Lowbytes
Everything posted by Lowbytes
  1. Never again any coated or lacquered Hcigar mods! My 3 weeks old VTC75C loosing color and looking like it is more than a year old IF - i´d go with a stainless one - it also looks like they´ve changed the battery coverage - a step forward!
  2. Can´t await DNA75 and DNA200 to be added !
  3. By the way - best way to practice my bad english - 40 Years ago finished school ...... hopefully the gramma is not too bad ;-)
  4. If mounted correctly it should be fine.........
  5. i´m just a user with limited knowledge - i´m still learning...........
  6. So it might be the black version of the fat daddy
  7. Normally Boxer/Rebel using Fat Daddy 510 connectors - for me the best 510 - so if you have problems to tighten the atomizer completely the problem is related to the threading of the atomizers 510 ----SMOK crap? Sorry - maybe others having different experiences with SMOK Atomizers ...... i do´nt like them - to much trouble ;-)
  8. So - one more try - i´ll take a look into your problem - can you please upload your ecig file of both mods - maybe we can discover whats up............
  9. 0,019 ohm????? Normally you use a copper tool to read the internal mod resistance - the copper will shorten the 510 connector with no external resistance - so your measurement will only read the internal resistance of the wire - 510 connector - usually it will come out with 0,003 ohms - this 0,003 ohms are part of the total resistance measured with an attached atomizer - if your atomizers coil is 0,16 Ohms you´ll have a total resistance of 0,163 Ohms - the DNA knows that the 0,003 Ohms are not the part of the coil resistance - So without copper tool you´ll never get 100% accurateness - the lower the numbers of the mod (mod resistance) the better it is. But thats my interpretation of the function - as i told you i´m not an expert - stay tuned until someone from evolve follows and answer your question............or someone else here in the forum Regards Mikel
  10. You´re always welcome! (b.t.w i´m not a specialist - so following my tips is on your own risk)
  11. In the end you will find out that it is (mostly) 0,003 Ohms of mod resistance (like my Boxer) - for exact results you also should do the case analyze !
  12. For the test mod resistance calibration you need to use TC wire - of course your mod will also work with Kanthal coils Please make sure that both mods are using the same wire material curves!
  13. So now only waiting for the 200 to be added........ Great!
  14. Yes - using the same curve on the others! Of course ist no ss316 (V4A) i´m on SS304 (V2A)
  15. Here we go! lowbytes1.ecig
  16. 0,36 Ohms
  17. Still weird results If i set my resistance manually to 0,334 i get the same results as on my other DNA´s - if i use the measured resistance it is ignoring my power settings (20W) and bouncing around the Preheat power
  18. Here we go - attached the VT75C Theme HCIGAR_VT75C.ecigtheme
  19. Please use the latest from the thread "Ohms reading too low" you have to manually load it into escribe !
  20. Mine set to 0,003 - are you already on the latest beta 24 ?
  21. David247 Direct contact to HCIGAR (not me personally but a Member of German DNA group - he has ordered 50 devices directly from Hcigar - when we found out the problem with the battery cover he ask for a replacement and he was told that the new battery covers will not fit the "old tube" - so (after a little shitstorm on the hcigar facebook site) they got an agreement for the spare parts! After giving some comments on the Hcigar site - they blocked me! So for me no chance to get the parts ;-)
  22. The "newer" batches of the Hcigar VT75C will have different Battery covers - they´ve also changed the threading of the battery cover and of the bat tube so all early adaptors are disadvantaged - the parts are change able - but how to get them..............? Mine came from gearbest - but i´m sure they will not ship the redesigned parts ..................
  23. Flog - No - currently the missing current is captured by the "gray´s" via an inter dimensional tunnel ! Thanks god i´m wearing a hat made out of silver foil ;-)
