Oiko Posted March 18, 2017 Author Report Posted March 18, 2017 Hello, my new DNA 250 wont charge using the usb cable. The first day I bought it, I left it to charge overnight, and since thenit wont charge through usb.Any possible fixes?thank you.
VapingBad Posted March 18, 2017 Report Posted March 18, 2017 Looks like you have it set to max-recharges on the mod tab in EScribe, that limits the charge to 4.1 V which will approximately double the life of your batteries. Choose max-puffs to charge to 4.2 V, you will need the options - UI set to advanced to see the mod tab.
Oiko Posted March 18, 2017 Author Report Posted March 18, 2017 Thank you for the reply, it wont charge even if cell voltage is 3.0V. I charge the batteries using external charger now
giz_60 Posted March 18, 2017 Report Posted March 18, 2017 Could you vape on it for awhile to discharge the batteries some & then post another screenshot of device manager & possible one of the 'Mod' tab...
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Have you tried a different USB cable...different USB port on your computer...or even tried charging via USB wall adapter? I had a USB cable that came with my 250 that I had to replace due to problems...
dwcraig1 Posted March 19, 2017 Report Posted March 19, 2017 Let me ask a couple of questions that I meant to ask yesterday...gotta askDid you try a different USB cable?Did you try another power sourse?
Oiko Posted March 19, 2017 Author Report Posted March 19, 2017 I have tried different cables and wall adapter 5v/2.1a.It charged through usb for half day the first day I bought it. Then it stopped.I bought it 3 days ago. Should I request a replace?
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Oiko said:I have tried different cables and wall adapter 5v/2.1a.It charged through usb for half day. Then it stopped.I bought it 3 days ago. Should I request a replace?Yes...I would...being it's so new...
dwcraig1 Posted March 19, 2017 Report Posted March 19, 2017 giz_60 said:Yes...I would...being it's so new... 1
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Oiko said:I have tried different cables and wall adapter 5v/2.1a.It charged through usb for half day the first day I bought it. Then it stopped.I bought it 3 days ago. Should I request a replace?I would start with the vendor you bought your device from...if no luck there, contact Hcigar...http://service@hcigar.comIf all else fails, you can try contacting Evolv, but they are going to probably want you to remove the board from the device & ship it to them, in the U.S. & this will probably void your warranty as well...https://helpdesk.evolvapor.com/?a=add
Wayneo Posted March 19, 2017 Report Posted March 19, 2017 Off Topic:Did ya'll notice the default mod thermal settings also? Are the mfgr's really this lax and not doing this, or is it new users happy with a hard reboot? (I notice there were no resets of the data in his screen shots)
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Wayneo said:Off Topic:Did ya'll notice the default mod thermal settings also? Are the mfgr's really this lax and not doing this, or is it new users happy with a hard reboot? (I notice there were no resets of the data in his screen shots)Of my 8 mods, I think only 1 came with the case thermals set at other than the default...Triade....
Wayneo Posted March 19, 2017 Report Posted March 19, 2017 Of my 6 different brands all have been set, including LostVape Efusion Duo, just lucky I guess. (I run my own anyway)
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Wayneo said:Of my 6 different brands all have been set, including LostVape Efusion Duo, just lucky I guess. (I run my own anyway)Same here...
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Oiko said:I have tried different cables and wall adapter 5v/2.1a.It charged through usb for half day the first day I bought it. Then it stopped.I bought it 3 days ago. Should I request a replace?You may want to try this...in Escribe, go to Device Monitor>Diagnostics>Reset USB Current Limit...if the USB has been inadvertently disabled, this will re-enable it...can't hurt to try...
Oiko Posted March 19, 2017 Author Report Posted March 19, 2017 Thank you all for your replies.Neither Reset Usb Current Limit had any effect.I will try to get a replace.
giz_60 Posted March 19, 2017 Report Posted March 19, 2017 Oiko said:Thank you all for your replies.Neither Reset Usb Current Limit had any effect.I will try to get a replace.
