Everything posted by maximumsport
I've been using the Geekvape DNA z100c mod with the P coils rated at 0.15 70-80W. After about 4 puffs @ 75 watts and the coil gets somewhat warn not HOT the wattage would drop down to 40 watts and give a weak vape. I've updated the chip to the latest firmware. Some how the chip is dropping the wattage. Is there any way to disable this? I've looked in escribe but could not find a setting. I use the profile Watts with punch at 1. Nothing special. Thanks.
I agree. The new link download for SP19 for MAC seems to be running a bit more smoother and less laggy. Thanks!
Just wanted to report: EScribe Suite 2.0 SP19 also lags like SP18 on Mac. No matter what DNA250C mod I use. Device manager runs really slow on graphing and lags inputs on clicks. SP17 still runs smooth all around with no lags. No idea what was changed in 18 but that has caused big lagging on Mac software.
Haven't personally installed and used it yet. Waiting to hear from James. Here you go: EScribe Suite 2.0 SP19 SP19 fixes: — DNA 250 Color (firmware 1.1 SP38) — Fixed a firmware crash that could occasionally come up when the device had been idle for a while. Fixed spurious Temperature Protected errors that could crop up in certain high-CPU themes with Replay off. — DNA Go (firmware 1.1 SP38) — Fixed a firmware crash that could occasionally come up when the device had been idle for a while. — EScribe — In Display tab -> Device Monitor, ‚Remove Readout‘ no longer crashes. — Production Utility — Firmware -> Browse no longer crashes. DNA Go now does Fire Tests correctly. Mac: http://pc.cd/j0z Win: http://pc.cd/d6N
evolv 250c Evolv Default Enhanced 250C Theme
maximumsport commented on JMat76's file in DNA 75 Color, 100 Color, 250 Color
Issue report: Updated to EScribe Suite 2.0 SP18. Noticed when using Device Monitor in EScribe it really lags and hangs a bit. Reverted back to EScribe Suite 2.0 SP17 and Device Monitor is working smoothly again. Could this be only a issue to me? Anyone else notice this? Thanks Edit: I'm on MacOS High Sierra.
James, other than the fix. Any other updates done to improve the firmware?
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
You can't No worries man. The new firmware will be available very soon!
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Hey guys, Been testing the Alpha/Beta version for a few days now. So far all my devices with the firmware in testing has woke up right away! I can safely say Evolv came through and was correct. It was a firmware issue!
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Any final ETA when the new firmware will be out? Someone said couple of days a couple days ago lol. Thanks Evolv. Keep up the good work!
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Hey retird, Which 4 cell DNA 250C mod do you have? Been looking around for a decent one. Thanks
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Who has ordered from Element or any other retails? Did they fix the battery door on the retail one with no gaps when closed with batteries installed? I know on some reviews the door had a gap when installed with batteries. Just curious if this was fixed with retail versions. Thanks
Just received mine back from EVOL. Awesome service guys! Works 100% now. Wakes up right away! Board was replaced. Also noticed they reprogrammed my battery graph a bit and it helps! Customer service from EVOL is superb!!
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Where did you find the "Deep Sleep" option in Escribe?
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Just catching up.. So you were able to send the whole mod to Evolv ? You don't have to send the board alone? Just curious.
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
That's weird. I own 2 finders and both hit like a beast. Maybe you have a defective mod which sucks. Check the 510 pin does it spring up and down? Either way once you install a atty it should fire up.
- 6 replies
- dna250c
- think vape finder
(and 1 more)
Tagged with:
