Everything posted by SirTimmyTimbit
multiple ui Gauges - Major update 2.0.0
SirTimmyTimbit commented on SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
Thanks man means a lot. I appreciate you putting up with this glitch It seems like the mod is firing instead of waiting to see if the button press is part of a sequence. I'm not sure what I can do to fix it but I'm definitely looking into it. I'm going to upload two new themes in a few hours. If you get a chance try them out. If the problems persist in those themes as well, and in no other DNA250 theme it'll be time for me to seek help from Evolv- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
I don't have that problem, and I haven't heard anyone else mention that either. Are you sure the profile is set up correctly? I just pushed an update (1.3.1) see if that solves it. The atomizer screen had an unused control in the staging area which I deleted in this update. I'm sorry it's glitching on you, thanks for letting me know!- 150 comments
- replay
- minimalstic
- (and 10 more)
That is very strange. Can you check to see if it happens on the main screen as well as a non firing screen like "Sys Status"? I can't see how a theme would be able to affect the lock system. I don't have a 250c to test it unfortunately. I'll keep looking into it. Just pushed an update (1.3.1) that fixes a few minor things. See if that helps? Thanks for letting me know guys!- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
Pushed an update to support Replay mode in DNA250c. I don't have a DNA250c device so I didn't get to test it. Please let me know if you find a bug or if something wasn't done right. Does anyone know how I can edit the automated screenshots generated upon uploading a theme here? Right now the thumbnail shows replay mode, I'd rather it show the wattage mode like before.- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
@blue_moon979 Thanks man! I really appreciate it The resistance listed under the blue bar will lead to that screen. If there's no atty attached, or if it's not making solid connection you'll get that screen. If it pops up on it's own and it's blank then I'm not sure what's going on. @realdigital That's a great idea about graphing voltage. I'll do that in the next version. Thanks! I do agree about the field being too small. It still works withing wrapping so I didn't really try to change it up. That screen will probably get an overhaul in a future version.- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
Ahh I see. I myself mostly use the main screen, to check battery percentage and watts/resistance. Anything beyond that I use escribe, and that happens once in a blue moon. I wasn't aware that a good portion of the users use the mod to do all these things. I'll update the theme in a few days with the features that it's missing. Thank you guys for letting me know!- 150 comments
- 2
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
Thanks I appreciate it. Can you point me to other themes that display that sort of information? Or perhaps screenshots of those info displayed on your current theme? If by Live Info you mean puff information including the graph, you can see that from SYS -> Puff Info. You can even fire from that screen. If you mean you want to see the current temperature, resistance and power being delivered at any point during the puff, the graphs and numbers are updated live on the main screen.- 150 comments
- replay
- minimalstic
- (and 10 more)
@Vapin What kind of additional control and TC specs would you like to see? If you click on the set temperature under the blue bar it'll let you adjust the temperature. If you click on atty it'll take you to the atomizer screen where you can change the power, temperature and pre-heat settings, as well as set or measure atomizer resistance. This theme is based on the default theme. The default theme had no option to lock resistance as far as I recall. It didn't cross my mind to put an option for it in there because I never use resistance lock in TC. I'll put it on there if I can find the room for it, without making the theme too cluttered. Thanks for your feedback ------------------------------- Edit: Added an ohm lock button in the Atomizer screen in version 1.1.2 that just released.- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
Version 2.2.0
28,627 downloads
Supports DNA250c and DNA75c, and Replay on both of those chips. Now you can choose from two different UI from the settings page. You need the latest international firmware 1.1 SP33.2 INT (included with EScribe Suite 2.0 SP15) on your DNA75c for it to work. Note: The status messages, like temp protected or atomizer short etc. are only displayed when firing. Press the fire button to exit the menu or any other page that doesn't have a back button. I hope you guys like it! Also check out my other themes:- 150 comments
- 36 reviews
- 38
- replay
- minimalstic
- (and 10 more)
