Frank65
Everything posted by Frank65
  1. Hello Take a look this thread
  2. maybe this video can help
  3. Hello Just select coil temperature field , push "options" button and change step size parameter to 1.
  4. Thanks , I just modified the fonts.
  5. Version 2.8.3
    2,517 downloads
    Replay Black on white theme r2.8.3
  6. Version 2.8.9
    28,492 downloads
    Last Version Rev 2.8.9 - August 2021 Full options theme with Replay. Rev 2.8.8 - March 2019
  7. Hello Is it normal board\software beahaviour that (always) when I start firing the device , software stops calculating room temperature ? This both on fw24\25 , testing with mod (Therion 75c) connected to device monitor (with USB chargin off). After sometime (I just tested first 26 min , second 16 min , third 39 min freezing) , it unfreezes and restart calculation, with a sudden temp value deviation. Sure that's not a major bug , but I'm curios to know ,beside how "it" works, if is there any magic trick \ hidden parameter to shorten freezing time period ? Thermal test performed , room temperature (when not freezed) is very near real temperature . Sorry 4 bad english ..
  8. Hi Any difference between SP5.1 and SP5.1c ..?
  9. Same here . Even if new SP24 took an improvement , "smoking feeling" is still somehow low . But I think you are in the right direction ... My ecig ,SS316L profile 8, Therion 75C 34_sp5_fw24.ecig
  10. I'm far from home too , but at first glance this is a big improvement : I cannot make any precise measure but my current res measure jumped up around 0.3 \ 0.4 ohms from sp23 to sp24 ... Nice job !
  11. Dear Mr.James Below my test results on Therion DNA75C: Device powered up by fire button I=GET OFFSET [RESULT=0.097A ] V=GET OFFSET [RESULT=0.034V ] R=SAMPLE OFFSETS I=GET OFFSET [RESULT=0.090A] V=GET OFFSET [RESULT=0.030A] R=SAMPLE OFFSETS I=GET OFFSET [RESULT=0.098A] V=GET OFFSET [RESULT=0.034V] R=SAMPLE OFFSETS I=GET OFFSET [RESULT=0.090A] V=GET OFFSET [RESULT=0.030A] R=SAMPLE OFFSETS I=GET OFFSET [RESULT=0.098A] V=GET OFFSET [RESULT=0.035V] SS316 coil measured on other device = 0,64 ohm On therion 75C= 0,5998 ohm delta=0,042 ohm room temp 27 degc \ same result on mod BR , Francesco
  12. Hello Exacly same delta here with Therion 75C , it reads minus 0.04 ohms on cold coil . With last SP23 , after performing case analyzer , at first glance I have much better results (after manually playing with Case static Temp rise parameter , which was not calculated by analyzer). Thanks ! regards , Francesco
  13. hello attached my results on Therion DNA75C Sorry if this is a stupid question (I'm new on DNA stuff) but do have i to calculate the static delta temp manually ? Regards Francesco
  14. Thank you Mr.James !
  15. Hello I'm definitely not an expert owning my first dna mod from a week , anyway with latest beta sp I had a problem with Battery pack volt reading stuck around at 54% , downgrading to last official one it went ok. Best regards Francesco ps : cold ohm reading is still too low on both service packs
