Hi everyone need some help I've just recently uploaded a service pack on escribe (sp5) before the install I was at 75 watts hitting at 51- 55 watts on my vt133 now after the SP upload it hits at 28 or 30 watts is this normal?
@dna671 Can you be a bit clearer. "I was at 75 watts hitting at 51- 55 watts" <- Using Temp Control? Also the absolute latest is sp5A.
@dwcraig1 I've updated to sp5A, but in Device monitor it shows sp5 which is the same as before. Is that normal??
That is how mine is also. There were some corrections made to SP5 so perhaps that reflects that. I really don't know.
Edit: from the Early software page "[SP5a fixes a few minor EScribe bugs in SP5.]"
SP5a just fixed a cosmetic refresh issue between related fields. For example, in SP5 if you chose "Do not change brightness." as the Brightness setting for firing, the (related) brightness slider did not disappear until you clicked it. This was weird. :)
Unless you reset your device settings, I'd definitely look at Cold Ohms.
Karloz, you're starting again with your garbage posts. I might have been 'sleep all fhrough history class', but I can spot you just as easily as I can spot a fake Canadian Loonie.
