mechaet Posted August 26, 2015 Author Report Share Posted August 26, 2015 Hi DNA200 forums!I have a stump-the-tech issue:I usually plug in my mod (LittUp 44) to charge overnight via USB on my computer (with escribe running and the device monitor running), and usually the mod has between 40 and 60% remaining on the battery.When I wake up the next morning (I usually sleep about 5 hours) I see that the mod has charged the batteries to about 4.09v per cell, balanced perfectly, and I unplug it from the usb port to go vape.SOMETIMES, but not every time, when I get to the patio and hit the fire button, it doesn't fire; instead I have a screen saying "ERROR PRESS UP TO CONTINUE". I hit up, the normal "ready" screen shows up, and I vape as per normal. Interestingly, the battery was showing 93-95% charge when plugged into USB but will now show 77% (always drops to 77% when I get the error screen).Things I've tried:Charging the pack on a lipo balance charger to actual 100%.Updating the firmware (it currently is running the 8/21, I've tried the 7/1 firmware and the other firmwares in between)Soft restart of the mod via escribe before going to vapeAnd it still happens. It vapes fine once I click past the error screen, but am I playing with fire on this thing? Link to comment Share on other sites More sharing options...
scoopy Posted August 27, 2015 Report Share Posted August 27, 2015 Have u checked the battery tab on escribe to see if u have maximize battery instead of maximize puffs..... I've never heard of that error screen though..weird......It does sound like the maximise battery is checked though so take a look in escribe under the battery tab Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 I just had this same message this morning. I checked the manual to see what it is but I can't find anything. Weird. Link to comment Share on other sites More sharing options...
scoopy Posted August 27, 2015 Report Share Posted August 27, 2015 Hopefully John Brandon or James can shed some.light on this part of the issue....I've never seen or even heard of that message Link to comment Share on other sites More sharing options...
retird Posted August 27, 2015 Report Share Posted August 27, 2015 It may be a "custom screen" put in the Littup44 by whoever built it. Maybe ya need to contact the vendor and get an explanation. Link to comment Share on other sites More sharing options...
blueridgedog Posted August 27, 2015 Report Share Posted August 27, 2015 I was thinking custom screen too. Possibly new/old coil. Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 dc601 said: It may be a "custom screen" put in the Littup44 by whoever built it. Maybe ya need to contact the vendor and get an explanation. Expand It is an evolv error screen. This happened on my evolv beta mod. I woke up this morning, unplugged my device as usual, tried to take a vape (yes I vape first thing in the morning while still in bed), then I got no vape, checked the screen and nothing, then I saw the error message but at only 5% brightness. As I try and squint to see what was going on, boom full brightness. This was rather disturbingly bright before my eyes could adjust. "ERROR PRESS UP TO CONTINUE." What do I do? I press up. It's vaping like normal. Except my mod is fully charged and all cells are at 4.2 volts. Personally, if I were to guess, it was protecting the cells from overcharging. I'm not sure though, I'm not evolv. Only someone in evolv can explain this. I did check the manual and according to the manual, no such error message exists. Yet the error does exist. I'll post a pic if it happens again. Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 I think that I'm going to carry a spare mod with me today, just in case. Link to comment Share on other sites More sharing options...
antyac2108 Posted August 27, 2015 Report Share Posted August 27, 2015 i had the same thing happen to mine on Monday. it happened to me mid puff and it just died i thought oh **** it died. i put it down 5 minutes later it had the smae message and i have been vaping it ever since no problem. i hooked it to escribe when i got home and everything was ok. no problem at all. it could be the firmware because i had just done the update on the 08/21 update. Link to comment Share on other sites More sharing options...
James Posted August 27, 2015 Report Share Posted August 27, 2015 Has this happened to anyone who is not on 8/21?The battery meter has changed because that message indicates it accidentally restarted without savings its settings. Most likely it indicates a firmware bug.Do you have any special settings presently? If so, could you attach them please? Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 Still on 7-29 r1 Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 It did it again while on escribe. ????? Link to comment Share on other sites More sharing options...
antyac2108 Posted August 27, 2015 Report Share Posted August 27, 2015 What kind of special setting's. Are you talking about battery settings, profile settings? Thank you Link to comment Share on other sites More sharing options...
retird Posted August 27, 2015 Report Share Posted August 27, 2015 Good to know that's an Evolv error message. Link to comment Share on other sites More sharing options...
James Posted August 27, 2015 Report Share Posted August 27, 2015 Oh, I mean your EScribe settings.iandvapyes: This happened to you before 8/21 then? How long have you been encountering it? Link to comment Share on other sites More sharing options...
iandvaypes Posted August 27, 2015 Report Share Posted August 27, 2015 James said: Oh, I mean your EScribe settings.iandvapyes: This happened to you before 8/21 then? How long have you been encountering it? Expand Still on the 7/29 r1. It just started it this morning Link to comment Share on other sites More sharing options...
mechaet Posted August 28, 2015 Author Report Share Posted August 28, 2015 Just had it happen again.http://puu.sh/jR3X5/88c35bedc6.pnghttp://puu.sh/jR3YQ/03edd53f48.png Link to comment Share on other sites More sharing options...
scoopy Posted August 28, 2015 Report Share Posted August 28, 2015 Iandvaypes. ...try the 8-21 firmware and see if it still does it.....not sayin it will fix it but it's worth a shot Link to comment Share on other sites More sharing options...
James Posted August 28, 2015 Report Share Posted August 28, 2015 mechaet could you save and post your settings file? I don't see anything unusual on those screens. Link to comment Share on other sites More sharing options...
mechaet Posted August 28, 2015 Author Report Share Posted August 28, 2015 Sure thing. Also:http://puu.sh/jRc6j/bc84c985c1.pngSettings file: https://onedrive.live.com/redir?resid=2133226AD7D65E28!2800&authkey=!AE_sNd5dL0jAWJ0&ithint=file%2cecig Link to comment Share on other sites More sharing options...
mechaet Posted August 31, 2015 Author Report Share Posted August 31, 2015 I think I might have narrowed it down to not being able to save it as 22.2Wh, it drops the decimal (wtf) and puts it at 22Wh which then allows it to charge to only 12.0V instead of 12.6, and at some point the chip figures out what the voltage is and drops the battery percentage accordingly and reboots(? not sure of sequence), coming back up with a lower battery percentage after showing the error screen. Link to comment Share on other sites More sharing options...
Always_Jonezen Posted September 11, 2015 Report Share Posted September 11, 2015 I am having the same problem. Same error every time I upload or download settings from escribe. I'm using software dated 8/7 Link to comment Share on other sites More sharing options...
xevape Posted September 16, 2015 Report Share Posted September 16, 2015 I just got this today. Upon uploading settings I get Error press Up to continue.With firmware 8-21 & 8-7 With firmware 7-29 Weird...does not happen with 2015-07-29.sw-update only firmware after that date. Link to comment Share on other sites More sharing options...
Always_Jonezen Posted September 19, 2015 Report Share Posted September 19, 2015 I pulled the battery out completely disconnected and reinstalled it and I haven't seen that error in 48hrs Link to comment Share on other sites More sharing options...
dairylandservice Posted November 27, 2015 Report Share Posted November 27, 2015 James said: Has this happened to anyone who is not on 8/21?The battery meter has changed because that message indicates it accidentally restarted without savings its settings. Most likely it indicates a firmware bug.Do you have any special settings presently? If so, could you attach them please? Expand I'm getting the same "Error Press Up to Continue" and same 77% battery meter reading on fully charged batteries in 3 of my 4 Reuleauxs.I am running firmware 2015-9-30 on all 4 and Escribe Revision 1.0.35.2.The problem is very intermittent and I have not seen this at all on either of my VT 200s. Link to comment Share on other sites More sharing options...
