gotten a defective mod now im afraid some of the sealed other brand mods I have might be defective.. Link to comment Share on other sites More sharing options...
Wayneo Posted November 28, 2016 Report Share Posted November 28, 2016 @fibercarbon Just a bit of bad luck. Go watch a few tutorial videos, open 'em up, change your settings, and keep your fingers crossed. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 Ok I got BRAND NEW mods in the mail today and I am using all the cords they have came with I have tried multiple usb chargers and plugging them into my pcI got 2 VT200 and 1 of them is charging fine the other wont charge at allI got 1 SMY SDNA 200W TC Box Mod it will not charge or power on at allWHAT is going on here there is no way 2 brand new mods sealed in the box will not charge.. Someone please help me out here. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 i have no way to remove the battery back off the units they require a VERY Tiny like STAR looking screwdriver which I dont have Link to comment Share on other sites More sharing options...
retird Posted November 28, 2016 Report Share Posted November 28, 2016 We have offered our suggestions. You can get with the vendor on their warranty for DOA units. You can run the USB Recovery Charging feature in Escribe to see if that will bring your batteries back from arriving with the charge too low. Batteries with such low charge will not charge normally so you can try the USB Recovery Charging as we said above. You may have to try it several times to get the batteries back.Since these devices are new I don't recommend you open them up as it may void any warranty you have. Let us know if the USB Recovery Charging helps... Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 i tried the usb recovery feature and it is not rising at all...what number should i set for the "SET USB Current limit" ?? Link to comment Share on other sites More sharing options...
retird Posted November 28, 2016 Report Share Posted November 28, 2016 I see you plugged in a different device as it has very low battery cells also.. Set the Current to 1A as that is the max for the DNA200. If charging from a computer it may only charge at 0.5 A....The charge time will take a while so be patient... Link to comment Share on other sites More sharing options...
VapingBad Posted November 28, 2016 Report Share Posted November 28, 2016 fibercarbon said:i tried the usb recovery feature and it is not rising at all...what number should i set for the "SET USB Current limit" ?? That is not USB Revovery Charging, you don't need to change the thing you are looking at.Go here or here on older versions of EScribe < V1.2, same thing Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 I followed the above twice on the HCigar VT200 and it still is not going up. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 28, 2016 Author Report Share Posted November 28, 2016 the battery is not showing the lightning bolt its just blank still... I am assuming it is not charging. Link to comment Share on other sites More sharing options...
VapingBad Posted November 28, 2016 Report Share Posted November 28, 2016 Cells 1 & 2 have gone up, it can take a while and several tries as it uses a low current and has a short time limit for safety, but if that cell has sat at 0.01 V for a while it may be permanently damaged and never hold charge again. Link to comment Share on other sites More sharing options...
fibercarbon Posted November 29, 2016 Author Report Share Posted November 29, 2016 i tried several times still not going up.. I am trying to contact the store I got it from Link to comment Share on other sites More sharing options...
retird Posted November 29, 2016 Report Share Posted November 29, 2016 Since they were DOA hopefully the vendor will replace them.... let us know how it shakes out... Link to comment Share on other sites More sharing options...
