dna671 Posted December 2, 2016 Author Report Share Posted December 2, 2016 Hi everyone need some help I've just recently uploaded a service pack on escribe (sp5) before the install I was at 75 watts hitting at 51- 55 watts on my vt133 now after the SP upload it hits at 28 or 30 watts is this normal? Link to comment Share on other sites More sharing options...
dwcraig1 Posted December 2, 2016 Report Share Posted December 2, 2016 Is the cold resistance the same as before you updated/ was the atty warm at the time of the update? Link to comment Share on other sites More sharing options...
dna671 Posted December 2, 2016 Author Report Share Posted December 2, 2016 dwcraig1 said: Is the cold resistance the same as before you updated/ was the atty warm at the time of the update? Expand yes/no, no atty was on my device at the time of the update. Link to comment Share on other sites More sharing options...
dwcraig1 Posted December 2, 2016 Report Share Posted December 2, 2016 I'm at a loss for an answer, perhaps someone will have it. Link to comment Share on other sites More sharing options...
Wayneo Posted December 2, 2016 Report Share Posted December 2, 2016 @dna671 Can you be a bit clearer. "I was at 75 watts hitting at 51- 55 watts" <- Using Temp Control? Also the absolute latest is sp5A.@dwcraig1 I've updated to sp5A, but in Device monitor it shows sp5 which is the same as before. Is that normal?? Link to comment Share on other sites More sharing options...
dwcraig1 Posted December 2, 2016 Report Share Posted December 2, 2016 That is how mine is also. There were some corrections made to SP5 so perhaps that reflects that. I really don't know.Edit: from the Early software page "[SP5a fixes a few minor EScribe bugs in SP5.]" Link to comment Share on other sites More sharing options...
James Posted December 2, 2016 Report Share Posted December 2, 2016 SP5a just fixed a cosmetic refresh issue between related fields. For example, in SP5 if you chose "Do not change brightness." as the Brightness setting for firing, the (related) brightness slider did not disappear until you clicked it. This was weird. Unless you reset your device settings, I'd definitely look at Cold Ohms. Link to comment Share on other sites More sharing options...
Canadianvape Posted December 3, 2016 Report Share Posted December 3, 2016 Override ohms? Use ohm meter and use that value at 70f. Should work. Link to comment Share on other sites More sharing options...
Wayneo Posted December 3, 2016 Report Share Posted December 3, 2016 Karloz, you're starting again with your garbage posts. I might have been 'sleep all fhrough history class', but I can spot you just as easily as I can spot a fake Canadian Loonie. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted December 3, 2016 Report Share Posted December 3, 2016 Wayneo said: Karloz, you're starting again with your garbage posts. I might have been 'sleep all fhrough history class', but I can spot you just as easily as I can spot a fake Canadian Loonie. Expand LOL, he's gone Wayneo, banned, for the second time. Link to comment Share on other sites More sharing options...
Wayneo Posted December 3, 2016 Report Share Posted December 3, 2016 @Chunky I'm sure the entire board thanks you. Link to comment Share on other sites More sharing options...
