ruckus
Everything posted by ruckus
  1. Version 0.1.2
    721 downloads
    Keep.It.Simple.StupidSweetie Just the essentials, no fluff.. practicing restraint was tougher than I thought! This was a W.I.P, was going to go the traditional route and include every option I could squeeze into the theme.. How often do I use these options? turns out barely.. if ever. The theme only ever displays options that are relevant to the selected profile, nothing more.. if something is unavailable its hidden. What do you get? Wattage control. Temp control. Replay control. Profile control. Coil ohm control. Graph featuring last puff wattage & peak temp (accessed by round robin-ing the main screen) Powerbank. Puff counters. Display settings. Stat dumps. Moose knuckle. Camel hump. That's it and I bet it's all you'll ever need.. refreshingly simple.
  2. Version 0.0.2
    1,420 downloads
    CREDIT :: Full credit to @JoeCockBill for the original conception of the base theme.
  3. Save the last puff I believe.
  4. "Puff saved, playing" meaning you have saved a puff in replay mode and its replicating it.
  5. Is that a RGB strip ?
  6. I replaced my screen yesterday, fired right back up and were back in business baby woo hoo! My replacement screen bounced around Australia for an entire week... the ironic thing is it only took 2 days to get here from the US! Just thought id share a quick update, cheers.
  7. This is precisely why I use some really good quality 3M double sided tape.. it works fantastic. I believe it's meant to be used in automotive interiors ? Couldn't tell you much more about it than that.. Hold everything in place, but is removable if need be..
  8. That's going to be a little tricky to get out haha.. I would try unscrew the board and remove the screen before trying to pry it out. I'm hoping to receive my replacement screen today.. looking forward to getting my 250C back into my rotation.
  9. A lot of the LED switches are sealed tho.. at least the ones I have on hand, not sure how you would replace the LED. I have attached the data sheet for the RGB should find what your looking for in there.. After it was all said and done, I didn't find it worth the effort, pushed on and put together my mod. LTST-C19HE1WT.pdf
  10. I identified the pins, couldn't find a switch suitable for the job. The RGB switches are just to large and bulky..
  11. Ah that's a shame, same thing with mine.. nothing visibility wrong. I ended up ordering a new screen, will see how we go!
  12. @steamer861 did you ever manage to fix this issue ? Just started happening to me few minutes ago.
  13. Before you go investing in a printer, I would recommend checking out a printing service like 3Dhubs.com Very inexpensive, I've printed quite a few enclosures in the past for other projects through them. Tons of suppliers on there so they are very competitive with prices generally costs me $15-$20 delivered AUD for a enclosure. Fantastic service, I was considering purchasing a printer myself... but honestly I just wouldn't use it enough to justify the purchase.
  14. Don't get me wrong tho I like the idea of a 3D printed enclosure (weight/scratch resistant) but yeah I couldn't justify the price.. Found these STEP files online just in case anyone reading this is interested on getting the ball rolling on a 3D printed reference case on the cheap: http://www.mamumods.com/dna250c/250CReferenceCase.zip
  15. Man I swear by alpinetech.. love those enclosures. . cheap too!
  16. Man those enclosures are expensive ... $81 AUD asking price for 3D printed part's seems ridiculous.
  17. Was hoping for real world results haha.. But that works, thanks!
  18. What a beast !? How many watt hour's does something like that give you ?
  19. Varitube V2 510 - Tattu 3S 1300mah (15.733Wh) Battery life has actually surprised and impressed me to be honest.. Very comparable to my dual 20700 DNA75C (17.996Wh) Tattu is a very reputable brand in the RC quad world which is why I went with them, they can handle massive speed punch out's from racing quads... won't have any issues handling the DNA!
  20. Popped my lipo mod cherry last night.. hahaha First lipo mod I've owned/built..
  21. If it feels like it's cutting power off to the coils, amp up the replay warmth. If it continues to happen however and your coils are getting wicked hot, it's probably due to replay restricting temp to prevent cotton burn.
  22. I probably should of worded it differently. We got there in the end !! Best of luck, regardless how you use replay, temp control whatever as long as it's enjoyable that's what's important.
  23. "3rd technique" is simply using replay with a coil material selected so the board can monitor temp. Using temp control & replay at the same time defeats the purpose in my opinion.. one you set by taste the other by temp - they essentially do the same thing by trying to meet conditions set by you. If your using replay WITH temp control active, replay is going to try replicate your saved puff - temp control is going to kick in and limit it. Replay adapts, temp control is strict. You mentioned if you disable temp control on your temp profile it's super hot vape - most likely active preheat/boost settings applied on that profile come to think of it.
  24. That's right.. in themes we refer to the setting as "temp protection" in escribe the exact same setting is referred to as "temprature". What makes the wattage profile a wattage profile is disabling this option.. so by you saying your getting difference experiences while this option is disabled on what you consider your temp control profile compared to your wattage profile makes no sense because by disabling "temp protection" your turning your temp control profile into a wattage profile. Hopefully that makes sense... if your still confused - plug your device into escribe so you can compare both your profiles in real time and you'll see exactly what I'm saying... turn off "temp protect" on your device and plug your device in.. then disconnect your device turn on "temp protect" and plug your device back in and re-download the settings"..
  25. Sorry that makes no sense to me to be honest... if you disable temp protection/temp in escribe your pretty much in WATTS mode.. "temp protection" is what the setting is referred to on the device / "temperature" is what that exact same setting is referred to on escribe. I think what your experiencing is a placebo effect... because by disabling temperature in escribe you've literally setup a duplicate/new "wattage" mode - the only difference is you have selected a wire material so the board can measure temp. Compare the "wattage" or "watts" profile on escribe to your SS316 while temp protection is disabled and it will all make sense.
