Effintreyy last won the day on March 7 2018
Effintreyy had the most liked content!
Effintreyy's Achievements
that makes sense. Thank you!
Yes rukus I have tried them and I really enjoyed them. I do like to use the SS as well with the temp control. Honestly I bought these and didn’t know what A1 was till a day or so later when I looked it up after I noticed running it in my SS profile was tearing through my cottons. Do y’all use dual coils or single? When I use dual it kills my batteries so fast I’ve been using single. Thanks for the advice!
Yes I have tried less cotton and feel it still burns? I braided some cotton last night and so far it is still holding in there. I feel like these might be 2mm maybe 2.5 but I’m like you and prefer 3 mm. I am not sure if these are from China or not I bought them at a vape shop when I was out of town. But they very well could be. Is it the kanthol that’s burning so hot making them burn in half so you think? What is your preferred metal? I will see if I can find some ohmland coils and give them a try thanks!
What are some recommended coils for the 75c? So far I have tried the fused Clapton’s and tiger coils. I have really enjoyed them both. I am currently on some juggernauts and I cant tell if it’s cause they’re wrapped smaller than normal but they keep burning my cotton after a few puffs. They’re made of kanthol and I have my watts turned down to 30. Any lower and it seems to not hit well. I’ve tried adding wraps To Them to increase the ohms to .38 but keep burning my cotton in half. Not sure if I’m doing something wrong or if it’s the coils but wanted to see what others thought on some different coils that are good for flavor? Thanks in advance!
Ok so I have boxer 75c I am running a 21700 ijoy battery with I believe 26g single fused Clapton coil with 7 wraps. When I first fire it says temp protect so I have to hit check ohms and it starts at .57ish. Then it kind of hits and then I hit check ohms again and it jumps to .67ish. And it hits better. Is this normal? Also I have been trying to play around with the watts and temp to find a happy medium. I’ve turned my preheat up to 50+watts and temp at 450 and my ongoing watts at 25-30 with the temp at 420ish? Sometimes I get a nice clean hit other times a lot of spit back or it chokes me and I cough up a lung. I have my coil spaced a bit. I’ve even noticed it has burnt my cotton apart. That could be the reason for spit back and burning flavor. Do I need to do a battery analyzer and case analizer? Or if I do one will I be able to dial this thing in better? Any recommendations of where I should be setting my waytts and temps at for a clean hit. I do like smoke but would rather have more flavor. Not a super warm hit but shmedium warmth that won’t burn me, but not cold either if that makes sense? Any help I can get to get this thing running better is greatly appreciated as I dont feel this thing is firing all pistons. Thanks again!
iJoy 21700 3750 mAh 40A EScribe Battery Profile
Effintreyy replied to Jasonvillamil's topic in Batteries and Charging
Thank you sir! -
- 5 comments
So I have changed to a single could hate ohming out at around.68. The battery is definitely lasting a lot longer now. I’m still having trouble getting it to hit right. I have my watts at 35 and my temp at 420. Does anyone have a suggestion of where to put my watts and temp at that might be preferable? Using ss316 fused Clapton coil. Also was considering the ijoy 2100 battery to see how it does. Are they’re any pros or cons for the 20700 vs 21700 from I joy for this boxer 75c
- 5 comments
- 5 comments
I have the same problem I think. When my vape has been sitting for a few minutes I go to hit it and it says temp control. If I hit check ohms my my ohms jump down to ..56and I barely get a hit. Then I press check ohms again and jump back up to .66 and I get a good hit. I have a single ss316 fused Clapton in the dead rabbit rda. My watts are at 43 and temp is at 390. My coils are spaced and everything has been cleaned but this still happens? Any idea if this seems normal or if this can be fixed?
Oh a mother quick question. If I switch to a single coil do I want more wraps on the coil to get a higher ohm? Does 7 wraps seem to be a good number?
